Originally posted by Belief
Tests in the video were made with 450 Hz
The component values are according to the diagram on page 33 of the forum with some modifications I mentioned earlier.
I have no instrument for measuring the coil uH
Do not perform tests of maximum detection distance.
The power is 12 volts
For the original Delta Pulse frequency is 100 or 120 Hz Roll 1.2 * 1.2 meters and 300 Hz Roll 45 * 45 Cm.
My advice is to experiment with smaller coils, then when you are familiar with your detector may attempt to modify the frequency and the delay time to obtain the maximum benefit of its MD.
Greetings
when power supply is 9V led is ON when 12V the led doesn't lights! (i used double face PCB) hop this helps to fix my problem
and it's always making a continues loud sound from head phone though TRSHOLD is at the MINIMUM!! I can't make it silent!! (when TRSHOLD is at maxmimum it sound like a sirene)
