Looking for Goldscan 5c by Eric Foster schematic
Originally posted by eclipse View PostI have the C code for the MCU, it will need slight adjustment for this (or other circuit) but I believe it won't be hard.
I've tested it this summer and it worked.
Bad thing is I don't have proper timing diagram generated by GS 4.
Otherwise If someone is able to provide such, I can modify the source and supply some programmed PICs.
Components in red can be replaced by the MCU.
[ATTACH]37626[/ATTACH]
If you powered the micro with ground and -5 volts, couldnt you drive the fet gates directly ?
No you need level shifting. I usually use transistors or cd4504.
BTW I wouldn't trust my old posts in the forum so much.
I learned alot in the past year or two, I focused on RE some circuits like the TDI, JW X8, Manta V3 etc, appears the best way to learn something is to break something.
Originally posted by eclipse View PostNo you need level shifting. I usually use transistors or cd4504.
OK, thanks for reply
