This is a PI detector which typically is NOT sensitive to coil. Most mono-coils of 300 to 500uH should work.Originally posted by tenere750 View PostCan somebody helping me out? Can somebody give me details about building a working coil 60cm
Lots and lots of coil info on these forums. Just wind a simple coil to test circuit.
this project want many of mecrocontroller to succes look if U reprogram atmega and give U
the code (ffffff) or (000000) it mean the atmega burn
just buy another one and test its cheep and safe time or re biuld a secret to test
U shuold got a beeeb in first start if not check atmega with reprograming
The voltage in socket with 28 pin ok .but how I now the right for all the pins do you have a photo. do you now how to check the atmega328p if is good or have burn
Test the voltag on lines with out mecrocontroller and test the battery amp it should be at least 1.8amp
Hi all,,,,,I don't know if this will help anyone but I have 2 x working Felezjoo's and for both I use 3 x 18650 batteries with a DC Adjustable XL6009 Step up step down converter and they work fine and give me about 6 hours detecting time. The 3 x 18650 give me 12v but I adjust the step up converter to 18v and it's been fine,,,no overheating or any other problems. Hope it helps someone. Marty
