  • there is more of reason for error coil begen with atmega and end with atmega any companent or track or cut couse error coil and also bad programing couse error coil so u have to start from atmega replace it and follow companent if u build another one u will not be abe to repair any of problem u will face
    • Hello
      Check R5 near ırf, if its is 10k change with 2k2 . its is an error on typoon.lay
      pls sent half of your first finding if it will ok:
      • Be sure that r10 is in correct value.. do not use shield on your coil, maintain correct coil specification and you will not experiencebany coil error.. it is not on atmega.
        • Hello
          R5 is 10 k wrong check first page attachment partlist it is 2k2 but not on typoon.lay
          I faced same thing and 2k2 solved coil error problem.
            with this board every thing possible
            • Felezjoo Pi Pcb
              • Originally posted by samii View Post
                Hello
                I dont have coil error with 10k, but I should change it, thanks for the info.
                • I do not know but İvconik pcb 2k2 for r5 and original document 2k2 .
                  if it is detecting 1 euro at 40 cm with a 30 cm coil like mine not problem
                  • Originally posted by gurdal View Post
                    Felezjoo Pi Pcb
                    Wow!
                    You really believe!
                    • this felezjoo dont love gold
                      I tests 3 type of coil with this MD but i thing that this felezjoo hate gold.
                      it can detect a coin at 30 cm . but it cant detect a gold ring at 10 cm
                      • what was the problem for error coil freind
                        • Problem with the coil, to be exact the error is as follows:
                          Delay
                          Coil error.
                          And the truth already check the more resistant resistances to the coil and I do not find the error.
                          That is why I ask for your help.
                          Something else in the hex file that went up EEPROM_CLEAR
                          Which is what this particular hex does not understand.
                          Is some kind of hex to do it at 100% full.
                          • I forgot to tell you that the version you use is that of Typon 2 lay.
                            • Hi jladre
                              I'm glad see you have succeeded on A cable coil, so I want to continue my unfinished work。
                              can you give me help about the cable coil?
                              Thanks a lot!
                              • Originally posted by faycel View Post
                                whats the problem please
