LM394 on my Minelab PCB
Hi Mario,
I think they are bby42 as their marking is s13 perhaps the 23 on there is just identifying the package so23. http://www.datasheetcatalog.org/data...ps/BBY42_1.pdf If you buy one in your next order you could see if it is marked the same and tests the same with your multimeter on the diode function and then finally replace the existing ones with replacement ones and if it all works as it did before they are the same.
Also I think you have made a mistake with the yellow trace and the inductor next to that little board. The yellow trace shorts out the inductor! I would also have a close look at the blue trace off that board with your scope to see if there are any oscillations there that get amplified by the other single fet, or if the other single fet in conjunction with the 6.8nf cap and surrounding resistors is making the oscillations. There is a fair chance that to change the frequency of the oscillator more than one component may have to be changed.
Also do ic's 7 and 9 have a chamfered edge? if so they could be 74hc4024 as that seems to be the only so14 74hc chip(that farnells have!) The pinout however does not look correct according to your trace. pin 1 of ic7 should be fed by the oscillator if it were a 4024. Might be worth another look.
Cheers Mick
Hi Mick,
thanks for the heads up on the S13 parts. I have them on order and will be testing them as soon as i get them.
You are right about the trace being incorrect for that inductor. My guess is that it runs parallel to a nearby capacitor. Those capacitors are always giving me incorrect values for the nearby parallel components.
I have a microscope on order, so hopefully we will make progress identifying ICs 4,6,7, and 9. I dont know if we will identify all of them because some were scrubbed deep, but we will continue identifying them.
Now regarding the frequency, i think the 1.2 Mhz has more to do with the speed dealing with timing issues right? In other words, if we speed up the frequency we speed up the timings? if that is the case, then wouldnt need to know the contents of the eeprom? I ask because that sine wave is very different from the variable square waves going across the coil. im going to post pictures so that u may see what im talking about. I think those waves may be running at a different frequency...
Hi Mario,
Yes that is correct, the oscillator drives the logic cct that changes the eeprom address to change the transmit and sample pulses. Speed up the clock and the transmit and sample pulses will speed up in proportion. Sine waves are not sent to the coil in a pulse induction metal detector. Square waves are used to drive the coil. You should see that the long tx is somewhere around 240us and then three 60us pulses. Just remember that after the transmit is turned off that there is a very short(1-5us) 180v pulse seen on the coil as the magnetic field collapses back into the coil. So you need to set your scope up accordingly to look at the coil, probe on X10, voltage on 5v/div and .1ms(100us)/div. Ground lead to coil gnd and probe to coil tx wire.
Did you get my email?
Cheers Mick
Finally some progress on frequency!
Ok, after countless more hours, I think I made some progress on changing the frequency. The trick is: Replacing the two lower right capacitors (the ones rated at 1nF and 6.8nF).
1nF, 2.2nF
75nF, 82nF
Corresponding square wave at pin 10, 4040 IC
1nF, 2.2nF
STOCK (More like 4.2 instead of 4!)
Now notice the effect on the transmit coil signal
Ok regarding the images, I need to mention a few points. One, There are only 2 smaller square waves because that S1323 part I removed during my testing remains removed. Otherwise, there would be 3 smaller square waves instead of the 2 you currently see (I need to do further testing to confirm if this part is bby42 as Mick suggested). I noticed the 2 smaller square waves only until Mick pointed it out on his last comment. However, reviewing old photos of this wave confirmed that the stock detector does transmit the 3 smaller square waves. Having said that, having 2 square waves does reduce the sensitivity of the detector significantly. (In the future, I might install another one of those S1323 parts to see if this makes the detector more sensitive...)
Two, when replacing the capacitors, the right most capacitor has to have higher capacitance than the the first. If you don't, the sine wave is going to be shifted and some what distorted, it makes the threshold erratic.
Three, as you go up in capacitor size, you will notice the threshold speed up. This was the case as I changed the values to 75nf-82nF. The detector became a bit unstable, although this was indoors, I have yet to experiment outdoors in a little EMI environment. By the same token, no noticeable threshold characteristics were noticed when going down in capacitance. I guess to make the transmit signal smaller you need to play with >1nF capasitors maybe?
Anyways, there you have it. I'll continue experimenting tomorrow...
Hi Mario,
You do have 3 short tx pulses! The transmit is the lower part of the trace, the coil runs on -7v(batt voltage) referenced to gnd.
Looks like you have made some good progress controlling the clock. You will be surprised at the difference in sensitivity to smaller targets now. If you can make it so you can switch in the caps to make it run standard frequency so in the field you can do a valid comparison on any improvements. I would set it up with the 1 and 2nf capacitors for the higher frequency and then set up the correct capacitors to make up the original values and add them in with a switch. I would be inclined to try and get it running a bit faster first though, but why not try it anyway.
Now another thing which you need to be aware about is jitter in the clock frequency. How I test for jitter is set my scope for 10X magnification of the time base and then scroll to the end of my trace. You need to have lots of waves visible (100 or more from where the scope triggered)so you can only just make them out. If the end is bouncing back and forth or the end lines are thicker than the ones at the start this would indicate that the oscillator has jitter. This jitter can cause instability in the threshold and the detector less sensitive. If the trace looks as good at the end as at the start everything is fine. I hope that makes sense!
Cheers Mick
Originally posted by mario View PostCan any one help me out to identify these? are they fets, voltage regulators? I removed one and still the frequency does not change, the threshold just becomes more unstable
H Mario
Those sot23 devices are veracters,they are in parrell to increase the capacitance,the capacitance is increased and decreased by changing the voltage applied to them,the adjustable trimmer used to adjust the emi will be adjusting the voltage applied to them.
Removing one will reduce the overall range of the adjustment.
Zed
Well, there you go gentlemen. With 60 cents and mediocre soldering technics, you too can make your SD2100 more sensitive.
Next, Im going to flash that hex and try to identify those remaining ICs. Im sure a lot of fried 2100s are going to start appearing on ebay soon regardless-Lol.
Mick, is there a way to tell the timing from those pics?
I know I need 10uS for small gold. I would like to know its stock settings.
A big thanks!
Hi Zed,
That makes sense, thanks for the explanation.
Mario
As far as getting the rest of the sample timings goes you need to set up your scope to read the tx pulses as you had it and with your other channel probe the control pins on the 4066's and see when each sample pulse is happening. You might need to zoom in a bit closer to get accurate measurements. I see that you have missed one of the sample control lines to one of the 4066's there should be 6 control lines. As far as working out which samples are for which channels goes you need to work out which cap/trimmer is for what channel, ch1 gb and ch2. Channel 2 will have its samples after the short tx pulses and ch1 will have its sample pulses after the long tx, but also the ground sample will be taken between ch1 first and second sample and after the last short tx pulse. Once you figure this out, try and trace the pulses back to the eeprom so you know what pins on the eeprom control what.
Cheers Mick
Can any one here tell me more about the contents of this Hex file?
I'm not saying it's the contents of the 28C256 eprom. I'm saying, If this was the dump, how can we change the timings.
Code::10000000F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F780 :10001000F7F7F7F7F7F79706040604060406040651 :100020000406040604060406040604060406040680 :1000300004060406040697F7F7F7F7F7F7F7F7F75C :10004000F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F740 :10005000F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F730 :10006000F7F7F7F7F7F7F7F7F7F7F7F7F7F71406F4 :100070000406040604060406040604060406040630 :10008000040604060406040604060406040604F72F :10009000F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F0 :1000A000F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7E0 :1000B000F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7D0 :1000C000F7F7F7F7F7F7F7F7040604060406040650 :1000D00004060406040604060406040604060406D0 :1000E0000406040604060406F7F7F7F7F7F7F7F730 :1000F000F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F790 :10010000F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F77F :10011000F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F76F :10012000141614161416141614161416141614167F :10013000141614161416141614161416141614364F :1001400014F6F7F7F7F7F7F7F7F7F7F7F7F7F7F723 :10015000F7F7F7F7141614161416141614161416C7 :10016000141614161416141614161416141614163F :100170001416143694F7F7F7F7F7F7F7F7F7F7F7DA :10018000F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7FF :10019000F7F7F7F7F777F7F7F7F7F7F7F797F7F7CF :1001A000F7F7F7F7F7F7F7F7F7F7971614161416A8 :1001B00014161416141614161416141614161416EF :1001C0001416141614161416143614F6F7F7F7F757 :1001D000F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7AF :1001E000F7F7F7F7F7B7F7F7F7F7F7F7F7F7F7F7DF :1001F000F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F78F :10020000F79704060406040604060406040604061A :10021000040604060406040604060406040604068E :1002200004F7F7F7F7F7F7F7F7F7F7F7F7F7F7F751 :10023000F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F74E :10024000F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F73E :10025000F7F7F7F7F7F7F7F797060406040604062B :10026000040604060406040604060406040604063E :10027000040604060406040694F7F7F7F7F7F7F701 :10028000F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7FE :10029000F7F7F7F704060406040604060406040646 :1002A000040604060406040604060406F7F7F7F736 :1002B000F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7CE :1002C000F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7BE :1002D000F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7AE :1002E000F7F70406040604060406040604060406DA :1002F00004060406040604060406040604060406AE :1003000014F614F7F7F7F7F7F7F7F7F7F7F7F7F744 :10031000F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F76D :10032000F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F75D :10033000F7F7F7F7F7F7F7F7F7D7F7F79516141674 :10034000141614161416141614161416141614165D :100350001416141614161416143614F7F7F7F7F7C4 :10036000F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F71D :10037000F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F70D :10038000F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7FD :10039000F7F7F797141614161416141614161416E5 :1003A00014161416141614161416141614161416FD :1003B000143614F6F7F7F7F7F7F7F7F7F7F7F7F755 :1003C000F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7BD :1003D000F7F7F7F7F7F7F7F7F7F7F7F7F7F7141671 :1003E00014161416143694F7F7F7F7F7F7F7F7F72C :1003F000F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F78D :10040000040604060406040604060406040604069C :10041000040604060406040604060406040604068C :10042000040604060406040606060406040604067A :100430000406040604060606060604060406060666 :100440000606040604060406040606060606040656 :10045000040604060406040604060406040604064C :10046000040604060406040604060406040604063C :10047000040604060406040604060406060604062A :10048000040604060406040604060406040604061C :100490000606040604060406040606060406040608 :1004A00004060606040604060406040604060406FA :1004B00004060406040604060406040604060406EC :1004C00004060406040606060406040604060406DA :1004D00004060406040604060406040606060406CA :1004E00004060406040604060406040604060606BA :1004F00004060406040604060406040604060406AC :10050000141614161416141614161416141614169B :10051000141614161416141614161416141614168B :100520001416141614161416141616161616141677 :10053000141614161416141614161416141614166B :10054000141614161416141614161416141614165B :10055000141614161416141614161416141614164B :100560001416161614161416141614161616141637 :10057000141614161416141614161416141614162B :100580001616141614161416141614161416141619 :100590001416141616161416141614161416141609 :1005A00014161416141614161416141614161416FB :1005B00014161616141614161416161614161416E7 :1005C00014161416141614161416141614161616D9 :1005D00014161416141616161416141614161416C9 :1005E00014161416141614161416141614161416BB :1005F00014161416141614161416141614161416AB :10060000040604060406040604060406040604069A :100610000406040606060406040606060606040684 :100620000606040604060406040604060406040678 :10063000040604060406040604060406040604066A :10064000040604060406040604060406040604065A :10065000040604060406040604060406040604064A :100660000406060604060406040606060406040636 :10067000040604060406040604060406040604062A :10068000040604060406040604060406040604061A :100690000406040604060406040604060606040608 :1006A00004060406040606060406040604060406F8 :1006B00004060606040604060406040604060406E8 :1006C00004060406040604060406040604060406DA :1006D00004060406040604060406040604060406CA :1006E00004060406040606060406040604060406B8 :1006F00004060606040604060406040604060406A8 :100700001416161616161616141614161416141693 :100710001416141614161416141614161416141689 :100720001416141614161416141614161416141679 :100730001416141614161416141614161416141669 :100740001417161614161416141614161416141656 :100750001416141614161416141614161616141647 :100760001416141614161416141614161416141639 :100770001416141614161416141614171416141628 :100780001416141614161416141614161416141619 :100790001416141614161416141614161416141609 :1007A00014161416141614161416171614161416F6 :1007B00014161616141614161416141614161416E7 :1007C00014161416141614161416141614161416D9 :1007D00014161416141614161416141614161616C7 :1007E00014161416141614161416141614161417B8 :1007F00014161416141614161416141614161416A9 :100800000406040604060406040604060406040698 :100810000406040604060406040604060406040688 :100820000406040604060406040606060606040674 :100830000406040604060406040604060406040668 :100840000406040604060406040604060406040658 :100850000406040604060406040604060406040648 :100860000406040604060406040604060406040638 :100870000406040604060606040606060606060620 :100880000406040604060406040604060406040618 :100890000406040604060406040604060406040608 :1008A00004060406040604060406040604060406F8 :1008B00004060406040604060606040604060406E6 :1008C00004060606040604060406040604060406D6 :1008D00006060406040604060406040606060606C2 :1008E00004060406040604060406040604060406B8 :1008F00004060406040604060406040604060406A8 :100900001416141614161416141614161416141697 :100910001416141614161416141614161416141687 :100920001416141614161416141614161416141677 :100930001416141614161416141614161416141667 :100940001416141614161416141614161416141657 :100950001416141614161616141614161416161643 :100960001416141614161416141614161416141637 :100970001416141614161416141614161416141627 :100980001416141614161416141614171416141616 :100990001416141614161416141614161416141607 :1009A00014161416141616161416141616161416F3 :1009B00014161416141614161416141614161416E7 :1009C00014161416141614161416141614161416D7 :1009D00014161416141614161416141614161416C7 :1009E00014161416141614161616141614161416B5 :1009F00014161616141614161416141616161616A1 :100A00000406040604060406040604060406040696 :100A10000406040604060406040604060406040686 :100A20000406040604060406040604060406040676 :100A30000406040604060406040604060406040666 :100A40000406040604060406040604060406040656 :100A50000406040604060406040604060706040643 :100A60000406040604060406040604060406040636 :100A70000406040604060406040604060406040626 :100A80000606040604060406040604060406040614 :100A90000406060604060406040604060406040604 :100AA00004060406040604060406040604060406F6 :100AB00004060406040604060406040604060406E6 :100AC00004060406040606060406040604060406D4 :100AD00006060406040606060406040604060406C2 :100AE00004060406040604060406040604060406B6 :100AF00004060406040604060406040604060406A6 :100B00001416141614161416141614161416141695 :100B10001416141614161416141614161416141685 :100B20001416161614161416141616161416141671 :100B30001416141614161416141614161416141665 :100B40001416141614161416141614161416141655 :100B50001416141614161416141614161416141645 :100B60001416141614161416141614161416141635 :100B70001416141614161416141614161416141625 :100B80001416141614161616161614161416141611 :100B90001416141614161616141614161416141603 :100BA00014161416141614161416141614161416F5 :100BB00014161416161614161416141616161416E1 :100BC00014161416141614161416141614161416D5 :100BD00014161416141614161416141614161416C5 :100BE00014161416141614161416141614161416B5 :100BF00014161416141614161416141614161416A5 :100C00000406040604060406040604060406040694 :100C10000406040604060406040604060406040684 :100C20000406040606060406040604060406040672 :100C30000406040604060406040604060406040664 :100C40000406040604060406040604060406040654 :100C50000406060604060406040606060406040640 :100C60000406040604060606040604060406040632 :100C70000406040604060406040606060406040622 :100C80000406040604060406040604060606040612 :100C90000406040604060406040604060406040604 :100CA00006060406040604060406040604060406F2 :100CB00004060406040604060406040604060406E4 :100CC00004060406040604060406040604060406D4 :100CD00004060406040604060406040604060406C4 :100CE00004060406040604060406040604060406B4 :100CF00004060406040604060406040604060406A4 :100D00001416141614161416141614161416141693 :100D10001416141614161416141614161416141683 :100D20001416141614161416141614161416141673 :100D3000161614161616141614161416141614165F :100D40001416141614161416141614161416141653 :100D50001416141614161416141614161416141643 :100D60001416141614161416141614161416141633 :100D70001416161614161416141614161416141621 :100D80001416141614161616141614161416141611 :100D90001616141614161416141614161416141601 :100DA00014161416141614161416141614161416F3 :100DB00014161416141614161416141614161416E3 :100DC00014161416141614161416141614161616D1 :100DD00014161416141616161416141614161416C1 :100DE00014161416141614161416141614161416B3 :100DF00014161416141614161416141614161416A3 :100E00000406040604060406040604060406040692 :100E1000040604060406040604060606040606067E :100E20000406040604060406040604060606040670 :100E30000406040604060406040604060406040662 :100E40000406040604060406040604060406040652 :100E5000040604060606040604060406040606063E :100E60000406040604060406040604060606040630 :100E70000406040604060406040604060406040622 :100E80000406040604060406040604060406040612 :100E90000406040604060406040604060406040602 :100EA00004060406040604060406040604060406F2 :100EB00004060406040604060406060604060406E0 :100EC00004060406040606060606040604060406CE :100ED00004060406040604060406040604060406C2 :100EE00004060406040604060406040604060406B2 :100EF00004060406040604060406040604060406A2 :100F0000141614161416141614161416161616168D :100F1000141614161616161614161416141614167D :100F2000141614161416161616161616141614166B :100F30001416141614161416141614161416141661 :100F40001416141614161416141614161416141651 :100F5000141614161616141614161416141616163D :100F6000161616161416141614161416141614162D :100F70001416141614161416141614161416141621 :100F8000141614161416161616161416141614160D :100F900014161416141616161416141614161416FF :100FA00014161416141614161416141614161416F1 :100FB00014161416141614161416141614161416E1 :100FC00014161416141614161416141614161416D1 :100FD00014161416141614161416141614161416C1 :100FE00014161416141616161616141614161416AD :100FF00014161416141614161416141614161416A1 :10100000F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F770 :10101000F7F7F7F7F7F7F7F7F7F70406040604060C :101020000406040604060406040604060406040670 :101030000406040604060406040697F7F7F7F7F714 :10104000F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F730 :10105000F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F720 :10106000F7F7F7F7F7F7F7F7F7F7F7F7F7F7F70601 :101070000406F7F7F7F7F7F7F7F7F7F7F7F7F7F7E4 :10108000F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F0 :10109000F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7E0 :1010A000F7F7F7F7F7F7F7F7040604060406040660 :1010B00004060406040604060406040604060406E0 :1010C0000406F7F7F7F7F7F7F7F7F7F7F7F7F7F794 :1010D000F7F7F7F7F7F7F7F7F797040604060406AC :1010E00004060406040604060406040604060406B0 :1010F000040604060406040604F7F7F7F7F7F7F703 :10110000F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F76F :10111000F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F75F :10112000F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F74F :1011300094161416141614161416141614161416DF :10114000141614161416141614161416141614362F :1011500014F7F7F7F7F7F7F7F7F7F7F7F7F7F7F702 :10116000F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F70F :10117000F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7FF :10118000F7F7F7F7F7F7F7F797161416141614167C :1011900014161416141614161416141614161416FF :1011A00014161416143614F7F7F7F7F7F7F7F7F7DE :1011B000F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7BF :1011C000F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7AF :1011D000F7F7F7F7F7F7F7F7F7F7F7F7F7971416C3 :1011E00014161416141614161416141614161416AF :1011F00014161416141614161416143614F7F7F7DA :10120000F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F76E :10121000F7970406040604060406040604060406FA :10122000040604060406040604060406040604066E :1012300004F7F7F7F7F7F7F7F7F7F7F7F7F7F7F731 :10124000F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F72E :10125000F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F71E :10126000F7F7F7F7F7F7F70604060406040604068F :101270000406040604060406040604F7F7F7F7F765 :10128000F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7EE :10129000F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7DE :1012A000F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7CE :1012B000F79704060406040604060406040604065A :1012C00004060406040604060406040604060406CE :1012D000F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F79E :1012E000F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F78E :1012F000F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F77E :10130000F7F7F7F7F79714161416141614161416A1 :10131000141614161416141614161416141614167D :101320001416141614F614F7F7F7F7F7F7F7F7F79C :10133000F7F7F7F7F7F7F7F714161416141614164D :10134000141614161416141614161416141614164D :1013500014161416141614F6F7F7F7F7F7F7F7F74D :10136000F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F70D :10137000F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7FD :10138000F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7964E :1013900014161416141614161416141614161416FD :1013A00014161416141614161416143614F6D7F749 :1013B000F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7BD :1013C000F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7AD :1013D000F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F79D :1013E000F7F7F7F7F7F71416141614161416141661 :1013F000141614161416141614161416141614169D :10140000040604060406040604060406040604068C :10141000040604060606040604060406040604067A :10142000040604060406040604060406040604066C :10143000040604060406040604060406040604065C :10144000040604060406040604060406040604064C :10145000040604060406040604060606040604063A :10146000040606060406040604060406040604062A :10147000040604060406040604060406040604061C :10148000040604060406040604060406040604060C :1014900004060406040604060406040604060406FC :1014A00004060406040604060406040604060406EC :1014B00004060406040604060406060604060406DA :1014C00006060406040604060606040604060406C8 :1014D00006060406040604060406040604060406BA :1014E00004060406040604060406040604060406AC :1014F000040604060406040604060606040604069A :101500001416141614161616141614161416141689 :101510001416141616161616141614161416141677 :101520001416161614161416141614161416141669 :101530001416141614161416141614161416171658 :10154000141614161416141614161416141614164B :101550001416141614161416141614161416161639 :10156000141614161416141614161416141614162B :10157000141614161416141614161416141614161B :10158000141614161416141614161416141614160B :1015900014161416141614161416141614161416FB :1015A00014161416161614161416141614161416E9 :1015B00014161616141614161616141614161416D7 :1015C00014161416141614161416141614161416CB :1015D00014161416141614161416141614161416BB :1015E00014161416141714161416141614161416AA :1015F0001416161614161416141614161416141699 :101600000406040704060406040604060406040689 :10161000040604060406040604060406040604067A :10162000040604060406040604060406040604066A :101630000406040604060606060604060406040656 :101640000406060604060406040604060406060646 :10165000040604060406040604060406040604063A :10166000040604060406040604060406040604062A :10167000040604060406040604060406040604061A :101680000406040604060406040604060606040608 :1016900004060406060604060406040604060606F6 :1016A00004060406060604060406040604060406E8 :1016B00004060406040604060406040604060406DA :1016C00004060406040604060406040604060407C9 :1016D00004060406040604060406040604060406BA :1016E00004060406040604060406040604060406AA :1016F0000406040604060606040604060406040698 :101700001416141614161416141614161416141689 :101710001416141614161416141616161416141677 :101720001416141614161416141616161416141667 :101730001416141614161416141614161416141659 :101740001416141614161416141614161416141649 :101750001416141614161416141614161416141639 :101760001416141614161416141614161416141629 :101770001416141614161416141614161416141619 :101780001416161614161416141614161416141607 :1017900014161416141614161416141614161416F9 :1017A00014161416141614161416141614161416E9 :1017B00014161416141614161416141614161416D9 :1017C00014161416141614161616141614161416C7 :1017D00014161416141614161416161614161416B7 :1017E00014171416141614161416141614161416A8 :1017F0001416141614161416141614161416141699 :101800000406040604060406040604060406040688 :101810000606040604060406040604060406060674 :101820000406040604060406040604060406040767 :101830000406040604060406040604060406040658 :101840000406040604060406040604060406040648 :101850000406040604060406040604060406040638 :101860000406040604060406040604060606060624 :101870000406040604060406040604060406040618 :101880000406040604060406040604060406040608 :1018900004060406040604060406040606060406F6 :1018A00004060406040606060406040604060606E4 :1018B00006060406040606060606040604060406D2 :1018C00004060406040604060406040604060406C8 :1018D00004060406040604060406040604060406B8 :1018E00004060406040604060406040604060406A8 :1018F0000406040604060406040604060406040698 :101900001416141614161416141614161416141687 :101910001416141614161416141614161416141677 :101920001416141614161416141614161416141667 :101930001416141614161416141614161416141657 :101940001416141614161416141614161416141647 :101950001416141614161416141614161416141637 :101960001416141614161416141614161416141627 :101970001416141614161416141614161416141617 :101980001416141614161416141614161416141607 :1019900014161416141614161416141614161416F7 :1019A00014161416141614161416141614161416E7 :1019B00014161416141614161416141614161416D7 :1019C00014161416141614161416141614161416C7 :1019D00014161416141614161416141614161416B7 :1019E00014161416141614161416141614161416A7 :1019F0001416141614161416141614161416141697 :101A00000406040604060406040604060406040686 :101A10000406040604060406040604060406040676 :101A20000406040604060406040604060406040666 :101A30000406040604060406040604060406040656 :101A40000406040604060406040604060406040646 :101A50000406040604060406040604060406040636 :101A60000406040604060406040604060406040626 :101A70000406040604060406040604060406040616 :101A80000406040604060406040604060406040606 :101A900004060406040604060406040604060406F6 :101AA00004060406040604060406040604060406E6 :101AB00004060406040604060406040604060406D6 :101AC00004060406040604060406040604060406C6 :101AD00004060406040604060406040604060406B6 :101AE00004060406040604060406040604060406A6 :101AF0000406040604060406040604060406040696 :101B00001416141614161416141614161416141685 :101B10001416141614161416141614161416141675 :101B20001416141614161416141614161416141665 :101B30001416141614161416141614161416141655 :101B40001416141614161416141614161416141645 :101B50001416141614161416141614161416141635 :101B60001416141614161416141614161416141625 :101B70001416141614161416141614161416141615 :101B80001416141614161416141614161416141605 :101B900014161416141614161416141614161416F5 :101BA00014161416141614161416141614161416E5 :101BB00014161416141614161416141614161416D5 :101BC00014161416141614161416141614161416C5 :101BD00014161416141614161416141614161416B5 :101BE00014161416141614161416141614161416A5 :101BF0001416141614161416141614161416141695 :101C00000406040604060406040604060406040684 :101C10000406040604060406040604060406040674 :101C20000406040604060406040604060406040664 :101C30000406040604060406040604060406040654 :101C40000406040604060406040604060406040644 :101C50000406040604060406040604060406040634 :101C60000406040604060406040604060406040624 :101C70000406040604060406040604060406040614 :101C80000406040604060407040604060406040603 :101C900004060406040604060406040604060406F4 :101CA00004060406040604060406040604060406E4 :101CB00004060406040604060406040604060406D4 :101CC00004060406040604060406040604060406C4 :101CD00004060406040604060406040604060406B4 :101CE00004060406040604060406040604060406A4 :101CF0000406040604060406040604060406040694 :101D00001416141614161416141614161416141683 :101D10001416141614161416141614161416141673 :101D20001416141614161416141614161416141663 :101D30001416141614161416141614161416141653 :101D40001416141614161416141614161416141643 :101D50001416141614161416141614161416141633 :101D60001416141614161416141614161416141623 :101D70001416141614161416141614161416141613 :101D80001416141614161416141614161416141603 :101D900014161416141614161416141614161416F3 :101DA00014161416141614161416141614161416E3 :101DB00014161416141614161416141614161416D3 :101DC00014161416141614161416141614161416C3 :101DD00014161416141614161416141614161416B3 :101DE00014161416141614161416141614161416A3 :101DF0001416141614161416141614161416141693 :101E00000406040604060406040604060406040682 :101E10000406040604060406040604060406040672 :101E20000406040604060406040604060406040662 :101E30000406040604060406040604060406040652 :101E40000406040604060406040604060406040642 :101E50000406040604060406040604060406040632 :101E60000406040604060406040604060406040622 :101E70000406040604060406040604060406040612 :101E80000406040604060406040604060406040602 :101E900004060406040604060406040604060406F2 :101EA00004060406040604060406040604060406E2 :101EB00004060406040604060406040604060406D2 :101EC00004060406040604060406040604060406C2 :101ED00004060406040604060406040604060406B2 :101EE00004060406040604060406040604060406A2 :101EF0000406040604060406040604060406040692 :101F00001416141614161416141614171416141680 :101F10001416141614161416141614161416141671 :101F20001416141614161416141614161416141661 :101F30001416141614161416141614161416141651 :101F40001416141614161416141614161416141641 :101F50001416141614161416141614161416141631 :101F60001416141614161416141614161416141621 :101F70001416141614161416141614161416141611 :101F80001416141614161416141614161416141601 :101F900014161416141614161416141614161416F1 :101FA00014161416141614161416141614161416E1 :101FB00014161416141614161416141614161416D1 :101FC00014161416141614161416141614161416C1 :101FD00014161416141614161416141614161416B1 :101FE00014161416141614161416141614161416A1 :101FF0001416141614161416141614161416141691 :102000000406040604060406040604060406040680 :10201000040604060406040604F7F7F7F7F7F7F7D3 :10202000F7F7F7F7F7F7F7F7F7F7F7F7F7F7F797A0 :102030000406040604060406040604060406040650 :102040000406040604060406040604060406040640 :10205000040604F7F7F7F7F7F7F7F7F7F7F7F7F7E7 :10206000F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F700 :10207000F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F0 :10208000F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7E0 :10209000970604060406040604060406040604065D :1020A00004060406040604060406040604060406E0 :1020B0000496F7F7F7F7F7F7F7F7F7F7F7F7F7F704 :1020C000F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7A0 :1020D000F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F790 :1020E000F7F7F7F7F7F7F7F7F7F7F7F7F7970406C4 :1020F0000406040604060406040604060406040690 :10210000141614161416141614161416141614F69F :1021100014F7F7F7F7F7F7F7F7F7F7F7F7F7F7F732 :10212000F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F73F :10213000F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F72F :10214000F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7977F :10215000141614161416141614161416141614162F :10216000141614161416141614161416141614161F :102170001416143697F7F7F7F7F7F7F7F7F7F7F7B7 :10218000F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7DF :10219000F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7CF :1021A000F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7971F :1021B00014161416141614161416141614161416CF :1021C000141614161416141614161416141614765F :1021D00014F7F7F7F7F7F7F7F7F7F7F7F7F7F7F772 :1021E000F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F77F :1021F000F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F76F :10220000F7F7F7F7F7F7F7F7F7F7F7F79706040693 :10221000040604060406040604060406040604066E :10222000040604060406040604060406040604065E :10223000D7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F74E :10224000F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F71E :10225000F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F70E :10226000F7F7F7F7F7F7F7F7F7F7F7F7F797040642 :10227000040604060406040604060406040604060E :102280000406040604060406040604060406F7F71A :10229000F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7CE :1022A000F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7BE :1022B000F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7AE :1022C000F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F79E :1022D000F7F7F7F7F7F7F7F7F7970406040604069A :1022E000040604060406040604060406040604069E :1022F00004060406040604060406F7F7F7F7F7F7E2 :10230000F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F75D :10231000F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F74D :10232000F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F73D :10233000F7F7F7F7F7F7D7961416141614161416BE :10234000141614161416141614161416141614163D :1023500014161416143614F6F7F7F7F7F7F7F7F71D :10236000F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7FD :10237000F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7ED :10238000F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7DD :10239000F7F7F7F7D71614161416141614161416A2 :1023A00014161416141614161416141614161416DD :1023B0001416143614F7F7F7F7F7F7F7F7F7F7F7F8 :1023C000F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F79D :1023D000F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F78D :1023E000F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F77D :1023F000F7971416141614F7F7F7F7F7F7F7F7F738 :10240000040604060406040604060406040604067C :10241000040604060406040604060406040604066C :10242000040604060406040604060406040604065C :10243000040604060406040604060406040604064C :10244000040604060406040604060406040604063C :10245000040604060406040604060406040604062C :10246000040604060406040604060406040604061C :10247000040604060406040604060406040604060C :1024800004060406040604060406040604060406FC :1024900004060406040604060406040604060406EC :1024A00004060406040604060406040604060406DC :1024B00004060406040604060406040604060406CC :1024C00004060406040604060406040604060406BC :1024D00004060406040604060406040604060406AC :1024E000040604060406040604060406040604069C :1024F000040604060406040604060406040604068C :10250000141614161416141614161416141614167B :10251000141614161416141614161416141614166B :10252000141614161416141614161416141614165B :10253000141614161416141614161416141614164B :10254000141614161416141614161416141614163B :10255000141614161416141614161416141614162B :10256000141614161416141614161416141614161B :10257000141614161416141614161416141614160B :1025800014161416141614161416141614161416FB :1025900014161416141614161416141614161416EB :1025A00014161416141614161416141614161416DB :1025B00014161416141614161416141614161416CB :1025C00014161416141614161416141614161416BB :1025D00014161416141614161416141614161416AB :1025E000141614161416141614161416141614169B :1025F000141614161416141614161416141614168B :10260000040604060406040604060406040604067A :10261000040604060406040604060406040604066A :10262000040604060406040604060406040604065A :10263000040604060406040604060406040604064A :10264000040604060406040604060406040604063A :10265000040604060406040604060406040604062A :10266000040604060406040604060406040604061A :10267000040604060406040604060406040604060A :1026800004060406040604060406040604060406FA :1026900004060406040604060406040604060406EA :1026A00004060406040604060406040604060406DA :1026B00004060406040604060406040604060406CA :1026C00004060406040604060406040604060406BA :1026D00004060406040604060406040604060406AA :1026E000040604060406040604060406040604069A :1026F000040604060406040604060406040604068A :102700001416141614161416141614161416141679 :102710001416141614161416141614161416141669 :102720001416141614161416141614161416141659 :102730001416141614161416141614161416141649 :102740001416141614161416141614161416141639 :102750001416141614161416141614161416141629 :102760001416141614161416141614161416141619 :102770001416141614161416141614161416141609 :1027800014161416141614161416141614161416F9 :1027900014161416141614161416141614161416E9 :1027A00014161416141614161416141614161416D9 :1027B00014161416141614161416141614161416C9 :1027C00014161416141614161416141614161416B9 :1027D00014161416141614161416141614161416A9 :1027E0001416141614161416141614161416141699 :1027F0001416141614161416141614161416141689 :102800000406040604060406040604060406040678 :102810000406040604060406040604060406040668 :102820000406040604060406040604060406040658 :102830000406040604060406040604060406040648 :102840000406040604060406040604060406040638 :102850000406040604060406040604060406040628 :102860000406040604060406040604060406040618 :102870000406040604060406040604060406040608 :1028800004060406040604060406040604060406F8 :1028900004060406040604060406040604060406E8 :1028A00004060406040604060406040604060406D8 :1028B00004060406040604060406040604060406C8 :1028C00004060406040604060406040604060406B8 :1028D00004060406040604060406040604060406A8 :1028E0000406040604060406040604060406040698 :1028F0000406040604060406040604060406040688 :102900001416141614161416141614161416141677 :102910001416141614161416141614161416141667 :102920001416141614161416141614161416141657 :102930001416141614161416141614161416141647 :102940001416141614161416141614161416141637 :102950001416141614161416141614161416141627 :102960001416141614161416141614161416141617 :102970001416141614161416141614161416141607 :1029800014161416141614161416141614161416F7 :1029900014161416141614161416141614161416E7 :1029A00014161416141614161416141614161416D7 :1029B00014161416141614161416141614161416C7 :1029C00014161416141614161416141614161416B7 :1029D00014161416141614161416141614161416A7 :1029E0001416141614161416141614161416141697 :1029F0001416141614161416141614161416141687 :102A00000406040604060406040604060406040676 :102A10000406040604060406040604060406040666 :102A20000406040604060406040604060406040656 :102A30000406040604060406040604060406040646 :102A40000406040604060406040604060406040636 :102A50000406040604060406040604060406040626 :102A60000406040604060406040604060406040616 :102A70000406040604060406040604060406040606 :102A800004060406040604060406040604060406F6 :102A900004060406040604060406040604060406E6 :102AA00004060406040604060406040604060406D6 :102AB00004060406040604060406040604060406C6 :102AC00004060406040604060406040604060406B6 :102AD00004060406040604060406040604060406A6 :102AE0000406040604060406040604060406040696 :102AF0000406040604060406040604060406040686 :102B00001416141614161416141614161416141675 :102B10001416141614161416141614161416141665 :102B20001416141614161416141614161416141655 :102B30001416141614161416141614161416141645 :102B40001416141614161416141614161416141635 :102B50001416141614161416141614161416141625 :102B60001416141614161416141614161416141615 :102B70001416141614161416141614161416141605 :102B800014161416141614161416141614161416F5 :102B900014161416141614161416141614161416E5 :102BA00014161416141614161416141614161416D5 :102BB00014161416141614161416141614161416C5 :102BC00014161416141614161416141614161416B5 :102BD00014161416141614161416141614161416A5 :102BE0001416141614161416141614161416141695 :102BF0001416141614161416141614161416141685 :102C00000406040604060406040604060406040674 :102C10000406040604060406040604060406040664 :102C20000406040604060406040604060406040654 :102C30000406040604060406040604060406040644 :102C40000406040604060406040604060406040634 :102C50000406040604060406040604060406040624 :102C60000406040604060406040604060406040614 :102C70000406040604060406040604060406040604 :102C800004060406040604060406040604060406F4 :102C900004060406040604060406040604060406E4 :102CA00004060406040604060406040604060406D4 :102CB00004060406040604060406040604060406C4 :102CC00004060406040604060406040604060406B4 :102CD00004060406040604060406040604060406A4 :102CE0000406040604060406040604060406040694 :102CF0000406040604060406040604060406040684 :102D00001416141614161416141614161416141673 :102D10001416141614161416141614161416141663 :102D20001716141614161416141614161416141650 :102D30001416141614161416141614161416141643 :102D40001416141614161416141614161416141633 :102D50001416141614161416141614161416141623 :102D60001416141614161416141614161416141613 :102D70001416141614161416141614161416141603 :102D800014161416141614161416141614161416F3 :102D900014161416141614161416141614161416E3 :102DA00014161416141614161416141614161416D3 :102DB00014161416141614161416141614161416C3 :102DC00014161416141614161416141614161416B3 :102DD00014161416141614161416141614161416A3 :102DE0001416141614161416141614161416141693 :102DF0001416141614161416141614161416141683 :102E00000406040604060406040604060406040672 :102E10000406040604060406040604060406040662 :102E20000406040604060406040604060406040652 :102E30000406040604060406040604060406040642 :102E40000406040604060406040604060406040632 :102E50000406040604060406040604060406040622 :102E60000406040604060406040604060406040612 :102E70000406040604060406040604060406040602 :102E800004060406040604060406040604060406F2 :102E900004060406040604060406040604060406E2 :102EA00004060406040604060406040604060406D2 :102EB00004060406040604060406040604060406C2 :102EC00004060406040604060406040604060406B2 :102ED00004060406040604060406040604060406A2 :102EE0000406040604060406040604060406040692 :102EF0000406040604060406040604060406040682 :102F00001416141614161416141614161416141671 :102F10001416141614161416141614161416141661 :102F20001416141614161416141614161416141651 :102F30001416141614161416141614161416141641 :102F40001416141614161416141614161416141631 :102F50001416141614161416141614161416141621 :102F60001416141614161416141614161416141611 :102F70001416141614161416141614161416141601 :102F800014161416141614161416141614161416F1 :102F900014161416141614161416141614161416E1 :102FA00014161416141614161416141614161416D1 :102FB00014161416141614161416141614161416C1 :102FC00014161416141614161416141614161416B1 :102FD00014161416141614161416141614161416A1 :102FE0001416141614161416141614161416141691 :102FF0001416141614161416141614161416141681 :10300000F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F750 :10301000F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F740 :10302000F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F730 :10303000F7F7F7F7F7F70406040604060406040694 :10304000040694F7F7F7F7F7F7F7F7F7F7F7F7F757 :10305000F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F700 :10306000F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F0 :10307000F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7E0 :10308000950604060406040604060406040604065F :1030900004060406040604060406040604060406E0 :1030A0000497F7F7F7F7F7F7F7F7F7F7F7F7F7F703 :1030B000F7F7F7F7F7F7F7F7F7F70406040604064C :1030C00004060406040604060406040604060406B0 :1030D00004060406040604060497F7F7F7F7F7F763 :1030E000F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F770 :1030F000F7F7F7F7F7F7F7F797060406040604065D :10310000141614161416141614161416141614166F :10311000141614161416141614F614F7F7F7F7F716 :10312000F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F72F :10313000F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F71F :10314000F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F70F :10315000F7F7F7F7F7F7F796141614161416141670 :10316000141614161416141614161416141614160F :10317000141614161416141614F697F7F7F7F7F733 :10318000F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7CF :10319000F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7BF :1031A000F7161416141614161416141614161416EC :1031B00014161416143614F614F7F7F7F7F7F7F792 :1031C000F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F78F :1031D000F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F77F :1031E000F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F76F :1031F000F7F7F7F794161416141614161416141677 :1032000004060406F7F7F7F7F7F7F7F7F7F7F7F716 :10321000F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F73E :10322000F7F7F7F7F7F7F7F7F7F7F7F7F797040672 :103230000406040604060406040604060406F7F75A :10324000F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F70E :10325000F7F7F7F7F7F7F7970406040604060406EE :10326000040604060406040604060406040604060E :1032700004060406040604060406F7F7F7F7F7F752 :10328000F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7CE :10329000F7F7F5F5F7F7F7F7F7F7F7F7F7F7F7F7C2 :1032A000F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7AE :1032B000F7F7F7F7F7970406040604060406040672 :1032C00004060406040604060406040604060406AE :1032D00004060406040697F7F7F7F7F7F7F7F7F78A :1032E000F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F76E :1032F000F7F7F7F7F7F7F7F795060406040604065D :10330000141614161416141614161416141614166D :103310001416141614161416143614F6F7F7F7F7D5 :10332000F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F72D :10333000F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F71D :10334000F7F7F7F7F7F7F7F7F7F7F7F7F7F71416D1 :10335000143614F7F7F7F7F7F7F7F7F7F7F7F7F784 :10336000F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7ED :10337000F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7DD :10338000F7F7F7F7F7F7F7F7F7F7F7F7F7F7D716CE :1033900014161416143614F695F7F7F7F7F7F7F72F :1033A000F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7AD :1033B000F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F79D :1033C000F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F78D :1033D000F7F7F7F7F79714161416141614161416B1 :1033E000141614161416141614161416141614168D :1033F0001416143614F697F7F7F7F7F7F7F7F7F709 :10340000040604060406040604060406040604066C :10341000040604060406040604060406040604065C :10342000040604060406040604060406040604064C :10343000040604060406040604060406040604063C :10344000040604060406040604060406040604062C :10345000040604060406040604060406040604061C :10346000040604060406040604060406040604060C :1034700004060406040604060406040604060406FC :1034800004060406040604060406040604060406EC :1034900004060406040604060406040604060406DC :1034A00004060406040604060406040604060406CC :1034B00004060406040604060406040604060406BC :1034C00004060406040604060406040604060406AC :1034D000040604060406040604060406040604069C :1034E000040604060406040604060406040604068C :1034F000040604060406040604060406040604067C :10350000141614161416141614161416141614166B :10351000141614161416141614161416141614165B :10352000141614161416141614161416141614164B :10353000141614161416141614161416141614163B :10354000141614161416141614161416141614162B :10355000141614161416141614161416141614161B :10356000141614161416141614161416141614160B :1035700014161416141614161416141614161416FB :1035800014161416141614161416141614161416EB :1035900014161416141614161416141614161416DB :1035A00014161416141614161416141614161416CB :1035B00014161416141614161416141614161416BB :1035C00014161416141614161416141614161416AB :1035D000141614161416141614161416141614169B :1035E000141614161416141614161416141614168B :1035F000141614161416141614161416141614167B :10360000040604060406040604060406040604066A :10361000040604060406040604060406040604065A :10362000040604060406040604060406040604064A :10363000040604060406040604060406040604063A :10364000040604060406040604060406040604062A :10365000040604060406040604060406040604061A :10366000040604060406040604060406040604060A :1036700004060406040604060406040604060406FA :1036800004060406040604060406040604060406EA :1036900004060406040604060406040604060406DA :1036A00004060406040604060406040604060406CA :1036B00004060406040604060406040604060406BA :1036C00004060406040604060406040604060406AA :1036D000040604060406040604060406040604069A :1036E000040604060406040604060406040604068A :1036F000040604060406040604060406040604067A :103700001416141614161416141614161416141669 :103710001416141614161416141614161416141659 :103720001416141614161416141614161416141649 :103730001416141614161416141614161416141639 :103740001416141614161416141614161416141629 :103750001416141614161416141614161416141619 :103760001416141614161416141614161416141609 :1037700014161416141614161416141614161416F9 :1037800014161416141614161416141614161416E9 :1037900014161416141614161416141614161416D9 :1037A00014161416141614161416141614161416C9 :1037B00014161416141614161416141614161416B9 :1037C00014161416141614161416141614161416A9 :1037D0001416141614161416141614161416141699 :1037E0001416141614161416141614161416141689 :1037F0001416141614161416141614161416141679 :103800000406040604060406040604060406040668 :103810000406040604060406040604060406040658 :103820000406040604060406040604060406040648 :103830000406040604060406040604060406040638 :103840000406040604060406040604060406040628 :103850000406040604060406040604060406040618 :103860000406040604060406040604060406040608 :1038700004060406040604060406040604060406F8 :1038800004060406040604060406040604060406E8 :1038900004060406040604060406040604060406D8 :1038A00004060406040604060406040604060406C8 :1038B00004060406040604060406040604060406B8 :1038C00004060406040604060406040604060406A8 :1038D0000406040604060406040604060406040698 :1038E0000406040604060406040604060406040688 :1038F0000406040604060406040604060406040678 :103900001416141614161416141614161416141667 :103910001416141614161416141614161416141657 :103920001416141614161416141614161416141647 :103930001416141614161416141614161416141637 :103940001416141614161416141614161416141627 :103950001416141614161416141614161416141617 :103960001416141614161416141614161416141607 :1039700014161416141614161416141614161416F7 :1039800014161416141614161416141614161416E7 :1039900014161416141614161416141614161416D7 :1039A00014161416141614161416141614161416C7 :1039B00014161416141614161416141614161416B7 :1039C00014161416141614161416141614161416A7 :1039D0001416141614161416141614161416141697 :1039E0001416141614161416141614161416141687 :1039F0001416141614161416141614161416141677 :103A00000406040604060406040604060406040666 :103A10000406040604060406040604060406040656 :103A20000406040604060406040604060406040646 :103A30000406040604060406040604060406040636 :103A40000406040604060406040604060406040626 :103A50000406040604060406040604060E0606060A :103A60000406040604060406040604060406040606 :103A700004060406040604060406040604060406F6 :103A800004060406040604060406040604060406E6 :103A900004060406040604060406040604060406D6 :103AA00004060406040604060406040604060406C6 :103AB00004070406040604060406040604060406B5 :103AC00004060406040604060406040604060406A6 :103AD0000406040604060406040604060406040696 :103AE0000406040604060406040604060406040686 :103AF0000406040604060406040604060406040676 :103B00001416141614161416141614161416141665 :103B10001416141614161416141614161416141655 :103B20001416141614161416141614161416141645 :103B30001416141614161416141614161416141635 :103B40001416141614161416141614161416141625 :103B50001416141614161416141614161416141615 :103B60001416141614161416141614161416141605 :103B700014161416141614161416141614161416F5 :103B800014161416141614161416141614161416E5 :103B900014161416141614161416141614161416D5 :103BA00014161416141614161416141614161416C5 :103BB00014161416141614161416141614161416B5 :103BC0003616141614161416141614161416141683 :103BD0001416141614161416141614161416141695 :103BE0001416141614161416141614161416141685 :103BF0001416141614161416141614161416141675 :103C00000406040604060406040604060406040664 :103C10000406040604060406040604060406040654 :103C20000406040604060406040604060406040644 :103C30000406040604060406040604060406040634 :103C40000406040604060406040604060406040624 :103C50000406040604060406040604060406040614 :103C60000406040604060406040604060406040604 :103C700004060406040604060406040604060406F4 :103C800004060406040604060406040604060406E4 :103C900004060406040604060406040604060406D4 :103CA00004060406040604060406040604060406C4 :103CB00004060406040604060406040604060406B4 :103CC00004060406040604060406040604060406A4 :103CD0000406040604060406040604060406040694 :103CE0000406040604060406040604060406040684 :103CF0000406040604060406040604060406040674 :103D00001416141614161416141614161416141663 :103D10001416141614161416141614161416141653 :103D20001416141614161416141614161416141643 :103D30001416141614161416141614161416141633 :103D40001416141614161416141614161416141623 :103D50001416141614161416141614161416141613 :103D60001416141614161416141614161416141603 :103D700014161416141614161416141614161416F3 :103D800014161416141614161416141614161416E3 :103D900014161416141614161416141614161416D3 :103DA00014161416141614161416141614161416C3 :103DB00014161416141614161416141614161416B3 :103DC00014161416141614161416141614161416A3 :103DD0001416141614161416141614161416141693 :103DE0001416141614161416141614161416141683 :103DF0001416141614161416141614161416141673 :103E00000406040604060406040604060406040662 :103E10000406040604060406040604060406040652 :103E20000406040604060406040604060406040642 :103E30000406040604060406040604060406040632 :103E40000406040604060406040604060406040622 :103E50000406040604060406040604060406040612 :103E60000406040604060406040604060406040602 :103E700004060406040604060406040604060406F2 :103E800004060406040604060406040604060406E2 :103E900004060406040604060406040604060406D2 :103EA00004060406040604060406040604060406C2 :103EB00004060406040604060406040604060406B2 :103EC00004060406040604060406040604060406A2 :103ED0000406040604060406040604060406040692 :103EE0000406040604060406040604060406040682 :103EF0000406040604060406040604060406040672 :103F00001416141614161416141614161416141661 :103F10001416141614161416141614161416141651 :103F20001416141614161416141614161416141641 :103F30001416141614161416141614161416141631 :103F40001416141614161416141614161416141621 :103F50001416141614161416141614161416141611 :103F60001416141614161416141614161416141601 :103F700014161416141614161416141614161416F1 :103F800014161416141614161416141614161416E1 :103F900014161416141614161416141614161416D1 :103FA00014161416141614161416141614161416C1 :103FB00014161416141614161416141614161416B1 :103FC00014161416141614161416141614161416A1 :103FD0001416141614161416141614161416141691 :103FE0001416141614161416141614161416141681 :103FF0001416141614161416141614161416141671 :10400000F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F740 :10401000F70604060406040604060406040604065D :104020000406040604060406040697F7F7F7F7F7F4 :10403000F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F710 :10404000F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F700 :10405000F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F0 :10406000F7F7F7F7F7F7F7D7040604060406040690 :1040700004060406040604060406040604060406F0 :1040800004060406040604060497F7F7F7F7F7F7A3 :10409000F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7B0 :1040A000F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7A0 :1040B000F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F790 :1040C000F7F7F7F7F7960406040604060406040655 :1040D0000406040604060406040604060406040690 :1040E000040604060406040604F7F7F7F7F7F7F7E3 :1040F000F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F750 :10410000F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F73F :10411000F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F72F :10412000F7F7F7F7F7F79516141614161416141672 :10413000141614161416141614161416141614162F :1041400014161416141614F694F7F7F7F7F7F7F792 :10415000F7F7F7F7F7F7F7F7F7F7F7F795161416F6 :1041600014161416141614161416141614161416FF :10417000141614161416141614161416143614F7EE :10418000F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7BF :10419000F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7AF :1041A000F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F79F :1041B000F7F7F7F7F7F7F7F7F7F797161416141658 :1041C000141614161416141614161416141614169F :1041D00014161416141614161416147614F7F7F78A :1041E000F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F75F :1041F000F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F74F :10420000F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F73E :10421000F7F7F7F7F7F7F7F7F7960406040604063B :10422000040604060406040604060406040604063E :10423000040604060406040604060406F7F7F7F766 :10424000F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7FE :10425000F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7EE :10426000F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7DE :10427000F7F7F7F7F7F7F7F79506040604060406CD :1042800004060406040604060406040604060406DE :10429000040604060406040604F7F7F7F7F7F7F731 :1042A000F7F7F7F7F7F7F7F7F7F7F7F7F7970406E2 :1042B00004060406040604060406040604060406AE :1042C000040604060406040604060406040604069E :1042D00094F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7D1 :1042E000F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F75E :1042F000F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F74E :10430000F7F7F7F7F7F7F7F7F7F7F7F7F797141661 :10431000141614161416141614161416141614164D :1043200014161416141614161416141614F614F77C :10433000F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F70D :10434000F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7FD :10435000F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7ED :10436000F7F7F7F7F7F7F7F7F7F7971614161416A6 :1043700014161416F7F7F7F7F7F7F7F7F7F7F7F755 :10438000F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7BD :10439000F7F7F7F7F7F71416141614161416141681 :1043A00014161416141614161416141614161416BD :1043B0001416141614F614F7F7F7F7F7F7F7F7F7DC :1043C000F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F77D :1043D000F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F76D :1043E000F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F75D :1043F000F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F74D :10440000040604060406040604060406040604065C :10441000040604060406040604060406040604064C :10442000040604060406040604060406040604063C :10443000040604060406040604060406040604062C :10444000040604060406040604060406040604061C :10445000040604060406040604060406040604060C :1044600004060406040604060406040604060406FC :1044700004060406040604060406040604060406EC :1044800004060406040604060406040604060406DC :1044900004060406040604060406040604060406CC :1044A00004060406040604060406040604060406BC :1044B00004060406040604060406040604060406AC :1044C000040604060406040604060406040604069C :1044D000040604060406040604060406040604068C :1044E000040604060406040604060406040604067C :1044F000040604060406040604060406040604066C :10450000141614161416141614161416141614165B :10451000141614161416141614161416141614164B :10452000141614161416141614161416141614163B :10453000141614161416141614161416141614162B :10454000141614161416141614161416141614161B :10455000141614161416141614161416141614160B :1045600014161416141614161416141614161416FB :1045700014161416141614161416141614161416EB :1045800014161416141614161416141614161416DB :1045900014161416141614161416141614161416CB :1045A00014161416141614161416141614161416BB :1045B00014161416141614161416141614161416AB :1045C000141614161416141614161416141614169B :1045D000141614161416141614161416141614168B :1045E000141614161416141614161416141614167B :1045F000141614161416141614161416141614166B :10460000040604060406040604060406040604065A :10461000040604060406040604060406040604064A :10462000040604060406040604060406040604063A :10463000040604060406040604060406040604062A :10464000040604060406040604060406040604061A :10465000040604060406040604060406040604060A :1046600004060406040604060406040604060406FA :1046700004060406040604060406040604060406EA :1046800004060406040604060406040604060406DA :1046900004060406040604060406040604060406CA :1046A00004060406040604060406040604060406BA :1046B00004060406040604060406040604060406AA :1046C000040604060406040604060406040604069A :1046D000040604060406040604060406040604068A :1046E000040604060406040604060406040604067A :1046F000040604060406040604060406040604066A :104700001416141614161416141614161416141659 :104710001416141614161416141614161416141649 :104720001416141614161416141614161416141639 :104730001416141614161416141614161416141629 :104740001416141614161416141614161416141619 :104750001416141614161416141614161416141609 :1047600014161417141614161416141614161416F8 :1047700014161416141614161416141614161416E9 :1047800014161416141614161416141614161416D9 :1047900014161416141614161416141614161416C9 :1047A00014161416141614161416141614161416B9 :1047B00014161416141614161416141614161416A9 :1047C0001416141614161416141614161416141699 :1047D0001416141614161416141614161416141689 :1047E0001416141614161616141614161416141677 :1047F0001416141614161416141614161416141669 :104800000406040604060406040604060406040658 :104810000406040604060406040604060406040648 :104820000406040604060406040604060406040638 :104830000406040604060406040604060406040628 :104840000406040604060406040604060406040618 :104850000406040604060406040604060406040608 :1048600004060406040604060406040604060406F8 :1048700004060406040604060406040604060406E8 :1048800004060406040604060406040604060406D8 :1048900004060406040604060406040604060406C8 :1048A00004060406040604060406040604060406B8 :1048B00004060406040604060406040604060406A8 :1048C0000406040604060406040604060406040698 :1048D0000406040604060406040604060406040688 :1048E0000406040604060406040604060406040678 :1048F0000406040604060406040604060406040668 :104900001416141614161416141614161416141657 :104910001416141614161416141614161416141647 :104920001416141614161416141614161416141637 :104930001416141614161416141614161416141627 :104940001416141614161416141614161416141617 :104950001416141614161416141614161416141607 :1049600014161416141614161416141614161416F7 :1049700014161416141614161416141614161416E7 :1049800014161416141614161416141614161416D7 :1049900014161416141614161416141614161416C7 :1049A00014161416141614161416141614161416B7 :1049B00014161416141614161416141614161416A7 :1049C0001416141614161416141614161416141697 :1049D0001416141614161416141614161416141687 :1049E0001416141614161416141614161416141677 :1049F0001416141614161416141614161416141667 :104A00000406040604060406040604060406040656 :104A10000406040604060406040604060406040646 :104A20000406040604060406040604060406040636 :104A30000406040604060406040604060406040626 :104A40000406040604060406040604060406040616 :104A50000406040604060406040604060406040606 :104A600004060406040604060406040604060406F6 :104A700004060406040604060406040604060406E6 :104A800004060406040604060406040604060406D6 :104A900004060406040604060406040604060406C6 :104AA00004060406040604060406040604060406B6 :104AB00004060406040604060406040604060406A6 :104AC0000406040604060406040604060406040696 :104AD0000406040604060406040604060406040686 :104AE0000406040604060406040604060406040676 :104AF0000406040604060406040604060406040666 :104B00001416141614161416141614161416141655 :104B10001416141614161416141614161416141645 :104B20001416141614161416141614161416141635 :104B30001416141614161416141614161416141625 :104B40001416141614161416141614161416141615 :104B50001416141614161416141614161416141605 :104B600014161416141614161416141614161416F5 :104B700014161416141614161416141614161416E5 :104B800014161416141614161416141614161416D5 :104B900014161416141614161416141614161416C5 :104BA00014161416141614161416141614161416B5 :104BB00014161416141614161416141614161416A5 :104BC0001416141614161416141614161416141695 :104BD0001416141614161416141614161416141685 :104BE0001416141614161416141614161416141675 :104BF0001416141614161416141614161416141665 :104C00000406040604060406040604060406040654 :104C10000406040604060406040604060406040644 :104C20000406040604060406040604060406040634 :104C30000406040604060406040604060406040624 :104C40000406040604060406040604060406040614 :104C50000406040604060406040604060406040604 :104C600004060406040604060406040604060406F4 :104C700004060406040604060406040604060406E4 :104C800004060406040604060406040604060406D4 :104C900004060406040604060406040604060406C4 :104CA00004060406040604060406040604060406B4 :104CB00004060406040604060406040604060406A4 :104CC0000406040604060406040604060406040694 :104CD0000406040604060406040604060406040684 :104CE0000406040604060406040604060406040674 :104CF0000406040604060406040604060406040664 :104D00001416141614161416141614161416141653 :104D10001416141614161416141614161416141643 :104D20001416141614161416141614161416141633 :104D30001416141614161416141614161416141623 :104D40001416141614161416141614161416141613 :104D50001416141614161416141614161416141603 :104D600014161416141614161416141614161416F3 :104D700014161416141614161416141614161416E3 :104D800014161416141614161416141614161416D3 :104D900014161416141614161416141614161416C3 :104DA00014161416141614161416141614161416B3 :104DB00014161416141614161416141614161416A3 :104DC0001416141614161416141614161416141693 :104DD0001416141614161416141614161416141683 :104DE0001416141614161416141614161416141673 :104DF0001416141614161416141614161416141663 :104E00000406040604060406040604060406040652 :104E10000406040604060406040604060406040642 :104E20000406040604060406040604060406040632 :104E30000406040604060406040604060406060620 :104E4000040604060406060604060606040604060E :104E50000406040604060406040604060406040602 :104E600004060406040604060406040604060406F2 :104E700004060406040604060406040604060406E2 :104E800004060406040604060406040604060406D2 :104E900004060406040604060406040604060406C2 :104EA00004060406040604060406040604060406B2 :104EB00004060406040604060406040604060406A2 :104EC0000406040604060406040604060406040692 :104ED0000406040604060406040604060406040682 :104EE0000406040604060406040604060406040672 :104EF0000406040604060406040604060406040662 :104F00001416141614161416141614161416141651 :104F10001416141614161416141614161416141641 :104F20001416141614161416141614161416141631 :104F30001416141614161416141614161416141621 :104F40001416141614161416141614161416141611 :104F50001416141614161416141614161416141601 :104F600014161416141614161416141614161416F1 :104F700014161416141614161416141614161416E1 :104F800014161416141614161416141614161416D1 :104F900014161416141614161416141614161416C1 :104FA00014161416141614161416141614161416B1 :104FB00014161416141614161416141614161416A1 :104FC0001416141614161416141614161416141691 :104FD0001416141614161416141614161416141681 :104FE0001416141614161416141614161416141671 :104FF0001416141614161416141614161416141661 :10500000F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F730 :10501000F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F720 :10502000F7F7F7F7F7F7F7F7F7F7F7F7F7F7950663 :105030000406040604060406040604060406040620 :10504000040604060406040604060406040604977F :10505000F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7E0 :10506000F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7D0 :10507000F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7C0 :10508000F7F7F7F7F7F7F7F7F7F7950604060406CB :10509000040604060406040604060406F7F7F7F7F8 :1050A000F7F7F79604060406040604060406040649 :1050B0000406F7F7F7F7F7F7F7F7F7F7F7F7F7F764 :1050C000F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F770 :1050D000F7F7F7F7F7F79706040604060406040641 :1050E0000406040604060406040604060406040670 :1050F00004060406040604060406F7F7F7F7F7F7B4 :10510000F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F72F :10511000F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F71F :10512000F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F70F :10513000F7F7F7F7F7971416141614161416141633 :10514000141614161416141614161416141614160F :1051500014161416147614F7F7F7F7F7F7F7F7F7AE :10516000F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7CF :10517000F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7BF :10518000F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7AF :10519000971614161416141614161416141614163C :1051A00014161416141614161416141614161416AF :1051B000147614F7F7F7F7F7F7F7F7F7F7F7F7F7C6 :1051C000F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F76F :1051D000F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F75F :1051E000F7F7F7F7F7F7F7F7F7F7F7F7F7F7F797AF :1051F000141614161416141614161416F7F7F7F7D7 :10520000F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F72E :10521000F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F71E :10522000F7F7F7F7F79704060406040604060406E2 :10523000040604060406040604060406040604061E :1052400004060406040604F7F7F7F7F7F7F7F7F78D :10525000F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7DE :10526000F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7CE :10527000F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7BE :10528000F7F71406040604060406040604060406DA :1052900004060406040604060406040604060406BE :1052A000040697F7F7F7F7F7F7F7F7F7F7F7F7F7D2 :1052B000F7F7F7F7F7F7F7F7F7F7F7F7D706040673 :1052C000040604060406040604060406040604068E :1052D000040604060406040604060406040604F78D :1052E000F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F74E :1052F000F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F73E :10530000F7F7F79714161416141614161416141625 :10531000141614161416141614161416141614163D :10532000141614F614F7F7F7F7F7F7F7F7F7F7F798 :10533000F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7FD :10534000F7F7F7F7F7F714161416141614161436A1 :1053500014F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7C0 :10536000F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7CD :10537000F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7BD :10538000F7F7F7F7F7F7F7F7F7F7F7F71416141635 :1053900014161416141614161416141614161416BD :1053A0001416141614161416143614F6F7F7F7F725 :1053B000F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F77D :1053C000F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F76D :1053D000F7F7F7F7F7F7F7F7F7F7F7F7F7F797169E :1053E000141614161416141614161416141614166D :1053F000141614161416141614161416141614F67D :105400000406040604060406040607060406040649 :10541000040604060406040604060406040604063C :10542000040604060406040604060406040604062C :10543000040604060406040604060406040604061C :10544000040604060406040604060406040604060C :1054500004060406040604060406040604060406FC :1054600004060406040604060406040604060406EC :1054700004060406040604060406040604060406DC :1054800004060406040604060406040604060406CC :1054900004060406040604060406040604060406BC :1054A00004060406040604060406040604060406AC :1054B000040604060406040604060406040604069C :1054C000040604060406040604060406040604068C :1054D000040604060406040604060406040604067C :1054E000040604060406040604060406040604066C :1054F000040604060406040604060406040604065C :10550000141614161416141614161416141614164B :10551000141614161416141614161416141614163B :10552000141614161416141614161416141614162B :10553000141614161416141614161416141614161B :105540001416141614161416141614161416161609 :1055500014161416141614161416141614161416FB :1055600014161416141614161416141614161416EB :1055700014161416141614161416141614161416DB :1055800014161416141614161416141614161416CB :1055900014161416141614161416141614161416BB :1055A00014161416141614161416141614161416AB :1055B000141614161416141614161417141614169A :1055C000141614161416141614161416141614168B :1055D000141614161416141614161416141614167B :1055E000141614161416141614161416141614166B :1055F000141614161416141614161416141614165B :105600000406060604060406040604060406040648 :10561000040604060406040604060406040604063A :10562000040604060406040604060406040604062A :10563000040604060406040604060406040604061A :10564000040604060406040604060406040604060A :1056500004060406040604060406040604060406FA :1056600004060406040604060406040604060406EA :1056700004060406040604060406040604060406DA :1056800004060406040604060406040604060406CA :1056900004060406040604060406040604060406BA :1056A00004060406040604060406040604060406AA :1056B000040604060406040604060406040604069A :1056C000040604060406040604060406040604068A :1056D000040604060406040604060406040604067A :1056E0000406040604060606040606060406040666 :1056F000040604060406040604060406040604065A :105700001416141614161416141614161416141649 :105710001416141614161416141614161416141639 :105720001416141614161416141614161416141629 :105730001416141614161416141614161416141619 :105740001416141614161416141614161416141609 :1057500014161416141614161416141614161416F9 :1057600014161416141614161416141614161416E9 :1057700014161416141614161416141614161416D9 :1057800014161416141614161416141614161416C9 :1057900014161416141614161416141614161416B9 :1057A00014161416141614161416141614161416A9 :1057B0001416141614161416141614161416141699 :1057C0001416141614161416141614161416141689 :1057D0001416141614161416141614161416141679 :1057E0001416141614161416141614161416141669 :1057F0001416141614161416141614161416141659 :105800000406040604060406040604060406040648 :105810000406040604060406040604060406040638 :105820000406040604060406040604060406040628 :105830000406040604060406040604060406040618 :105840000406040604060406040604060406040608 :1058500004060406040604060406040604060406F8 :1058600004060406040604060406040604060406E8 :1058700004060406040604060406040604060406D8 :1058800004060406040604060406040604060406C8 :1058900004060406040604060406040604060406B8 :1058A00004060406040604060406040604060406A8 :1058B0000406040604060406040604060406040698 :1058C0000406040604060406040604060406040688 :1058D0000406040604060406040604060406040678 :1058E0000406040604060406040604060406040668 :1058F0000406040604060406040604060406040658 :105900001416141614161416141614161416141647 :105910001416141614161416141614161416141637 :105920001416141614161416141614161416141627 :105930001416141614161416141614161416141617 :105940001416141614161416141614161416141607 :1059500014161416141614161416141614161416F7 :1059600014161416141614161416141614161416E7 :1059700014161416141614161416141614161416D7 :1059800014161416141614161416141614161416C7 :1059900014161416141614161416141614161416B7 :1059A00014161416141614161416141614161416A7 :1059B0001416141614161416141614161416141697 :1059C0001416141614161416141614161416141687 :1059D0001416141614161416141614161416141677 :1059E0001416141614161416141614161416141667 :1059F0001416141614161416141614161416141657 :105A00000406040604060406040604060406040646 :105A10000406040604060406040604060406040636 :105A20000406040604060406040604060406040626 :105A30000406040604060406040604060406040616 :105A40000406040604060406040604060406040606 :105A500004060406040604060406040604060406F6 :105A600004060406040604060406040604060406E6 :105A700004060406040604060406040604060406D6 :105A800004060406040604060406040604060406C6 :105A900004060406040604060406040604060406B6 :105AA00004060406040604060406040604060406A6 :105AB0000406040604060406040604060406040696 :105AC0000406040604060406040604060406040686 :105AD0000406040604060406040604060406040676 :105AE0000406040604060406040604060406040666 :105AF0000406040604060406040604060406040656 :105B00001416141614161416141614161416141645 :105B10001416141614163F1614161416141614160A :105B20001416141614161416141614161416141625 :105B30001416141614161416141614161416141615 :105B40001416141614161416141614161416141605 :105B500014161416141614161416141614161416F5 :105B600014161416141614161416141614161416E5 :105B700014161416141614161416141614161416D5 :105B800014161416141614161416141614161416C5 :105B900014161416141614161416141614161416B5 :105BA00014161416141614161416141614161416A5 :105BB0001416141614161416141614161416141695 :105BC0001416141614161416141614161416141685 :105BD0001416141614161416141614161416141675 :105BE0001416141614161416141614161416141665 :105BF0001416141614161416141614161416141655 :105C00000406040604060406040604060406040644 :105C10000406040604060406040604060406040634 :105C20000406040604060406040604060406040624 :105C30000406040604060406040604060406040614 :105C40000406040604060406040604060406040604 :105C500004060406040604060406040604060406F4 :105C600004060406040604060406040604060406E4 :105C700004060406040604060406040604060406D4 :105C800004060406040604060406040604060406C4 :105C900004060406040604060406040604060406B4 :105CA00004060406040604060406040604060406A4 :105CB0000406040604060406040604060406040694 :105CC0000406040604060406040604060406040684 :105CD0000406040604060406060604060406040672 :105CE0000406040604060406040604060406040664 :105CF0000406040604060406040604060406040654 :105D00001416141614161416141614161416141643 :105D10001416141614161416141614161416141633 :105D20001416141614161416141614161416141623 :105D30001416141614161416141614161416141613 :105D40001416141614161416141614161416141603 :105D500014161416141614161416141614161416F3 :105D600014161416141614161416141614161416E3 :105D700014161416141614161416141614161416D3 :105D800014161416141614161416141614161416C3 :105D900014161416141614161416141614161416B3 :105DA00014161416141614161416141614161416A3 :105DB0001416141614161416141614161416141693 :105DC0001416141614161416141614171416141682 :105DD0001416141614161416141614161416141673 :105DE0001416141614161416141614161416141663 :105DF0001416141614161416141614161416141653 :105E00000406040604060406040604060406040642 :105E10000406040604060406040604060406040632 :105E20000406040604060406040604060406040622 :105E30000406040604060406040604060406040612 :105E40000406040604060406040604060406040602 :105E500004060406040604060406040604060406F2 :105E600004060406040604060406040604060406E2 :105E700004060406040604060406040604060406D2 :105E800004060406040604060406040604060406C2 :105E900004060406040604060406040604060406B2 :105EA00004060406040604060406040604060406A2 :105EB0000406040604060406040604060406040692 :105EC0000406040604060406040604060406040682 :105ED0000406040604060406040604060406040672 :105EE0000406040604060406040604060406040662 :105EF0000406040604060406040604060406040652 :105F00001416141614161416141614161416141641 :105F10001416141614161416141614161416141631 :105F20001416141614161416141614161416141621 :105F30001416141614161416141614161416141611 :105F40001416141614161416141614161416141601 :105F500014161416141614161416141614161416F1 :105F600014161416141614161416141614161416E1 :105F700014161416141614161416141614161416D1 :105F800014161416141614161416141614161416C1 :105F900014161416141614161416141614161416B1 :105FA00014161416141614161416141614161416A1 :105FB0001416141614161416141614161416141691 :105FC0001416141614161416141614161416141681 :105FD0001416141614161416141614161416141671 :105FE0001416141614161416141614161416141661 :105FF0001416141614161416141614161416141651 :10600000F7F7F7F7F7F7F7F7F706040604060406BD :10601000040604060406040604060406040604979F :10602000F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F700 :10603000F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F0 :10604000F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7E0 :10605000F7F7F7F7F7F7F7F7F7F7F79604060406F9 :1060600004060406040604060406040604060406E0 :106070000406040604060406040604060406F7F7EC :10608000F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7A0 :10609000F7F7F7F7F7F7F7D7F7F7F7F7F7F7F7F7B0 :1060A000F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F780 :1060B000F7F7F7F7F7F7F7F7F7F7F7970406040698 :1060C0000406040604060406040604060406040680 :1060D00004060406040604060406040604F7F7F79B :1060E000F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F740 :1060F000F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F730 :10610000F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F71F :10611000F7F7F7F7F7F7F7F7F797141614161416BB :10612000141614161416141614161416141614161F :1061300014161416141614161416147614F7F7F70A :10614000F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7DF :10615000F7F7F71614161416141614161416141648 :1061600014161416141614161416141614161416DF :106170001416143697F7F7F7F7F7F7F7F7F7F7F777 :10618000F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F79F :10619000F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F78F :1061A000F7F7F7F7F7F7D7D7F7F7F7F7F7F7F7F7BF :1061B000F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F76F :1061C000F7F7F7F7F7F7F7F79516141614161416EE :1061D000141614161416141614161416141614166F :1061E000141614161416143614F7F7F7F7F7F7F712 :1061F000F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F72F :10620000F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F71E :10621000F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F70E :10622000F7F7F7F7F7F70406040604060406040672 :10623000040604060406040604060406040604060E :106240000406040604060406D7F7F7F7F7F7F7F78E :10625000F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7CE :10626000F7F7F7F7F7F7D7D7F7F7F7F7F7F7F7F7FE :10627000F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7AE :10628000F7F7F7F797060406040604060406040663 :1062900004060406040604060406040604F7F7F7D9 :1062A000F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F77E :1062B000F7F7F7F7F7F7F7D704060406040604061E :1062C000040604060406040604060406040604067E :1062D00004060406040604060406F7F7F7F7F7F7C2 :1062E000F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F73E :1062F000F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F72E :10630000F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F71D :10631000F7F7F7F7F7F7F79714161416141614167D :10632000141614161416141614161416141614161D :10633000141614161416147614F7F7F7F7F7F7F780 :10634000F7F7F7F7F7F7F7F7F7F7F7F7B7B7F7F75D :10635000F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7CD :10636000F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7BD :10637000F7F7F7F7951614161416141614161416C4 :1063800014161416141614161416141614161416BD :1063900014161416147614F7F7F7F7F7F7F7F7F75C :1063A000F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F77D :1063B000F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F76D :1063C000F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F75D :1063D000F7F7F7F7941614161416141614F7F7F7C0 :1063E000F7F7F7F7F7F7F7F7F7F714161416141689 :1063F000141614161416141614161416141614164D :10640000040604060406040604060406040604063C :10641000040604060406040604060406040604062C :10642000040604060406040604060406040604061C :10643000040604060406040604060406040604060C :1064400004060406040604060406040604060406FC :1064500004060406040604060406040604060406EC :1064600004060406040604060406040604060406DC :1064700004060406040604060406040604060406CC :1064800004060406040604060406040604060406BC :1064900004060406040604060406040604060406AC :1064A000040604060406040604060406040604069C :1064B000040604060406040604060406040604068C :1064C000040604060406040604060406040604067C :1064D000040604060406040604060406040604066C :1064E000040604060406040604060406040604065C :1064F000040604060406040604060406040604064C :10650000141614161416141614161416141614163B :10651000141614161416141614161416141614162B :10652000141614161416141614161416141614161B :10653000141614161416141614161416141614160B :1065400014161416141614161416141614161416FB :1065500014161416141614161416141614161416EB :1065600014161416141614161416141614161416DB :1065700014161416141614161416141614161416CB :1065800014161416141614161416141614161416BB :1065900014161416141614161416141614161416AB :1065A000141614161416141614161416141614169B :1065B000141614161416141614161416141614168B :1065C000141614161416141614161416141614167B :1065D000141614161416141614161416141614166B :1065E000141614161416141614161416141614165B :1065F000141614161416141614161416141614164B :10660000040604060406040604060406040604063A :10661000040604060406040604060406040604062A :10662000040604060406040604060406040604061A :10663000040604060406040604060406040604060A :1066400004060406040604060406040604060406FA :1066500004060406040604060406040604060406EA :1066600004060406040604060406040604060406DA :1066700004060406040604060406040604060406CA :1066800004060406040604060406040604060406BA :1066900004060406040604060406040604060406AA :1066A000040604060406040604060406040604069A :1066B000040604060406040604060406040604068A :1066C000040604060406040604060406040604067A :1066D000040604060406040604060406040604066A :1066E000040604060406040604060406040604065A :1066F000040604060406040604060406040604064A :106700001416141614161416141614161416141639 :106710001416141614161416141614161416141629 :106720001416141614161416141614161416141619 :106730001416141614161416141614161416141609 :1067400014161416141614161416141614161416F9 :1067500014161416141614161416141614161416E9 :1067600014161416141614161416141614161416D9 :1067700014161416141614161416141614161416C9 :1067800014161416141614161416141614161416B9 :1067900014161416141614161416141614161416A9 :1067A0001416141614161416141714161416141698 :1067B0001416141614161416141614161416141689 :1067C0001416141614161416141614161416141679 :1067D0001416141614161416141614161416141669 :1067E0001416141614161416141614161416141659 :1067F0001416141714161416141614161416141648 :106800000406040604060406040604060406040638 :106810000406040604060406040604060406040628 :106820000406040604060406040604060406040618 :106830000406040604060406040604060406040608 :1068400004060406040604060406040604060406F8 :1068500004060406040604060406040604060406E8 :1068600004060406070604060406040604060406D5 :1068700004060406040604060406040604060406C8 :1068800004060406040604060406040604060406B8 :1068900004060406040604060406040604060406A8 :1068A0000406040604060406040604060406040698 :1068B0000406040604060406040604060406040688 :1068C0000406040604060406040604060406040678 :1068D0000406040604060406040604060406040668 :1068E0000406040604060406040604060406040658 :1068F0000406040604060406040604060406040648 :106900001416141614161416141614161416141637 :106910001416141614161416141614161416141627 :106920001416141614161416141614161416141617 :106930001416141614161416141614161416141607 :1069400014161416141614161416141614161416F7 :1069500014161416141614161416141614161416E7 :1069600014161416141614161416141614161416D7 :1069700014161416141614161416141614161416C7 :1069800014161416141614161416141614161416B7 :1069900014161416141614161416141614161416A7 :1069A0001416141614161416141614161416141697 :1069B0001416141614161416141614161416141687 :1069C0001416141614161416141614161416141677 :1069D0001416141614161416141614161416141667 :1069E0001416141614161416141614161416141657 :1069F0001416141614161416141614161416141647 :106A00000406040604060406040604060406040636 :106A10000406040604060406040604060406040626 :106A20000406040604060406040604060406040616 :106A30000406040604060406040604060406040606 :106A400004060406040604060406040604060406F6 :106A500004060406040604060406040604060406E6 :106A600004060406040604060406040604060406D6 :106A700004060406040604060406040604060406C6 :106A800004060406040604060406040604060406B6 :106A900004060406040604060406040604060406A6 :106AA0000406040604060406040604060406040696 :106AB0000406040604060406040604060406040686 :106AC0000406040604060406040604060406040676 :106AD0000406040604060406040604060406040666 :106AE0000406040604060406040604060406040656 :106AF0000406040604060406040604060406040646 :106B00001416141614161416141614161416141635 :106B10001416141614161416141614161416141625 :106B20001416141614161416141614161416141615 :106B30001416141614161416141614161416141605 :106B400014161416141614161416141614161416F5 :106B500014161416141614161416141614161416E5 :106B600014161416141614161416141614161416D5 :106B700014161416141614161416141614161416C5 :106B800014161416141614161416141614161416B5 :106B900014161416141614161416141614161416A5 :106BA0001416141614161416141614161416141695 :106BB0001416141614161416141614161416141685 :106BC0001416141614161416141614161416141675 :106BD0001416141614161416141614161416141665 :106BE0001416141614161416141614161416141655 :106BF0001416141614161416141614161416141645 :106C00000406040604060406040604060406040634 :106C10000406040604060406040604060406040624 :106C20000406040604060406040604060406040614 :106C30000406040604060406040604060406040604 :106C400004060406040604060406040604060406F4 :106C500004060406040604060406040604060406E4 :106C600004060406040604060406040604060406D4 :106C700004060406040604060406040604060406C4 :106C800004060406040604060406040604060406B4 :106C900004060406040604060406040604060406A4 :106CA0000406040604060406040604060406040694 :106CB0000406040604060406040604060406040684 :106CC0000406040604060406040604060406040674 :106CD0000406040604060406040604060406040664 :106CE0000406040604060406040604060406040654 :106CF0000406040604060406040604060406040644 :106D00001416141614161416141614161416141633 :106D10001416141614161416141614161416141623 :106D20001416141614161416141614161416141613 :106D30001416141614161416141614161416141603 :106D400014161416141614161416141614161416F3 :106D500014161416141614161416141614161416E3 :106D600014161416141614161416141614161416D3 :106D700014161416141614161416141614161416C3 :106D800014161416141614161416141614161416B3 :106D900014161416141614161416141614161416A3 :106DA0001416141614161416141614161416141693 :106DB0001416141614161416141614161416141683 :106DC0001416141614161416141614161416141673 :106DD0001416141614161416141614161416141663 :106DE0001416141614161416141614161416141653 :106DF0001416141614161416141614161416141643 :106E00000406040604060406040604060406040632 :106E10000406040604060406040604060406040622 :106E20000406040604060406040604060406040612 :106E30000406040604060406040604060406040602 :106E400004060406040604060406040604060406F2 :106E500004060406040604060406040604060406E2 :106E600004060406040604060406040604060406D2 :106E700004060406040604060406040604060606C0 :106E800004060406040604060406040604060406B2 :106E900004060406040604060406040604060406A2 :106EA0000406040604060406040604060406040692 :106EB0000406040604060406040604060406040682 :106EC0000406040604060406040604060406040672 :106ED0000406040604060406040604060406040662 :106EE0000406040604060406040604060406040652 :106EF0000406040604060406040604060406040642 :106F00001416141614161416141614161416141631 :106F10001416141614161416141614161416141621 :106F20001416141614161416141614161416141611 :106F30001416141614161416141614161416141601 :106F400014161416141614161416141614161416F1 :106F500014161416141614161416141614161416E1 :106F600014161416141614161416141614161416D1 :106F700014161416141614161416141614161416C1 :106F800014161416141614161416141614161416B1 :106F900014161416141614161416141614161416A1 :106FA0001416141614161416141614161416141691 :106FB0001416141614161416141614161416141681 :106FC0001416141614161416141614161416141671 :106FD0001416141614161416141614161416141661 :106FE0001416141614161416141614161416141651 :106FF0001416141614161416141614161416141641 :10700000F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F710 :10701000F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F700 :10702000F7F7970604060406040604060406040699 :107030000406040604060406040604060406040600 :107040000406040697F7F7F7F7F7F7F7F7F7F7F7F8 :10705000F7F7F7F7F7F7F7F7F7060406040604065D :1070600004060406040604060406040604060406D0 :1070700004060416F7F7F7F7F7F7F7F7F7F7F7F758 :10708000F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F790 :10709000F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F780 :1070A000F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F770 :1070B000F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F760 :1070C000F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F750 :1070D000F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F740 :1070E000F7F7F7F7F7060406040604060406049704 :1070F000F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F720 :10710000F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F70F :10711000F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7FF :10712000F7F7F7F7F7F7F7F7F7F7F7F7F797141613 :1071300014161416141614161416141614161416FF :10714000141614161416141614161416143614F7EE :10715000F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7BF :10716000F7F7F7F7F7F7F7F7F7F7F7F7B7B7F7F72F :10717000F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F79F :10718000F7F7F7F7F7F7F7F7F7F79516141614165A :10719000141614161416141614161416141614169F :1071A00014161416141614161416147614F7F7F78A :1071B000F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F75F :1071C000F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F74F :1071D000F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F73F :1071E000F7F7F7F797161416141614161416141644 :1071F00014161416F7F7F7F7F7F7F7F7F7F7F7F7A7 :10720000F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F70E :10721000F7F7F7F7F7F7F7F7F7F797060406040617 :10722000040604060406040604060406040604060E :1072300004060406040604060406040604F7F7F729 :10724000F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7CE :10725000F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7BE :10726000F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7AE :10727000F7F7F7F797060406040604060406040663 :1072800004060406040604060406040604060406AE :10729000040604060406F7F7F7F7F7F7F7F7F7F72A :1072A000F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F76E :1072B000F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F75E :1072C000F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F74E :1072D000D70604060406040604060406040604068B :1072E000040604060406040604060406040604064E :1072F00004060497F7F7F7F7F7F7F7F7F7F7F7F755 :10730000F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F70D :10731000F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7FD :10732000F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7ED :10733000F797141614161416141614161416F7F7D5 :10734000F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7CD :10735000F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7BD :10736000F7F7F7F7F7F71416141614161416141681 :1073700014161416141614161416141614161416BD :1073800014161416141614F614F7F7F7F7F7F7F7A0 :10739000F7F7F7F7F7F7F7F7F7F7F7F7D7D7F7F7BD :1073A000F7F7D7D7F7F7F7F7F7F7F7F7F7F7F7F7AD :1073B000F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F75D :1073C000F7F7F7F7F7971416141614161416141681 :1073D000141614161416141614161416141614165D :1073E0001416141614F614F7F7F7F7F7F7F7F7F77C :1073F000F7F7F7F7F7F7F7F7F7F7F7F7F7F7F7F71D :10740000040604060406040604060406040604062C :10741000040604060406040604060406040604061C :10742000040604060406040604060406040604060C :1074300004060406040604060406040604060406FC :1074400004060406040604060406040604060406EC :1074500004060406040604060406040604060406DC :1074600004060406040604060406040604060406CC :1074700004060406040604060406040604060406BC :1074800004060406040604060406040604060406AC :10749000040604060406040604060406040604069C :1074A000040604060406040604060406040604068C :1074B000040604060406040604060406040604067C :1074C000040604060406040604060406040604066C :1074D000040604060406040604060406040604065C :1074E000040604060406040604060406040604064C :1074F000040604060406040604060406040604063C :10750000141614161416141614161416141614162B :10751000141614161416141614161416141614161B :10752000141614161416141614161416141614160B :1075300014161416141614161416141614161416FB :1075400014161416141614161416141614161416EB :1075500014161416141614161416141614161416DB :1075600014161416141614161416141614161416CB :1075700014161416141614161416141614161416BB :1075800014161416141614161416141614161416AB :10759000141614161416141614161416141614169B :1075A000141614161416141614161416141614168B :1075B000141614161416141614161416141614167B :1075C000141614161416141614161416141614166B :1075D000141614161416141614161416141614165B :1075E000141614161416141614161416141614164B :1075F000141614161416141614161416141614163B :10760000040604060406040604060406040604062A :10761000040604060406040604060406040604061A :10762000040604060406040604060406040604060A :1076300004070406040604060406040604060406F9 :1076400004060406040604060406040604060406EA :1076500004060406040604060406040604060406DA :1076600004060406040604060406040604060406CA :1076700004060406040604060406040604060406BA :1076800004060406040604060406040604060406AA :107690000406040604060406040704060406040699 :1076A000040604060406040604060406040604068A :1076B000040604060406040604060406040604067A :1076C000040604060406040604060406040604066A :1076D000040604060406040604060406040604065A :1076E000040604060406040604060406040604064A :1076F000040604060406040604060406040604063A :107700001416141614161416141614161416141629 :107710001416141614161416141614161416141619 :107720001416141614161416141614161416141609 :1077300014161416141614161416141614161416F9 :1077400014161416141614161416141614161416E9 :1077500014161416141614161416141614161416D9 :1077600014161416141614161416141614161416C9 :1077700014161416141614161416141614161416B9 :1077800014161416141614161416141614161416A9 :107790001416141614161416141614161416141699 :1077A0001416141614161416141614161416141689 :1077B0001416141614161416141614161416141679 :1077C0001416141614161416141614161416141669 :1077D0001416141614161416141614161416141659 :1077E0001416141614161416141614161416141649 :1077F0001416141614161416141614161416141639 :107800000406040604060406040604060406040628 :107810000406040604060406040604060406040618 :107820000406040604060406040604060406040608 :1078300004060406040604060406040604060406F8 :1078400004060406040604060406040604060406E8 :1078500004060406040604060406040604060406D8 :1078600004060406040604060406040604060406C8 :1078700004060406040604060406040604060406B8 :1078800004060406040604060406040604060406A8 :107890000406040604060406040604060406040698 :1078A0000406040604060406040604060406040688 :1078B0000406040604060406040604060406040678 :1078C0000406040604060406040604060406040668 :1078D0000406040604060406040604060406040658 :1078E0000406040604060406040604060406040648 :1078F0000406040604060406040604060406040638 :107900001416141614161416141614161416141627 :107910001416141614161416141614161416141617 :107920001416141614161416141614161416141607 :1079300014161416141614161416141614161416F7 :1079400014161416141614161416141614161416E7 :1079500014161416141614161416141614161416D7 :1079600014161416141614161416141614161416C7 :1079700014161416141614161416141614161416B7 :1079800014161416141614161416141614161416A7 :107990001416141614161416141614161416161695 :1079A0001416141614161416141614161416141687 :1079B0001416141614161416141614161416141677 :1079C0001416141614161416141614161416141667 :1079D0001416141614161416141614161416141657 :1079E0001416141614161416141614161416141647 :1079F0001416141614161416141614161416141637 :107A00000406040604060406040604060406040626 :107A10000406040604060406040604060406040616 :107A20000406040604060406040604060406040606 :107A300004060406040604060406040604060406F6 :107A400004060406040604060406040604060406E6 :107A500004060406040604060406040604060406D6 :107A600004060406040604060406040604060406C6 :107A700004060406040604060406040604060406B6 :107A800004060406040604060406040604060406A6 :107A90000406040604060406040604060406040696 :107AA0000406040604060406040604060406040686 :107AB0000406040604060406040604060406040676 :107AC0000406040604060406040604060406040666 :107AD0000406040604060406040604060406040656 :107AE0000406040604060406040604060406040646 :107AF0000406040604060406040604060406040636 :107B00001416141614161416141614161416141625 :107B10001416141614161416141614161416141615 :107B20001416141614161416141614161416141605 :107B300014161416141614161416141614161416F5 :107B400014161416141614161416141614161416E5 :107B500014161416141614161416141614161416D5 :107B600014161416141614161416141614161416C5 :107B700014161416141614161416141614161416B5 :107B800014161416141614161416141614161416A5 :107B90001416141614161416141614161416141695 :107BA0001416141614161416141614161416141685 :107BB0001416141614161416141614161416141675 :107BC0001416141614161416141614161416141665 :107BD0001416141614161416141614161416141655 :107BE0001416141614161416141614161416141645 :107BF0001416141614161416141614161416141635 :107C00000406040604060406040604060406040624 :107C10000406040604060406040604060406040614 :107C20000406040604060406040604060406040604 :107C300004060406040604060406040604060406F4 :107C400004060406040604060406040604060406E4 :107C500004060406040604060406040604060406D4 :107C600004060406040604060406040604060406C4 :107C700004060406040604060406040604060406B4 :107C800004060406040604060406040604060406A4 :107C90000406040604060406040604060406040694 :107CA0000406040604060406040604060406040684 :107CB0000406040604060406040604060406040674 :107CC0000406040604060406040604060406040664 :107CD0000406040604060406040604060406040654 :107CE0000406040604060406040604060406040644 :107CF0000406040604060406070604060406040631 :107D00001416141614161416141614161416141623 :107D10001416141614161416141614161416141613 :107D20001416141614161416141614161416141603 :107D300014161416141614161416141614161416F3 :107D400014161416141614161416141614161416E3 :107D500014161416141614161416141614161416D3 :107D600014161416141614161416141614161416C3 :107D700014161416141614161416141614161416B3 :107D800014161416141614161416141614161416A3 :107D90001416141614161416141614161416141693 :107DA0001416141614161416141614161416141683 :107DB0001416141614161416141614161416141673 :107DC0001416141614161416141614161416141663 :107DD0001416141614161416141614161416141653 :107DE0001416141614161416141614161416141643 :107DF0001416141614161416141614161416141633 :107E00000406040604060406040604060406040622 :107E10000406040604060406040604060406040612 :107E20000406040604060406040604060406040602 :107E300004060406040604060406040604060406F2 :107E400004060406040604060406040604060406E2 :107E500004060406040604060406040604060406D2 :107E600004060406040604060406040604060406C2 :107E700004060406040604060406040604060406B2 :107E800004060406040604060406040604060406A2 :107E90000406040604060406040604060406040692 :107EA0000406040604060406040604060406040682 :107EB0000406040604060406040604060406040672 :107EC0000406040604060406040604060406040662 :107ED0000406040604060406040604060406040652 :107EE0000406040604060406040604060406040642 :107EF0000406040604060406040604060406040632 :107F00001416141614161416141614161416141621 :107F10001416141614161416141614161416141611 :107F20001416141614161416141614161416141601 :107F300014161416141614161416141614161416F1 :107F400014161416141614161416141614161416E1 :107F500014161416141614161416141614161416D1 :107F600014161416141614161416141614161416C1 :107F700014161416141614161416141614161416B1 :107F800014161416141614161416141614161416A1 :107F90001416141614161416141614161416141691 :107FA0001416141614161416141614161416141681 :107FB0001416141614161416141614161416141671 :107FC0001416141614161416141614161416141661 :107FD0001416141614161416141614161416141651 :107FE0001416141614161416141614161416141641 :107FF0001416141614161416141614161416141631 :00000001FF
Hi Mario,
You sly devil!
You need to convert that to binary and look at each byte at a time. Each byte, in binary form, is what ends up at the output of the eeprom when that address is accessed. Then all you need to do is figure out which bits do what, example first bit might be transmit, second ch1 sample one third ch1 sample2 etc.
Also those other 2 chips could be this one, the pinout is correct and makes sense. http://focus.ti.com/lit/ds/symlink/sn74ahct00.pdf The no. may not be correct.
An inverting nand gate would be sufficient to convert the sine wave from the oscillator to a square wave seen at the 4040.
Cheers Mick
