modification ATX
  • Mechanic
    Ooops, the preamp ic is missing from the last file.
    Please see the updated pic.. Click image for larger version
Name:	Front end receive.jpg
    Cheers Mick
  • Mechanic
    Hi Guys,
    Here is the atx front end I don't have values for the tx and rx coils that I can find.
    Cheers MickClick image for larger version
  • daverave
    i have wire like in the photo and mine is litz...cant believe garrett would use ordinary wire.
  • Davor
    Originally posted by DOOLEY View Post
    now who posted this picture ages ago with the suggestion a coil could be
    balanced using this configuration ????............................
    We had a thorough discussion on this coil here: http://www.geotech1.com/forums/showt...New-PI-machine
    Aziz even made calculations with dimensions that balanced. The inner eye size is critical for balance. However, for PI a perfect balance is not a requirement.
  • Geo
    PI detectors with separate TX and RX coils do not need the coils to be induction balanced. There are two possibilities here that I can think of:
    1) The sensitive area is within the centre circle, whereas a standard DD configuration would have a thin sensitive area from front-to-back.
    2) It was designed to make the casual observer conclude that the coil is actually a concentric.
    I believe the second...
  • Koala
    After watching a video , you may be right, the video showed detecting a small gold clasp that other coils could not detect.
    I was also watching YouTube. Quite respectably distance on a .1 gram gold nugget. Pinpoints really well.
  • 6666
  • Qiaozhi
  • 6666
    hum,
    so basically inside it's arranged like this then ????
    [ATTACH]34676[/ATTACH]
    I made some coils in that configuration and when they were balanced there was a lot of difference in over lap distances from original atx coil,
    it only required a small amount of overlap to balance,
    Bending the coils more to the atx shape I could not balance them with placing coils over each other like the atx design, I had to move them father apart to balance, without having an atx coil to test, my conclusion (right or wrong)
    was the atx coil is not IB.
  • greylourie
    WM6
  • DOOLEY
    hum,
Name:	Concentric DD COIL.gif
  • Davor
    It was only obvious. I'm a bit surprised to see plain magnet wire, and no trace of tidiness. With proper initial geometry it must be very easy to balance.
  • 6666
    Thanks for the picture it confirms some theory's about the coil construction .
  • tifred
    HI 6666
    Yes I have the number of turns and type of wire, but there is resistance and I have no value, it is breaking.
    I have pictures but I do not know if I'm allowed to show, there surely has a garrett patent.
  • 6666
    Hello Tifred what did you do with the windings of the coil ? do you still have the wire ? can you remove the wire from the potting mix so we can learn how garrett made the coil ?
    do you have any more pictures of the coil ?
