Originally posted by ripsdevala View PostI cant find any doc/tutorial to make a 3dss coil, do you have one?
With mono coil it doesnt have iron rejection, i dug 1mx1mx20cm and fill it with sand and pick all iron on it, just to test a coil, i think there should be no iron fragment around it. All pi detector work, except pickini its not emi friendly
Jladre, what is the best setting for terain with iron sand, i think i have iron sand soil all around here.
Originally posted by jladre View PostInstead of standard planar coil you make 2 spider wave coil "3dss". Example is one 4" 3dss and 1 8.5" 3dss then put it together in series to end of the small one and start of the big one. You will be amazed how sensitive it is.
Hi,Thanks that interesting, what was the total inductance you made the coil/coils ?
Instead of standard planar coil you make 2 spider wave coil "3dss". Example is one 4" 3dss and 1 8.5" 3dss then put it together in series to end of the small one and start of the big one. You will be amazed how sensitive it is.Originally posted by 6666 View PostHi what coil are you referring to with this name ?
Good morning all,
Can i use this 150uf tantalum for c6, c12? but im not sure the voltage rating for those.
Hi what coil are you referring to with this name ?double planar spider wave coil
Ivconic found that standart coil work best for him. In my case the double planar spider wave coil works best for me but by now im using a 3dss coil which is easy to manuever underwater.. be aware if you will using the standard coil never put shielding to it except the cable.Originally posted by ripsdevala View PostWill change it..
is standar pi coil is better than spider coil? I use spider for now
Will change it..Originally posted by jladre View PostYou need to change the value of R20 to conpensate to the battery monitor.[ATTACH]38297[/ATTACH][ATTACH]38297[/ATTACH]
I think i should change the caps to square box film.
Many thanks jladre
, i dont know if this normal to have voltage on the soil.
