  • Fadel saleh
    Gerber files for printing PCB boards on CNC bales
  • sabios
    This is a new video I recorded in an open field, and as always, I'm using a 355ml aluminum can, this time at 67cm.
    And I'm using a 50cm square spool with its sled so the spool doesn't move and cause any errors.
  • sabios
    I've used coils up to 230uH and it's worked for me, although that one is a bit unstable. But with 330 to 450uH there are no problems.
    At least on my end, I haven't had any problems and I've seen that it works well. In fact, I've recently been looking at the Iron Reged section, which is the discrimination feature, and I've noticed that it removes ferrous materials easily, although it's a bit tricky to use precisely.
    Actually, I currently have three different coils: a 45cm spider-type coil, a 50cm square coil, and a 1x1m square coil, and all of them have worked well, except for the 57uH one, which was the prototype.
  • ivconic
    A colleague left me a Chinese copy coil for ML GP&GPX for a few days.
    So I tested and measured.
    I had to add a 1 ohm series resistor and connected that to the FelezJoo PI.
    The coil immediately worked solidly, without the occasional "Coil error" problem, which is otherwise common.
    But I won't know how well it works until I get the original LF357.
    For now, there is still LF356 in the detector, which is not adequate.
    BTW coil is 43x28cm.
ID:	449449Click image for larger version
  • sabios
    In this new video, I'm using a 50cm square coil with a sled that keeps it at 21cm, but I'm finding it more difficult to use because the location is more challenging.
    However, since it's balanced with a single button, it's easier.
    And lastly, it's only for the can that's 70cm away; it doesn't detect the coin.
    Besides, there were too many ants.
    By the way, its resistance is 1.5 ohms and its inductance is 370uH.
  • sabios
    The coil has a resistance of 1.6 ohms and an inductance of 350uH. I'm using the full version 3.35, but I should clarify that I made some adjustments since most of the problems were related to that. Finally, to make it a little slower and more stable, I added something to the board, which is what makes it run slower but very stable. Tomorrow I plan to make a 50cm square coil to see the differences between this one and the other.
  • Ruben2000
    Hey experts! It looks like the Felezjoo is working well.
    What firmware are you using?
    Could you share the specifications of your coils?​
  • sabios
    This is a video I made; I should clarify that I'm not a professional at this. In the video, I clearly showed that the can is 70cm high. What do you think? As I said, it's very stable, although in this version, as you can see, it's a bit slower, but that makes it more stable than it was before.
    Incidentally, I also used an XH-M404 With Display for this detector to stabilize it at the correct voltage, and I must say it works wonderfully with it.
  • sabios
    Has anyone noticed that the Felezjoo is fast at detection but therefore more unstable? With a small change, it becomes slower but more stable. I'm using a 45cm coil for testing. I recently buried a can of chili peppers 40cm deep and it detected it.
    And of course, this is the version I modified.​
  • ivconic
    Welcome to my world of pain!
  • latcakir
    Is it possible to perform integrated testing of the LF357 with a V/I curve tracer?
  • Fadel saleh
    اريد اطلب منك الكود. الخاص بلمعالج v2.40.hex
  • Aziz
    Even the very cheap 741 op-amps get faked:
    WTF, all fake!
  • Aziz
    Hi all,
    I have some original LF357 (DIP) somewhere. They must be at least 20 - 30 years old now.
    Also some TL071, TL072.
    Is it really difficult to get the original parts today?
  • cristiano.sar
    If someone had told me this 20-25 years ago; I could hardly believe it.
    But today I am 100% sure of what I am going to write.
    If we take all the existing projects on the forum and the thousands of people who participated in DIY and often gave their experiences, opinions,
    often reports on failure and problems on the forum... today I am 100% sure that over 70% of failures are related to fake components!
    The other 30% of failures goes to ignorance, incompetence or inexperience.
    I sign this statement!
    That is true, for example, I rebuilt my TGSL and coils for it a lot of times to find some years later that the problem with low depth performace was related to fake components.
