  • BC547
    Better without auto correction:
    An alternative would be to place the 3 x 18650 in parallel and connect a cheap upconverter that can be adjusted to 12V.
    And a 5V USB C charger.​
    Something like this: adjust the output voltage to whatever you want
    https://www.amazon.com.be/-/nl/Step-up-voedingsadapter-Arduino-Raspberry-projecten/dp/B06ZYYC99S/ref=sr_1_18?crid=2X70L277N7P5J
    The main argument to not to use an upconverter would be switching noise.
  • BC547
    I always used a batterij pack of 3 x18650 in series.
    This gives you in theory 3 x 3.7 V = 11.1V.
    An alternative would be tobput thé 3 x 18650 in parallel and connect a cheap upconverter that can be adjudted tot 5V.
  • MDfanatic
    BC547 would it be better if the Pickini was powered with 3 x 18650 or by 4 x 18650?
  • BC547
    Alpi : you've got mail.
    You may have noticed that I removed the "Shop" page from my website for 2 reasons:
    1 / I am running out of 16F1824 and they are phasing out
    2a / I used to send every kit/controller via normal post mail. Not via DHL or other courier. In some countries, the normal mail proved to be "not so trustworthy" to put it mildly and some kits got lost in transit...
    2b / I don' have enough spare time to assemble these kits and put them into the mail anymore...
    You can still obtain the 16F1824 online.
    Then try to find somebody who has a PicKit3 progrmammer ( or buy one ) and download the hex file from my website: http://www.willaert.world/MD/software/v4/Pickini4.1.hex
  • Alpi
    Hi Bernhard
    Can I buy a microchip from you the 16F1824 with program pickini v4 for contact [email protected]
  • sbalio1
    Ok.kt315
  • kt315
    Originally posted by Reedick View Post
    Hi friend i try lm709 it works but the same problem sensivity decreassed
    you use obsolete and slowlest opamp in the world. it has 0.25V/us slew rate, just, compare with LF357 having 50V/us.
  • Reedick
  • BC547
    The coil resistance should not be 0 ohms, rather 0.5 ohms or more. This is just a check if the coil is not shorted = 0 ohm.
    But then you would get the 'coil error sound' = no flyback pulses detected.
    To put evertything on a timeline - please correct me if this is wrong:
    - you have built this PCB, connected a coil and everything worked fine ? Normal detection sensitivity ?
    - some time later, the sensitivity has decreased ?
    Can you check on pin 3 of the PIC16F1824 if the sensitivity setting is changing between 0 and 5V when you turn the sensitivity potmeter ?
    Also check the capacitor that is in parallel with the 1M feedback resistor of the opamp LM318. It should not be more than 4.7 pF.
    You can even remove this capacitor.
    Also check all DC voltages with a multimeter on each pin of the microcontroller and the opamp:
    The reference voltages are here:
  • Reedick
    Friend can you give me detail for coil. 30cm diameter ohm and mh.
    30cm=????ohm
    20cm=???? Ohm
  • Reedick
    Hi friend ihave detect sound but after that sensivity decreased. . This may image. Pcb
  • BC547
    This is the correct link to the coil error sound:
    http://www.willaert.world/MD/pickini...technical.html
  • BC547
    Can you also check your coil : measure it with an ohm meter ?
    Are you getting the startup sound and after that the idle sound ? Or the coil error sound ?
  • Reedick
    Iwell chow you my pcb
  • Reedick
    Hi F117 no it worked ok but sensivity coil decreased into . Detected nothing
