Regarding the pl5 schematic, my information is also incomplete. I checked its schematic before and saw some small problems. Due to the unknown number of some ICs, I left it aside.
I think that if the number of ics is identified, minor problems in its schematic circuits can be identified.
Pulse Star II (first analog version)
The good power of pl5 is due to its output transistor, and the better stability of ps2 is due to the use of a frequency crystal that minimizes the slippage of produced pulses
Thank you for sharing your useful experiences.
So far, a good conclusion has been obtained according to the practical experience, which was not far from the mind.
"The LP5 goes deeper and responds better to small targets, but it does not have the stability of the PS2".
If you have a correct and accurate Lorenz 5 circuit, please upload it.Originally posted by roshik View PostQuestion:
If we compare the schematic of this metal detector and Lorenz pulse5 metal detector, it seems that the design of this circuit is more professional, especially in the discrimination of metals, but the fet transistor used in the driver of the search coil, Here we have irf640, but in the Lorenz irfp460, (irfp460 is better than from irf640(power and other parameters of the transistor)).
Is it possible to say that in terms of discrimination , Pulse Star 2 is better than Lorenz Pulse 5, but in terms of depth of metal detection, lp5 is better than ps2?
Please, friends who had practical experience of using these two metal detectors, share their experiences.
I had both in my hands, for repair and for research in the field. You can't say that one is better than the other, each has its pros and cons. The LP5 goes deeper and responds better to small targets, but it does not have the stability of the PS2, so for areas like ours, Greece, the Balkans, etc., with a lot of rock with ore, and for easier use, I recommend the PS2,
the LP5 has no competitor in terms of deep and for northern Europe countries it is a far better choice.
First, there is no best PI metal detector. Each circuit has advantages and disadvantages. I had Pulse Star 2 years ago. Its separation section sometimes had errors and did not function accurately. Also, better separation has nothing to do with the type of output transistor. Pulse Star and Lorenz 5 are old designs. In new PI designs, using new techniques, the separation performance in the PI method has been improved.Originally posted by roshik View PostQuestion:
If you are looking for a better resolution... Pulse Star and Lorenz 5 are not responsive.
Question:
[КУОТЕ=росхик;н429231]хвала Орбита
Али у шеми, сигнал оба транзистора је из једне тачке.[/КУОТЕ]
Жао нам је што иде преко 10к отпорника до базе бц 327 са Цон 3.Attached Files
hank you Orbit
But in the schematic, the signal of both transistors is from one point.
One shines on iron, the other on noble, the instructions state that discrimination works for objects larger than 10cm! Although in practice we cannot rely on discrimination. This also applies to Puls Star 2 Pro!The signal for iron comes from the main channel from the mother board, and for precious metals from the small board, it is connected to the base bc 337, where the input is also for all metal, i.e. iron!
Hello everyone
In the upper and left side of the schematic of the main circuit of the metal detector, there are two led that are controlled by two bc327 transistors. Considering that the circuits of these two are exactly the same, what is the reason for using two diodes and for what purpose?
THANK SO MUCH TO MR ORBIT MR IVONIC MR K315 AND FOR EVERYBADY WHO PARTICIPATED IN PROVIDING HELP
