Most probably bad or counterfeit LM7812. Grab a genuine L7812CV and it will work as it should.
Most likely your 7812 is fake when it draws a current and shuts down. I already had this problem.
- Likes 1
Hello
i have problem with felezjoo
when i connect the coil to device and power on device not work lm7812 getting hot when i disconnect the coil power up device turn on and connect coil work normal what the case ?
Help me guy
Hello, can you please tell me what is the resistance of 1 meter coil?
Thank you
they are all lies there is no new version by the editor there is only 3.35v
falezjoo is the worst project I've ever seen.
ground balance does not hold.
waste of time.
Hi to all freinds . there is a version V4.24 HEX . Can someone here get it. Please
i use the full version : felezjoo full M 3.35 and the : felezjoo full edit 3.35, this two can you give me one stable
Are you using the original .HEX version of Hamid with the counter? Ah reports that the version without the counter is unstable in the field, although I have not noticed a difference between the two versions.
yes i leave air gap in the shield and conect to ground ok, the shield is in the plastic cover then i have a piece of paper and then the coil inside,
but i have the problem before shield the coil.
