Originally posted by RS_Phil
Delta Pulse
The greater the damping resistance of the coil, the greater the resistance the or reduce? Who can tell me, thank you
PNow the detector is working, there was just a stupid mistake- one IC wasn't installed properly.Originally posted by Davis9000 View PostHello! I made Delta Pulse detector(I used KT315 designed board), made test coil(12 cm diameter and 36 turns of 0.4 mm wire). I got constant sound from speaker, but no reply to metal objects, when i connect oscilloscope to the testpoint T1 in schematic(output of the preamp), I can see there reaction to metal objects. I also checked T3, T4 and T5 with oscilloscope, these were ok. What should I get at T6 and T7 and what should I check?
It is best to ignore all such requestsOriginally posted by kt315 View PostGeorge, those chineses crap overloaded my email box by bare spam requests to give them 'deeper detector on gold on 3 meters depth'.
so let me overload those bad guys by something they are served up too. they always only ask but never give useful info in the exchange.
i got 1-3 messages everyday!
yours
or tell them to post their questions in the forum. Otherwise the questions will be endless.
yours
aojieage was not promoting Delta Pulse. He was advertising the Chinese website TaoBao.Originally posted by kt315 View PostDelta Pulse does not needed in additional advertising. Delta Pulse is the perfect working deeper impulse detector released and checked in
thousands copies worldwide.
Following a complaint from another Geotech member, I have to remind you:Originally posted by aojieage View Post
The Tech Forum is for general tech discussions on all types of metal detectors: VLF, PI, 2-box, BFO, off-resonance, PLL, etc. Questions, ideas, and anything else that moves you. ..... BUT, not advertising.
Please us the Free Advertising section.
on a spot R37 R41 you have to see a level slight low than zero with some low freq noise.
then bring a metal and you have to see encrease of the level above zero volt.
