Well LM311 is used for this job in a later model, so it is possible that I misread the scraped away marking.
F1A4 Mods anyone?
Actually you're probably right, it likely is the 1011. Looked over the datasheet again and found typical applications which matched the configuration here - along with a phrase "When the emitter is used as the output, the collector istypically tied to V+ and the load is connected to groundor V–."Originally posted by Mechanic View PostWell LM311 is used for this job in a later model, so it is possible that I misread the scraped away marking.
I guess it was the output transistor that confused me - I'll stick with LT1011 after all!
