  • bernte_one
    no felezjoo needs a specific coil, wrong coil is not useable for discrimination
  • waltr
    Originally posted by tenere750 View Post
    Can somebody helping me out? Can somebody give me details about building a working coil 60cm
    This is a PI detector which typically is NOT sensitive to coil. Most mono-coils of 300 to 500uH should work.
    Lots and lots of coil info on these forums. Just wind a simple coil to test circuit.
  • tenere750
  • basellafe
    this project want many of mecrocontroller to succes look if U reprogram atmega and give U
    the code (ffffff) or (000000) it mean the atmega burn
  • Kostasp
    Thanks do you have a good working pcb to see
  • basellafe
    just buy another one and test its cheep and safe time or re biuld a secret to test
  • Kostasp
    is any way to check the chip thanks
  • basellafe
    i think its burn
  • Kostasp
    i cant reprograming he says no communicate with target chip
    i use this USB-ISP-Programmer-for-AVR
  • basellafe
    U shuold got a beeeb in first start if not check atmega with reprograming
  • Kostasp
    The voltage in socket with 28 pin ok .but how I now the right for all the pins do you have a photo. do you now how to check the atmega328p if is good or have burn
  • basellafe
    Test the voltag on lines with out mecrocontroller and test the battery amp it should be at least 1.8amp
  • Kostasp
ID:	352171 this is the pcb and a second Click image for larger version
ID:	352172 i have fix the C24 but dont start
  • MartyJ1963
    Hi all,,,,,I don't know if this will help anyone but I have 2 x working Felezjoo's and for both I use 3 x 18650 batteries with a DC Adjustable XL6009 Step up step down converter and they work fine and give me about 6 hours detecting time. The 3 x 18650 give me 12v but I adjust the step up converter to 18v and it's been fine,,,no overheating or any other problems. Hope it helps someone. Marty
  • basellafe
    yes its good no problem with it
