Delta Pulse
  • pigeon
    sz, can you draw these points A...E on the schematic? tia
    hi
    please where's the emplacement for r50and r51 in the pcb
    thank you best regards
    p.
  • pigeon
    Originally posted by freedan3d View Post
    no szucs_g. p6 and p7 that i show on pcb and schematic use for lcd
    I attached some file for that lcd.I have delta pulse dircriminator lcd circuit too .i can upload here if you want
    freedan3d
    Hi all
    It is possible to use the original lcd discrimination for delta pulse klasik if so can you give me location of p1/p2/p3/p4/p5/and p9
    Thank you very much
  • jap
    Hi Nikolov
    use Coil Calculator by Qiaozhi its good tool.
    -small coil for small ,start 23cm coil.
    best time
    j.
  • Nikolov
    yes they are same, what round coil is your advise for delta pulse 28cm maybe?? or.....
    1x1 is huge for operating I want something small
    tnx
  • jap
    Hi Nikolov
    The 2 coil 1x1m square , 32cm are same L...mh
    best time
    j.
  • Nikolov
    1x1m. Wind 17 turns. Use wire with 1mm diameter. If the DC resistance is lower than 2.5 Ohm then connect a resistance in series, so to measure at the connector a dc resistance of 3.5 ohm (3 ... to 4 ohm is ok)
    for example coca cola can about 1-1.2m
    Thanks JAP
  • jap
    Hi Nikolov
    -what is specifications of u 1x1m square coil? the deep?
    -coil 32 cm 0.5 mm 32 turn =adsl cat5 or cat 6 4x8turn ...4.6 ohm .
    best time
    j.
  • Nikolov
    Hello my friends
    I have Delta pulse with 1x1m square coil, but I want to build round coil with D=32cm what is the best specifications? how many turns, wire diameters, resistance.
  • jap
    Hi hadi-dindar
    Use another type or Use CAT6(Belden_Cat_6_)
    best time
    j.
  • hadi-dindar
    Originally posted by jap View Post
    Hi hadi-dindar
    The kind that you badly - Use another type.
    best time
    j.
    tnx bro
    i user cat5-e cable
    cat5-e cable 4utp yd/t926.2
  • jap
    Hi hadi-dindar
    best time
    j.
  • hadi-dindar
    hi all freinds
    so sorry for my question there
    i have a cat-5e cable - network cable
    when i create a coil 40cm with 3turn cat5 cable and conect the wire i have 15ohm in coil
    for example i have 2ohm resistance in reed branch .
    plz help me
  • supermen
    Thanks Japanese for the answer, you're always there when we need help,
    Greetings
  • jap
    Hi supermen
    -coil 30 cm 0.5 mm 32 turn =adsl cat5 4x8turn ...4.6 ohm .
    best time
    j.
  • supermen
    Hello Japanese
    What is the best coil 30cm diameter???
