Good news - my Fisher 1266-X schematic should be still here:
http://www.geotech1.com/forums/showp...&postcount=149
This link seems to be dead:
http://www.geotech1.com/forums/showp...78&postcount=2
The 1265 circuit is here:
http://www.geotech1.com/forums/showthread.php?t=17696
Don't know about the 1280x but I heard the 1270x wasn't
half as good as the 1265 or 1266.
Perhaps the 1265x was better at 18mm 5pence test because
of the smaller coil (8'' vs 10.5''). But some people seem to
recall the 1265x was slightly deeper as the 1266x -
contrary to the above advertising info paper.
btw. does the 1265x has non-motion pinpointing, too?
(if you pull the trigger below the housing, pushing is Disc 2)
here some additional interesting links:
Seems there are no Fisher 1265-X videos on youtube (perhaps
you have the motivation to film some?) but for the 1266-X.
The signals for the coins at 35cm 1ft. are very weak, though.
http://www.youtube.com/watch?v=GSGs-wEUrY4
fisher 1266x - silver coin
http://www.youtube.com/watch?v=_-D1GfuWaMs
Fisher 1266x - american coins - 10.5'' coil
http://www.youtube.com/watch?v=qjMM8KGwZ3s
Fisher 1266x - american coins - 8'' coil
http://www.youtube.com/watch?v=aUqlK8X_dTw
Fisher 1266x - metal detector test in air
And here is a huge amount of info, also some about the 1265.
http://www.treasurenet.com/forums/re...ng-legend.html
btw. after this 5 pence test info I have tested a similar coin -
1 Cent (Euro) 17mm copper, with the 10.5'' (26.5cm) coil
and I could also detect it at 10'' (15cm) but inside the
livingroom with heavy electricity and radiation stuff.
I guess at an electrosmog free location I would reach it at
20cm / 8'' distance - in air. The slightly larger 2 Cent coin
was detectable indoors at ca. 17.5cm / 7 inches.
With this new mod now it is possible to set the noise to an
acceptable level; before there was no way for indoor usage.
They should have created a much more wide spreaded
sensitivity range for this detector in the beginning because
also outside exists enough locations near powerlines or
special houses that makes searching impossible otherwise.
Perhaps I'll find some very silent spot outside to repeat those
small coin-tests. But already it seems that the complete mod
gives around 20% more depth compared with before.
