MY DELTA PULSE
my delta pulse emit a continued sound, when I press the RESET the sound fall down but after 5 seconds it apear again (a continus sound). what the problem?
Delta Pulse
I'm glad I asked but I'm still a little bit confused.Originally posted by tuxnor View PostC30 4700uF
C31 4700uF
C32 4700uF
ST TH1210D is specialty diode for T1 [IRF740]
Ahhh i see is a substitute for irf740 or the other way..case closed
Maybe the FR diode is not meant to replace the IRF740 but is suggested to be placed across the IRF740 to help reduce the flyback time?
Just a guess.
Think about it - you simply cannot replace the IRF740 with a diode. No how, no way. Or, at least I don't think so. But, putting a FR diode (in reverse) in parallel from source to drain would help reduce flyback time. IRF740 already has a reverse connected diode from S to D. Adding an FR diode would speed things up a little bit.
Even better might be to use a MOSFET that already has FR diode. I know of only one such MOSFET at this time, but I am sure there must be others.
I found this only by accident:
STF12NM50ND has FR diode: http://www.st.com/stonline/products/...e/ds/14936.pdf
STF12NM50N has a slower diode but is, apparently, otherwise identical:
I am interested in the FR diode version but unfortunately the TO220 package is not stocked by my favorite distributer, only Dpak or DDpak are stocked. I will search some more when I get time, or maybe try the DDpak in my project (if it ever gets to that stage of completion).
Without having the exact diagram to go along with the parts list you posted I don't know where two of the 4700uF capacitors go. I can only find one 4700uF on my DP schematic. Maybe they are all supposed to be in parallel, which would provide 3x the filtering; a very good idea.
Here is a link to the STTH1210D. http://www.st.com/stonline/products/...4/stth1210.pdf
tuxnor, what you are probably wanting to do is stick to the original DP schematic but add one FR diode across the IRF740, and add two 4700uf capacitors across the one that's already there. (?!) Be sure and connect the FR diode in reverse, or else it will muck things up and won't last very long.
Maaan .sorry for unconsisient fierematches..Originally posted by porkluvr View PostGolly. Nothing like being SPECIFIC. "Some forums"?
What forums??
Found at Thehunthing and on some googling where other ask about it..
i tryed to get a answear on thehunthing where eugne is most
but without any luck
I have ordred all components after this list..before i study schema and pcblay
Delta Pulse parts list re-written by Eugene 11-19-09
C1 22nF
C2 1nF
C3 10nF ok ny og brukt
C4 1.5nF
C5 1.5nF
C6 1.5nF
C7 1000µF electrolytic ok 1
C8 10µF
C9 100nF Polyester film***** bestill
C10 100nF
C11 100nF
C12 100µF
C13 15pF ok bestilt 3
C14 100nF
C15 100nF
C16 100nF
C17 47pF
C18 100nF
C19 100nF
C20 100nF
C21 10µF ok 10+++
C22 100nF
C23 100nF
C24 100nF
C25 220nF
C26 47nF
C27 220µF ok 2
C28 100nF
C29 100µF ok 10++ ny
C30 4700uF
C31 4700uF
C32 4700uF
D1 LM556 ok fra kina
D2 4538 ok bestilt 2 stk
D3 4538 ok 2 stk
D4 LF357 ok fra kina
D5 TL062 ok bestilt
D6 TL062
D7 TL062
D8 NE555 ok
D9 4066 ok bestilt
D10 4066 ok bestilt
PR1 250k
P1 50k
P2 500k
P3 20k
P4 20k
P5 10k
P6 10k
R1 470k
R4 5k6
R5 680 1 Watt
R7 15k
R8 27k
R9 68k
R10 100k
R11 100k
R15 820
R17 120k
R18 120k
R28 56k
R31 5k6
R32 330
R34 22k
R35 5k6
R36 56k
R37 560
R42 22k
R44 330
R48 8k2
R50 1 Ohm 0.25 Watt
R2 6k8 ok 3stk
R3 47k ok 50
R21 47k ok 50
R22 47k ok50
R33 4k7 ok 50 stk
R49 1k ok 50 stk
R45 39 ok 5 stk 0.6w+ 2 stk problå 1%
R46 2,2 ok 5stk**************************
R40 12k ok 50 stk
R41 6k8 ok 5stk
R23 4k7 use 1% precision ok 50 stk
R24 4k7 use 1% precision ok 50
R25 4k7 use 1% precision ok 50
R26 4k7 use 1% precision ok 50
R27 4k7 ok 50 stk
R29 1M ok 50 stk
R30 1M ok 50 stk
R6 1k ok 50 stk
R16 12k ok 50 stk
R12 10k ok 5stk
R13 10k ok 5 stk
R38 10k ok 5 stk
R14 1k ok 50 stk
R47 1k ok 50 stk
R39 1k ok 50 stk
R19 4k7 ok 50 stk
R20 2k2ok 50 stk
' R43 6k8 ok 5 stk***************¨'
T1 IRF740 ok alle tr
T2 BC546 ok alle
T3 BC557 ok alle
T4 BC546
T5 BC546
T6 BC546
T7 BC546
T8 BC546
T9 BC557
T10 BC557
VD1 1N4148 ok alle diode
VD2 1N4148
VD3 1N4148
VD4 1N4148
VD5 1N4148
VD6 1N4148
VD7 1N4001
VD8 1N4148
VD9 1N4148
VD10 1N4148
VD11 1N4148
VD12 1N4148
VD13 1N4148
VD14 Zener 8V2 ok bestilt 2
VD15 Zener 9V1 ok bestilt 3
VD16 red color LED
VD17 green color LED
Golly. Nothing like being SPECIFIC. "Some forums"?Originally posted by tuxnor View Postwhat is all this about STTH1210D and 3 x 4700uf caps on some forums?? i cant find where it shall be on any deltapulse component overlay either on any schema i have untill now..
Ken jørgensen
Rossfjord avel
What forums??
Originally posted by kt315 View Postthinking, but not so clearly, you can find an analog of the diode, Ultrafast Recovery I look in datasheet, in any CRT oldie type PC monitors. I need to take a time-out for deep learning of this matter.
OK ...Thanks KT315 .
i am clean now hearing that ,,i have thrown home in norway,,1000+ crt´s
use to have a computer and gameconsole shop with service,chipping,soldering,etc..
but where is placement of this diode..is it over 10.000 cab where there is used a 1n4001 now on last schema ?
Anyone have "the old" schema where STTH is mentioend
and is it only on 2 sides pcb where it was used ??
1n4937 is faaast
I can get my hands a STTH diode without problem and would like to use it as suggested ..sorry for beeing stubborn,but is it best for deltapulse curcit
then i would like to use it..
Hello my czech friend ..yes its legal in Norway ,,but not here in swedenOriginally posted by SIBI View PostHi Tuxnor,
I have a question, is metaldetecting in Norsk ilegal or not? Is dificult for me to find a job there? I´m from czech republic. My girlfriend love this country.
you need a premission for area, and what you are looking for,,
so i have bought a mineraldetector
ar924 for use in prospecting here in sweden..so i may go around law ,,last time i asked premission from consil
office here,,they said yes and they did hardly know;n what a metaldetector is
I tell you this ,,its easyer to get a work in norway than sweden..depence on your proffesion of course..and its expencive in norway,,i moved to sweden
thinking, but not so clearly, you can find an analog of the diode, Ultrafast Recovery I look in datasheet, in any CRT oldie type PC monitors. I need to take a time-out for deep learning of this matter.Originally posted by tuxnor View Postwhat is all this about STTH1210D and 3 x 4700uf caps on some forums?? i cant find where it shall be on any deltapulse component overlay either on any schema i have untill now..
.what happend ?
I have not been in the shower since christmas because of this headpain.STTH1210D.so please answer somone so i can go to my bathroom and take a bath
.i am also making the 2 side delta pulse
after this singel side pcb
i am ordering STTH1210D from my contakt in china..so if anyone need hard to get components i can help members here worldwide
i succesfully got all my lf 357 and lm556 from china a week ago
Ken jørgensen
Rossfjord avel
greetings!Originally posted by che View Posthi to all
This is the first post im from lebanon im hobby electronique
i have built this circuit
, but
they emit continuous beeps
Can anyone help me please To work well
I have used coil 60cm 0.5 mm and 25turn 7.5 ohm
What should I do
unfortunately not know the English language(40 page
if you press the knob RESET (or PRESET) the sound would fall down in few seconds. if not - you have a problem. if yes, the sound falls down to zero level, then you begin to turn THRESHOLD pot before a moment the sound will reveal again in staccato style. then you slightly turn it back before the sound must be dissapear to zero again. you did get the tuning and can go to hunter out
try.
KT315: I must make my coil stabil and make some more tests. When i was testing before, it takes 1.5 M x 1M (i don´t know that word in eglish for it
) for 3 M with strong sound.
Hi Tuxnor,
hi to all
, but
What should I do
delta pulse
.what happend ?
Ken jørgensen
Rossfjord avel
you draw a problem why White's deleted CAVE mode from his new TM-808. why some guru leaves only 2 pots at panel, like Eric Foster in his PI detectors. for idiots many pots at panel go to an head illness only! althought you have 101 keys on your PC keybord and do not ask people of MICROSOFT why them are so muchOriginally posted by SIBI View PostHi, how do you tune DP in field? I don´t know, what to do. If i put pots to 0, then my DP beeps, when to max, sound disapears
And detection is poor. I have 1x1 m coil, 15 turns, 0,7mm wire
