Delta Pulse
  • szucs_g
    Originally posted by hadi-dindar View Post
    I cant understand you Purpose about +e and _e
    i have 10*1.2v=12v buttry
    and i have 320hz freq in pin 9 ic 556 without coil.
    plz explain about buttry value
    tnx
    Very good, how you distribute a frequency the Tr3-on. The two 1N4148 they are properly? Your coil may not be bad. Unless does not close ranks the two cables. This has to work. The two diodes were smoking at me away once, when I fastened a one 2,4 aH battery to the electronics. Why? Don't ask, i don't know.
  • Nicolas
    Hi Sparky
    I join all-round shema for you
    do you even create a table
    or you are Lazy
    Sorry we d'ont have
    Best time
    Nicolas
  • sparky
    Parts assignment sheet for 7 knob Turkish Delta Pulse?
    Originally posted by Nicolas View Post
    Originally Posted by sparky
    Does anyone have parts placement sheet or schematic for the 7 knob Turkish delta pulse? I found the 6 knob but it's not close enough.
    Attachment 21305
    [ATTACH]21306[/ATTACH][ATTACH]21307[/ATTACH]
    Do you have something like this? It would be much easier to assemble if I had an assignment sheet.
  • hadi-dindar
    tnx
  • szucs_g
    +E, -E are correct value? The first is this. Is 556 working?
  • jap
    Hi hadi-dindar
    -coil 40 cm 0.5 mm 24 turn =adsl cat5 3x8turn ...2.6 ohm
    Put pictures of the project
    best time
    j.
  • hadi-dindar
    hi jap.
    i changed 840 and 556 and t9
    but Not true my dear.
    can you help my to crate a pefrect coil for my set ? and i have only 680ohm . 1w nad 1.5k 2w resistance for r5,r6 .
  • jap
    Hi hadi-dindar
    -Is irf840 is hot now ?
    -change Q1=IRF740 OR 840
    -change D1=UA556
    -Tested and check T9
    best time
    j.
  • Nicolas
    [ATTACH]21305[/ATTACH]
    Look it.
    Green circle for Plot or Knob
    Red Circle Connection LCD with PIC 18f252
    Best time
    N.
    Delta pulse _ema (1).pdfClick image for larger version
  • sparky
  • szucs_g
    Prepare a picture from IRF neighbourhood. I revised it the sch. It may be IRF only according to me, if without a coil not short-circuit.
    My little coil big like Garett coil. http://n1.vatera.hu/photos/6a/2f/9d16_1_big.jpg
    450uH, 3,4 Ohm and work fine.
    The frequencies is ca. 500Hz. If the freq. low the IRF warming with low resistant coil.
  • hadi-dindar
    Originally posted by jap View Post
    Hi hadi-dindar
    R5=1.2K~ 1.5k ~ 2.2k /1w
    r6=680,R7=15K
    -IF coil resistance 3.4 ohm add in series to coil 2.2 ohm/1w
    best time
    j.
    hi my dear . jap
    my r5 now is 1.5k 2w and r6=680ohm 1w
    but not work
    and current in circuit is zero
    and my coil ohms is 3.4 ohm
    3.4 ohm is match with informations ( r6 and r5 ) ?
  • Nicolas
    Hi hadi-dindar
    In this case it is necessary that your coil is 6.2 Ohm
    as he explained our dear Jap
    And checked the transistor BC 557 I had this problem
    made to change the IRF 740 by another 840
    best time
    N.
  • jap
    Hi hadi-dindar
    r6=680,R7=15K
    best time
    j.
  • hadi-dindar
    Hi hadi-dindar
    ( wire 0.8 with cat5 cable ) (cat5 cable not 0.8 is 0.5mm)
    R5=680~1.2k /1w
    r6=1k
    -IF coil resistance 3.4 ohm add in series to coil 2.2/1w
    best time
    j.
    bro i have one 1.5k 2w resistor /
    can i add this resistor inistate of 680ohm with 3.4 ohm coil ?
