Hi Geo.
Not good. Only three active levels, something impossible.
Check the measurement.
You measure the PIN 14, 15, 2kom load to GND.
To be correct GND and Vcc.
Actuation of the serial number of a separate resistor compositions from Vcc to test PIN1-8.
No links with the SLC and the VCO, but the measurement DAC!
Try to do an experiment to change the levels of H / L for 1,3,4 PIN.
Is there something changes?
Is the rigid tension PIN3, 4, without any pins?
See why you need to wait 10 minutes, normally 1 sec after the configuration.
And you have a good frequency of the X-tal?
Because I can configure so long, because a small frequency.
Check out the case.
Best regards Chris.
Check out the case.
Best regards Chris.
