Originally posted by Micheal
(I'm kidding.)
Very nice work, fast too! Is that shiny blue wire teflon insulated?
What you should do is get several different colors of wire so you can color code your connections (in the future). PVC is much easier to work with than teflon, by the way.
You should color code the five wires, using a Sharpie, Magic Marker or whatever brand permanent marker you have in Oz. W2=red W4=black W3=green and you can make the other two whatever you choose. Or don't color code. Five wires shouldn't be too hard to keep straight.
You need to connect W2 to +5V, W4 to -5V, and W3 to ground. Making the connections near the voltage regulators would be ideal.
W1 is the target in. You must find the output from the next to last amplifier in your machine. Hopefully your detector's amplifier chain follows the older versions. Ummh, yes?
Find the base resistor of your output transistor (47k) and connect W5 to the signal input end. Make sure you disconnect from the old audio oscillator (LM35
. The connection end will probably need to be left flying. Be careful not to rip the resistor from the board. It this works you can remove the LM358 (and solder the resistor end back on the board) but don't do so yet.That should be it. I suppose the hard part is finding the "Target Signal" connection point. As I look at the XL500 schematic from Homefire it looks like the junction of the .022 cap and two 470k resistors may be a good place. It's between the CA3140 and the LM741.
It looks like you have a polyester cap for the 4.7nF. If your output frequency drifts you should replace that with PP or PS.
I see that next time I post a schematic I should make a parts list. You could have used el-cheapo 0.1 disk caps for C1 and C5, but mylar (aka polyester, "film") caps are better. Also, C4 should be temperature stable (polypropylene, etc.) because we want the VCO frequency to be stable even as temperature changes.
That's it! Fire it up and watch it smoke! For safety purposes you should wear safety glasses. I had an electrolytic cap explode one time. It became a projectile and missed my eye by about 1 inch. That's no joke.
