Hello!
i would like to try this build. Read all posts in this thread ,downloaded necessary files from link dantech suggested ,studying the schematic found some components missing ,i guess that those are the "unneeded" parts after the modification...Regarding the MCU i had an Atmega328 - not 328P - laying around my workshop ,wonder if this will work??I attached my STK500 loaded the hex file "main_en_ltd_m328" , fuses Extended=0xFF - High=0xD9 - Low=0xF7 and programmed the mcu without any fault messages .I have seen from another forum a guy selected totally different fuses ,only high and low same ,i guess for another hex..
Anyway ,engraved a test pcb out of "mainboard_keyboard_by_ozzy123_2nd_ChancePI_mod(3) " lay file (is this a working pcb???) and waiting for parts to try this build..A thing should be onboard is the ISP port for onboard programming as the original Chance..
