hi ivconic ihave debug numbers that A320 B790 C910 how can i get these number more close together
HELLO EVERY ONE
I MAKE THE FELEZJOU PCB BUT I HAVE A NEW PROBLEM
THE PCB RUN NORMALY WITHOUT COIL AND THE LCD DESPLAY " coil error"
BUT WHEN I PUT THE COIL THERE IS NO DESPLAY IN THE LCD
AND THE 7812 BECAME VERY HOT
PLEASE ANY IDIA TO HELP ME
Clearly there's a problem with the coil.Originally posted by faycel View PostHELLO EVERY ONE
Also ... did you know that (according to forum etiquette) posting in CAPITALS is equivalent to shouting?
Here's a useful guide -> http://www.toptenreviews.com/service...tiquette-tips/
sorryOriginally posted by Qiaozhi View PostClearly there's a problem with the coil.
hi .... I had the same problem and i give you and advise its the amperage you are giving to the motherboard what's causing all this .... I gave big amperage to my first board and i had the same problem when i plug the coil the lcd turns off then i found that one of the diodes burned out (the one on the left ) i changed it and the problem continued ... I kept trying to make it detect the coil and the atmega burned and everything stoped working... At last i changed the atmega and put less amperage and the problem gone ... So becareful you will burn your atmega.Originally posted by faycel View PostHELLO EVERY ONE
About coil error are you using original lf357??? Try some other opamps and see mybe it will workOriginally posted by faycel View Postok its the problem. now its ok but "coil errror"
keep in mind my friend if you try more opamps and it doesn't work build another one mybe other components are burned and you cant notice them
