Hello
if you will use IRF740 will not get coil error or open device first and connect coil.
Thanks juse for reply i have tryed to post some photo buti couldnt i dont no why but i will try again so my board i use lf356 and irf 840 resesters is 5%tolerance no tantaliom capaceters only electrolic and ceramic for 104 code i use ivica pcbmy coil i onnected it directly its tow coil one of them is 22cm with31 turns and the other is spider 19 cm with 27 turns fuses is normaly as it should be
what cuse error coil. all the time with many tries lhave error coil
SureOriginally posted by pigeon View Posthi thank you allfriend for help.
the usbisp not work
Ripsdevala can you send your pcb
UP...Originally posted by ripsdevala View PostIs there a way to make felezjoo to be in motion (dynamic) mode?, any MD with non motion (static) mode is not working properly here, to many vulcanic ground.
hi thank you allfriend for help.Originally posted by ripsdevala View PostTry this driver, if this fail you need chinese driver to work like my usbasp
http://www.fischl.de/usbasp/usbasp.2011-05-28.tar.gz
the usbisp not work
Firmware files and drivers for older AVR/Atmel Studio and/or Arduino/AVRDUDE
Recommended drivers for Windows 10
Source
thank you
i have USBisp not usbasp/Is what they are the same
i haven't driver Where can I find
Your usbasp is not recognized, are you already install the driver?Originally posted by pigeon View Post[ATTACH]38546[/ATTACH]
Make this for simple programingOriginally posted by pigeon View Posthi all friend
I have usb isp adapter .i can't burn atmega328 with it
what should I do
please help me
thank you[ATTACH]38545[/ATTACH]
