  • Tahabns1
    Hello everybody, Am your friend taha from Tunisia. I have the felezjoo with all his model of this great machine, For you, who HAD this " COIL ERROR " this is simple use potentiometer 5k or 10k instead of R11 390 ohm. Using the potentiometer with clicking Down button, felezjoo read the coil, slightly try to fix the Super number ABC then restart the box.
  • zakari
    hi folharin
    you can re-programing the same atmega no need another
    best regard
    zakari
  • folharin
    i used usbasp and avr dudess
  • folharin
    I was in the middle of recording atmega and I think there was an error in the compilation.my doubt is if i can re-record in the same atmega or need to buy another new one?
    Eu estava no meio da grava??o do atmega e acho que ocorreu um erro na compila??o
  • Qiaozhi
    Originally posted by Ruben2000 View Post
    este hilo est? muerto parece que COVID-19 ha ganado la batalla !!!
  • Ruben2000
  • Ruben2000
ID:	358271Click image for larger version
ID:	358270Click image for larger version
  • Ruben2000
    I have not been able to get the original LF357N and I am testing it with a Chinese one and I had to use the IRF740 because the IRF840 burns out. I am still a beginner at this.
  • Ruben2000
    Originally posted by folharin View Post
    ACHO QUE MEU USBASP ? FALSO CHIN?S
    to be able to record correctly you have to install the AVR DUDE program correctly
  • Ruben2000
    to be able to record correctly you have to install the AVR DUDE program correctly.
  • Ruben2000
  • AK48
    Principle
    The tantalum capacitor is a gelled or solid electrolyte capacitor whose dielectric is a thin layer of tantalum oxide (Ta
    2 O 5 ), a refractory metal whose transformation takes place by sintering at very high temperature. Compared to aluminum, tantalum oxide has a permittivity of 26 (8.5 for alumina) which makes it possible to produce capacitors of smaller volume with identical capacity, very reliable, robust and usable between -55 and + 125 ? C
    There are several technologies for producing this type of capacitor:
    - strips of tantalum laminated and wound in the conventional way
    - capacitors with sintered anode and solid electrolyte (manganese dioxide)
    - capacitors with sintered anode and gel electrolyte
    In this last model the anode is a block of very fine tantalum powder agglomerated by sintering electrically separated from the cathode (the electrolyte: sulfuric acid or lithium chloride) by the thin film of insulating oxide (Ta
    2 O 5 ). The negative electrode is made up of the silver casing which contains everything and must be chemically resistant to the electrolyte.
    The thickness of the dielectric is very small: a few nanometers for a low voltage capacitor but its surface area is very large due to the granular structure of the anode (see Capacitors: different types of dielectrics ).
    Use and characteristics
    Due to its small size and large capacity, the tantalum capacitor tends to replace the aluminum electrolytic capacitor. It is found in LF as a connection and decoupling capacitor. As its leakage current is low and its capacitance stable and precise, it is also used in timing circuits.
    Standardized operating voltage: 6.3 to 125V, beyond 85 ? C it gradually decreases
    Polarization
    : Like aluminum electrolytic capacitors, tantalum capacitors can be damaged if plugged in backwards. There are models which withstand a few volts in reverse and non-polarized models which are in fact two polarized capacitors mounted in series and in opposition.
    frequency range
    Up to a hundred kHz, the capacitance does not vary with frequency. then it decreases very clearly. A 22?F capacitor from 1 to 100kHz will only make 1?F at 2MHz Leakage
    current : a few ?A due to the impurities contained in the tantalum powder
    Temperature range : -55 ? C to + 125 ? C
    Capacity range : commonly a few ?F to several tens of mF
    Tolerance: minimum 10% for models with liquid electrolyte and 5% for models with solid electrolyte
    Losses : fairly high, tg (
    d ) ranging from 0.05 to 0.8
    Lifespan and reliability : very favorable especially for models with solid electrolyte
  • ricalbertvig
    is there a difference in using electrolyte instead of tantalum 100 uf? I tested with tantalum and electrolyte and the behavior is the same .. because the author recommends using tantalum 100 uf? .. how can it affect using electrolyte? Greetings ,,, I await a response from someone knowledgeable on the subject ..
  • Qiaozhi
    English?
  • folharin
