For people they want to unlock any atmega there is a easy way to doit download version 4 of atmel studio and you should have avr dragon load the hex with avr studio config the avr dragon when you start debugging with atmel studio when he finish from programming the 328p with isp mode he will programme the fuse to switch to debugwire and atmel studio will ask you switch off the target follow what the pop-up message said if you didn't you will brick the 328p chip and it will not recognized to unbrick it you must use high voltage programmer .to get where the programme
Write the counter check the application note about read and write to eeprom find the asm or hex code and put breakpoint run the code until it stop watch the LCD start keep doing run until you see the message count the number of run you was doing if you get all this step and you get to badboy place just make a nop or jump maybe there is a CRC check don't spread the cracked hex just use it for your project respect the owner think about the time you spent to unlock and the time spent by the owner for coding and debugging I didn't crack any hex and don't ask me to send you or post anything illegal
