hello if I connect a coil 380 uH coil 38 cm radius with 1 mm wire device not opening giving coil error .İf I open device without coil and connect during startup felezjoo working without any problem.
if ı connect serial 8 ohm to coil device opening. How can I solve this problem?
Use thinner wire.Originally posted by gurdal View Posthello if I connect a coil 380 uH coil 38 cm radius with 1 mm wire device not opening giving coil error .İf I open device without coil and connect during startup felezjoo working without any problem.
The "2 stage amp" shown in #980... I don't get it.
What is it? Voodoo? An idea to get rid of your precious LF357s?
This circuit - the way it is pictured - will do exactly nothing to your signal, however it will most likely heat up (and potentially destroy) the second LF357...
"...hello if I connect a coil 380 uH coil 38 cm radius with 1 mm wire..."Originally posted by gurdal View PostUse thinner wire ?
1mm wire is too thick for coil with only 38cm diameter, by my humble opinion.
For 38cm diameter coil i would suggest wire gauge between 0.55 to 0.7mm.
But for this particular detector; i would not suggest use of single Cu lac wire.
Inter capacitance is high and FelezJoo PI don't like it.
Instead use litz wire with common gauge not exceeding 0.55 to 0.7mm, preferably pvc coated (a bit more inter space - much less inter capacitance).
Or in case if you insist on single Cu lac wire; than don't make conventional single layer coil but do make spider or basket coil instead with it.
