  • ivconic
ID:	417617Click image for larger version
ID:	417618Click image for larger version
ID:	417620Click image for larger version
ID:	417621Click image for larger version
  • ivconic
    A friend sent me a link from Iran Ads. FelezJoo for sale. When converting Tomans to Dollars; the price is about 88 dollars.
    The first thing to notice is the new and improved pcb design.
    And the use of LF357 in a round, "military standard" package.
    There are some of these in my local stores, but they are very expensive!
    Still... a detector this good is worth the investment.
    What interests me is; can anyone find the gerber files for such a new pcb?
    https://iran2kit.com/product/%D8%A8%...D8%AE%D9%87-4/
  • kt315
    promised, without GERBER.
  • kt315
  • kt315
    Originally posted by nick holas View Post
    hi all
    thanks for your reply ivconic and KT315 .
    ivconic ,i ve send your file to jlcpcb and ..... it don't works !!!!!! it say "your file has been saved into your files manager " and 0 layer detected .
    when i want to see them with gerber viewer it say "unable to preview"
    i ve corrected my file like you say and........ it make the same things ,layers are not a the good place .
    i don't understand!!!!
    capture of my files--->
    got the reply...
  • nick holas
    hi all.
    Hurra!!!!!!! thanks all!!!!! it works!!!!!
  • nick holas
    hi all
  • ivconic
    With Fedex option pcbs arrive within 10 days... at least to my place.
    Just look at the prices for 5 pcbs, nobody can compete that!
    I just LOVE JLPcb!
    Click image for larger version  Name:	image.png Views:	0 Size:	39.1 KB ID:	417279​
  • ivconic
    The problem was easy to solve.
    The wire jumpers should be in the blue (top) layer (C1), but that's less important, it was more important to mark all the holes as "Through pad":
    Click image for larger version  Name:	image.png Views:	0 Size:	10.8 KB ID:	417277​​
  • ivconic
    Try with this one, corrected, it works for me:
    Click image for larger version  Name:	image.png Views:	0 Size:	76.2 KB ID:	417274​
  • kt315
    i asked them via the field MESSAGES, can they use just LAY file. but right now they are not on-line. wait a reply.
  • nick holas
    Hi all ,did some one have the felezjoo .brd files?
    i would like to send it to " jlcpcb".
    I have the .lay files but when i make the gerber files with sprint layout 6 the bottom lay,top lay ,in print lay aren't at the good place for "JLCPCB"
    thanks all
  • useus
    I do not understand
  • kt315
    your body is on the ground. you stand on the ground. you go on the ground. is it clear for you?
  • useus
    connect the stick to cold end of the coil, ie to power supply line. ground the coil socket, inside the housing. then by wire connect steam to the socket.
    remember, your body/hand must be isolated from the stick.
    The stick is made of carbon fiber, the wire does not touch any part of my body, the connections are correct...
