My AGD analog detector work
  • I never seem to get the name of the AGD26.1 signal processor circuit board correct. But here is a picture of the circuit board I will use for testing and continuation of coding work for the 128 pin STM32 MPU. I made this board the same size as the front end board for now and may move the lower mounting holes upward and trim it down to smaller size. Close to 4.1 inch wide and 4.75 in height.
    The programming JTAG connector towards the upper left will be accessible through a access hole in the side of the enclosure. Once it this board is assembled and programmed the front end board gain will be adjusted so that everything plays together nicely.
    Below is my current circuit diagram for this circuit board.
    [ATTACH]n449377[/ATTACH]
    • I really like using individual controls for controlling my detectors and this version of my AGD26 detector is intended to fit inside my existing enclosures. They provide good RF shielding and weight just about the right amount to balance a completed detector with coil attached. The front panel control panel is getting a new layout since there are more switches now that will interface with the MPU. I designed a new front panel circuit board for the 26.1 version as shown below.
      All the switches and controls mount to the back side of this PCB, it them mounts as an assembly to the 1/8 inch aluminum front panel. It interconnects to the signal processor board via wires that feed from the back side of the circuit broad and exit the board through the holes marked FP1, FP2 and FP3. Solder pads are provided to solder the wires into, FP1, a dual row 12 pin, FP2 and 6 pin vertical, and a 3 pin vertical that still as a small old FP1 label but is FP3 just for switching between internal speaker and headphone. This is simple circuit board and receives 3.3V dc from the signal processor board for the digital switch interfaces, and a 2.048 ADC reference voltage for handling the analog seven 2.5K linear controls. Their output voltages is routed to one of the STM32G474 MPU 12 bit ADC's, over sampled, averaged and the scaled as required. scaled.
      The controls are intended to provide some adjustment range to, TX pulse width, channel 1 gate width, and channel gate width. For channel 2 gating there is a second control that allows for moving is gate period left and right. This is called CH2-Slide. The AGD26.1 always uses the the TX coil for its channel 1 receive signal. If a coil such as a DD coil is connected it can be operated like a MONO coil. Channel 2 can be switched to use the separate build in receive pre-amp to utilize the coils separate winding. Thus while in DD mode it can use both coils during the receive period. The DD-PRE switch handles that function.
      The main signal processing is done by two 16bit ADC's, One for each channel. I'm sitll using the sample and hold circuit as in my prior detectors since the output of these also control the front ends board DC offsets. The sample and hold circuit adds a second receive gate which has a fast raw signal output and a filtered slower output, the sample and hold value for the gated period. I have added a switch to allow selection of which signal gets processed the the two 16 bit ADC's. Switching to that function is by front panel switch, SIG-SRC.
      The MPU witll be programmed to have a default configuration which will be able to be modified via user control by setting the MAN-DISC switch on the front panel. Doing so makes the RATIO control active to allow for variable mixing of the two channel. Inverting channel 2 will be possible by using the CH2-INVERT switch on the front panel.
      Most of these things are to get a bit more flexibility, time will tell if they will be beneficial or not. My diagram for the front panel does not show parts values but are 0.1uf caps, 1k resistors, 2.5K linear pots and bat handled toggle switches.
      Here is the file in PDF format.
      [ATTACH]n449470[/ATTACH]
      • Congratulations!
        I have never seen a man who is so systematic, orderly and detailed.
        But here I am looking... the date you started the topic is 03-03-2023.. and today is 06-12-2026.
        Over 3 years on, we still haven't seen that detector in action... I wonder; do you also buy components on Aliexpress!??
        • ivconic: I have purchased from Aliexpress​ in the past but don't recall what I purchased. My usual parts source is Digikey, Mouser being second. For all other things that they do not carry it is internet search until I find something suitable.
          Back to the AGD26.1 work
          Back in 2023 I got interested in building a PI based metal detector without knowing anything about them. Since then I have built a lot of them and used each one to make improvements a bit at a time. I still use my AGD24.1A version that has damping resistor changes, and first receive stage and channel amps changes. The development work did not end there it has continued with focus on pulse generation, coil damping and very first receive gain stage. Every thing else depends on how well a detector will work. The nice thing is that the pulsar, damping and first gain stage can be simulated very accurately. Simulations can give great results, but poor circuit board layout and design can completely wreck those results. All this takes time, and even with great care problems can be expected to occur that require a bit of rework.
          Time to some of the mechanical work that needs to be completed:
          I got my drawings completed for modifications for two of my older enclosures,and their front and rear panels. I also drew out the shield that will go over the part of the TX section or the front end board. This will also be used as a heat sink to help control the heat generated by the three 2.5K 3W resistors.
          Some times when thinking about the retirements for a PI metal detector it may be beneficial to think of it as being two delay lines which sync to a common trigger point, the end of the TX pulse. This starts the decay of not only the TX coil but also the targets signal. The delay line concept is what decayed those two two out until they reach the zero signal point. Drawing a chart helps to clarify a bit between TX coil decay and targets signal decay slope.
          In the small chart below I set the known requirement to detect 0.015 gram of gold in my AGD24.2 detectors to have a decay time of about 3.9us after the TX pulse ends. It also shows the approximate 2.5us decay point of the AGD26.1. The targets return signal decay slope is still much higher at the 2.5us point than the 3.9us point. Just a bit further that 4us the targets return voltage becomes zero and no longer delectable. One additional thing that needs to be considered if speed. If the gain stages are two slow the signal to be processed may not be able to get properly time aligned.
          There are various ways at looking at the signal relationships in a PI detector, I like to use something like the below chart:
          Click image for larger version  Name:	The-Two-PI-Detector-DelayLines.png Views:	0 Size:	71.1 KB ID:	449577
          • ".. Simulations can give great results, but poor circuit board layout and design can completely wreck those results..."
            Ok, clearly, I see that you have set yourself high goals and ambitions, sampling below 5uS is already something that exceeds ordinary DIY possibilities.
            Although you wrote a lot of text and gave a lot of schematic parts and the appearance of your pcbs is outstanding...
            still I didn't have the patience to read everything so I apologize for asking something that you may have already answered in your posts;
            Besides the ambitions of sampling below 5uS, does your detector have GEB and DISC?
            All the effort you put in would be pretty pointless without even a GEB option.
            A video demonstration does not have to prove anything, but it can still tell a lot to an experienced eye. And that is what is missing from this thread.
            When I initially asked you to make a video; I didn't mean to watch something pointless, but to get a basic sense of how that detector works.
            If you followed closely other topics on the forum; you would have seen my sporadic resistance to most of the videos on Youtube,
            which prove nothing and have the ambition to prove something.
            But especially in this case, a good video is what we need here. Not to criticize and mock - but to get a basic sense of how it works.
            Your high commitment to your project, as well as the many articles you have written so far, are worthy of attention.
            But you have to understand that we live in a modern age when the story is incomplete if we don't have a video experience.
            • GEB is basically and change in the detectors zero reference level. To speed up this adjustment individuals generally move the detectors up and down to regenerate a larger difference voltage which aids in resetting the zero reference level a bit faster. Generally this is done automatically through design, it usually just takes a bit longer. DISC is a bit more complicated, and can use early or late signal mixing. Detectors that have built in digital processors can use more complex methods if they have built in math processing abilities. My AGD analog detectors have always included my version of GEB as shown in the circuit diagrams. It is done automatically.
              The AGD detectors are meant to be used to find very small gold and have undergone changes that improved performance a bit at a time. In considering those changes I would have to say that more attention has been paid to TX coil decay time, which also requires greater dynamic range in the receive gain stages. Most all my postings have been related to the technical aspects. The signal processing board with its MPU will further improve the detectors performance. The combination of the high performance front end and the future digital processing addition will offer great flexibility via firmware code changes.
              My post are of a technical nature and not a story. The technical content may be beneficial or not, but it is is open to comment and it is hoped that others experiment with the concepts and circuitry that I use or describe, and perhaps offer suggestions on how I could improve those further. I do not have a lot of spare time to monitor the forum so it is best to contact me via message.
              According to UPS the two main circuit boards for the AGD26.1 should arrive by 9PM tomorrow. While waiting for those to arrive I updated my parts stock and worked on the changes required to my enclosure. Here are some pictures of that work.
              Click image for larger version  Name:	Enclosure-Parts.png Views:	0 Size:	369.2 KB ID:	449875
              Back side of front and rear panels showing anti rotation pockets for the switches and pots.
              Click image for larger version  Name:	Back-Side- Front-Rear-Panels.png Views:	0 Size:	366.7 KB ID:	449876
              I was just going to put a shield plate over the TX section but changed that to have a bit of heat sink ability. To use this the three three watt coil delay load resistors would need to stand off the board 0.125 inch and the a 3mm thigh silicon pad placed between the resistors and heat sink. In the picture below I show it attached to a early engineering development circuit board. The slots in the heat sink will be at a slight upward angle when the detector to be is sweeping the ground. If I make more of these heat sinks I would rotate the slots 90 degrees.
              Click image for larger version  Name:	TX-Shield.png Views:	0 Size:	475.9 KB ID:	449877
              Last edited by Auto-Mation-Assist; 06-22-2026, 06:05 AM. Reason: Eleinate letter and added comment.
