Sandbanks
  • #76
    I see no second (EF) sample on this schematic, how is this suppose to work stable without one?
    • #77
      Here's my take on Sandbanks & Proscan. Changed Gain 1000, instead of the insane 10,000; Simplified timing control; Added EF sample and integrator from Dooley TD3X; Diode for mosfet drain; PSU as in MiniPulse Plus;
      Sandbanks - Proscan - GT.pdf
      • #78
        Interesting collection of ideas, you are switching Q1 and Q3 with only 5 volts from the micro is that enough ?
        • #79
          Voltage should be right. The micro/jfets configuration is same as in Minipulse so this should work just fine.
          Will the micro provide enough current, hope so !
          From datasheet: "- High current source/sink for direct LED drive"..
          Maximum output current sunk by any I/O pin............................................... .................................................. ... 25 mA
          Maximum output current sourced by any I/O pin .................................................. ............................................ 25 mA
          Maximum current sunk by GPIO.............................................. .................................................. ...................... 90 mA
          Maximum current sourced GPIO.............................................. .................................................. ...................... 90 mA
          • #80
            Here's update on the schematic. You can use PIC code from Hammerhead II thread to run this, though will probably require code tweaking.
            Proscan GT.pdf
            • #81
              Scoped my MPP and yes it only uses 5 volts on gate, this could be handy for another project.
              • #82
                Hello Everyone,
                My name Wahyu from Indonesia,
                Video my PI Polones base, i modified with Mosfet IRF740
                https://www.youtube.com/watch?v=WoD_NUfBYmk
                • #83
                  What happened to the sandbanks post ?
                  • #84
                    Originally posted by Wahyu View Post
                    Hello Everyone,
                    Can you show as the scheamatic or circuit of this modification?
                    • #85
                      I built sandbanks project using a modified power supply(555 pump charge). I also modified the delay on sampling. It works very well. Depth is very good. I used NE5534 preamp stage redesign instead of 709. This is non motion pi. I also did follow up mods as described in sandbanks article.very good. The schematic posted above is fundamentally different. It resembles minipulse plus. Apples and oranges.
                      • #86
                        What did you do to the Delay ? What Follow Up Mods . Thank You.
                        • #87
                          HI
                          Can anyone explain what exactly is the role of the C7?
                          Considering the fact that Pin 8 in the op-amp LF357 is N.C!
                          tnx
                          • #88
                            Originally posted by koohyar View Post
                            HI
                            tnx
                            [ATTACH]37389[/ATTACH]
                            [ATTACH]37390[/ATTACH]
                            It looks like a mistake to me. Here's the original Sandbanks article:
                            http://www.geotech1.com/cgi-bin/page...anks/index.dat
                            and it doesn't use an LF357. So I assume the PCB you posted is someone's modified version.
                            • #89
                              Looks like a Cap that may have been used with some other Op Amp.
                              • #90
                                The original used the LM709. It was used for Freq Compensation. Pin 1 / Pin 8.
