Pulse Star II (first analog version)
  • #91
    Originally posted by profesor View Post
    hello KT315 and ivconic.I have an old pulse star 2 analog version. The charging circuit is defective.
    There were backplane pcb plans in the forum now I can't find it.
    Can you help for the charging circuit.
    thanks.
    hello amigo. good will be if you will send some pics of your boards. people are waiting from me full data on detectors archived
    in one global base. your put is hi appreciated. pleasure
    • #92
      I need Pulse Star 2 coil data. uH? Ohm?
      • #93
        Hi, my metal detector is broken. Please send me the diagram if anyone has it. Thank you
        Puls star pro
        I'm gmail. [email protected]
        • #94
          Puls star pro
          Evo odmah lisice��
          • #95
            Evo odmah lisice��
            English please.
            • #96
              schema pcb bro thax so much
              • #97
                Hello, does anyone have a pulse star pro metal detector circuit, please send it to me
                Gmail l'm; ali [email protected]
                • #98
                  I don't think anyone here has a usable schematic for the Pulse Star Pro.
                  • #99
                    The Pro Pulse Star 2 has two processors anyway so I don't believe the circuitry would get anything significant.
                    • https://www.youtube.com/watch?v=D2ZpA_nSVQo
                      https://www.youtube.com/watch?v=ynlg3g9Vako&t=4s
                      This project has surprisingly good behavior in areas full of garbage. Last year the author of this detector told me that he no longer uses semi-sine, because of the heavy and expensive coil - as if he knew that the price of copper will rise dramatically this spring ...
                      • guys, i got PS II with broken rotary switch. i did search and discovered it is 3P4T type, 3 pole 4 position. also, wafer switch google translate gives me.
                        can you give me a source to buy it? i see just 2 pole switches at chinese platform. Click image for larger version
                        • Comment
                          • Comment
                            • Digikey & Mouser have them, probably other big distys like Farnell. Also on eBay.
                                hi
                                https://eu.mouser.com/ProductDetail/...1nAUyKgw%3D%3D
