  • Wiltran
    does the latest 3.30 hex code have the 300 use limitation?
  • silverdog
    Originally posted by chevesne View Post
    Me too.
    [ATTACH]35792[/ATTACH]
    I'm not sure about Avrdude but it may help
    I had a problem using extreme burner to begin with, replace the files in \program files\extreme burner AVR\data with the ones in the attachment
    It was something to do with defining the correct oscillator and speed
    felezjoofuses.zip
  • chevesne
    Me too.
Name:	erreur prog fuse.JPG
  • jladre
    hey jladre, which of the posted code version is audio only and which is without limits, please.
    And what's the name of your avatar pic and where are more such hot cuties?
    Hi funfinder! I would like to share the hex but due to the agreement of the one who give it to me i cannot give it to anybody.. I hope you understand..
  • chevesne
    @ Funfinder, you have some info here, and the last version: v3.30
  • gurdal
    hi
    complete circuit
    I could not write ATmega328 hex
  • Funfinder
  • jladre
    I understand tiredness, but not understand Tagalogish interpretation. What should be this term: "Daily Daily"? Delay Delay? Dial Dial? Delilah Delilah (Tom Jones). Or something else?
    Hahaha!! Daily means delay.. It is just an error of the translator which cannot perfectly translate persian to english..
  • WM6
    Originally posted by RS_Phil View Post
    Right WM6 so tired of editing a lot of text to correct. much more to translate it in my language (Tagalog)
  • Qiaozhi
    Nice bro JLad..nindut pang IRF460.
    Originally posted by jladre View Post
    mao gyud bro.. mas nindot sya kun supermesh power mosfet. maayo pud and irf460 ky ubos kaau and RDs..
    English please!
    Remember the forum rules.
  • jladre
    Originally posted by pigeon View Post
    thank you very much JLADRE
    P.
  • pigeon
    another refined pcb with track holes for high power mosfet.
    [ATTACH]35764[/ATTACH]
    P.
  • jladre
  • RS_Phil
  • jladre
    felezjoo pi is also a powerful pinpointer. A pinpoiner can be add to your pi just make a switch (to use the pin pointer coil and the ordinary coil)SPDT switch is reccomended). round tube with a diameter of 2 cm is between 90 to 100 turns of wire. In this case the small loop will be a maximum of about 20 cm range for highly accurate grinding point can be used. Compare to other pinpointer i've seen it has the deepest detection.
