Delta Pulse
  • kt315
    irf820
    will work on low PULSE WIDTH. on 500usec may be burn. 820 has very low current - 2,5A vs 10A of IRF740.
  • kt315
    the table had been uploaded probably 10s times.
  • yhl
    The parameter I need a one meter coil
  • kt315
    here is for M. a pic with coil from pvc. this pic is NOT MINE and not mine coil. only as an example.
  • kt315
    about DP http://garimpeirosamadores.blogspot....-caseiros.html
  • kt315
  • kt315
    some pics not mine DP with big coil
  • kt315
    Wow That's the first time I have heard that. I though higher inductance was used
    for big objects or deep detection (like 1mx1m coils). You would miss small objects
    as the higher inductance has greater resistance to change so needs to be pulsed
    slower....
    Eric Foster: My Beachscan uses a coil of 1mH as does the C.Scope CS7 and CS6PI.
  • kt315
    not. TOO LOW SPEED.
    all substitute HERE in Bill of The Material.
    DP_part_list.txt
  • seadoggy
    LF357 can substitute with TL071???
  • jladre
    ANY experiments with big coil in the room will end in unsuccess. be cause you have huge amount of EMF influence and metal armature around you.
    I wrote about this many times but people again and again try check DP with 1x1m coil in the kitchen.
    Tnx kt315...peace... i try to test it in the garden tommorow..
  • kt315
  • jladre
    Got problem on 1x1m coil.. when i plug 1x1meter coil 6ohms, 385uh to the dp the sounds from the speaker become weak and even any adjustment of the pots i cannot get detection.. dp works well in smaller coil. What would be the problem?
  • mohandes
    when i connect coil LCD response very bad for adjust but without coil well.so is ok?
    battery adjust well and next CW TR1 to see full (i see it next push zero) but when i ccw TR1 don't show full to set it, how can i adjust.
    please any one help
    i wait.
  • mohandes
    for adjust LCD ,i cant set best point for discrimination .how i do this .i see turkey video but in final set by copper and iron i dont understand please help;
    by 18f252 my means.
