Hi my friend its not the battery what cause the problem try to use 10 ohm 4 watts and higher resistor in series with the coil
Make this for simple programingOriginally posted by pigeon View Posthi all friend
I have usb isp adapter .i can't burn atmega328 with it
what should I do
please help me
thank you[ATTACH]38545[/ATTACH]
http://www.geotech1.com/forums/showt...hlight=Icduino
Firmware files and drivers for older AVR/Atmel Studio and/or Arduino/AVRDUDE
https://www.olimex.com/Products/AVR/...owsDrivers.zip
Recommended drivers for Windows 10
https://www.olimex.com/Products/AVR/...AS-6-7-W10.zip
Source
Try this driver, if this fail you need chinese driver to work like my usbasp
http://www.fischl.de/usbasp/usbasp.2011-05-28.tar.gz
hi thank you allfriend for help.Originally posted by ripsdevala View PostTry this driver, if this fail you need chinese driver to work like my usbasp
the usbisp not work
Ripsdevala can you send your pcb
SureOriginally posted by pigeon View Posthi thank you allfriend for help.
the usbisp not work
UP...Originally posted by ripsdevala View PostIs there a way to make felezjoo to be in motion (dynamic) mode?, any MD with non motion (static) mode is not working properly here, to many vulcanic ground.
Thanks juse for reply i have tryed to post some photo buti couldnt i dont no why but i will try again so my board i use lf356 and irf 840 resesters is 5%tolerance no tantaliom capaceters only electrolic and ceramic for 104 code i use ivica pcbmy coil i onnected it directly its tow coil one of them is 22cm with31 turns and the other is spider 19 cm with 27 turns fuses is normaly as it should be
