Hello everyone!
I'm sharing this because I believe no one should go through the waste of time, money and energy which I had over this!! I also would like to thank everyone who's been making this forum the way it is. THANK YOU from the bottom of my heart. I've been learning a lot from you guys.
Before we begin, I should tell you that I'm not an expert in electronics. I'm more like a learner from mistakes kind of guy
Here we go:
A,B,C numbers have to be at their correct values which will eventually lead to a correct value of the Automated Delay.
A = Ideally 300, however any number between 200 to 400 is fine
B = Ideally 700, but any number around it is ok
C = Ideally 800, but any number around it is ok
Automatic Delay = Ideally 20, but any value from18 to 22 is perfect, and you will get it right once you adjust the A,B, C values.
To do so, follow the below steps in order:
A few words on Felezjoo Pi:
Happy hunting everyone!
Here we go:
- Assuming the pcb components are with the designated values, check pin# 23 of the microcontroller with your oscilloscope (not a multimeter) and it should be 4.8V (between 4.75 and 4.85 volts) if it is not, you need to change R8 (1K8. To increase voltage you lower the resistance, and you do the opposite if you need to decrease the voltage. In my case,
R8= 1.75 K and now voltage is 4.84v. Now you should notice an effect in the "A" value but keep in mind that is not its final value. - Replace R9 (1M) with 1 mega potentiometer then turn the device on while the coil is connected to it. And start lowering the potentiometer to increase all of the three numbers but keep an eye mainly on "B" until you get it to its sweet spot. In my case, my numbers were about (170, 580 and 690) and I had to lower R9 to 560K to get (299, 700 and 802) and my amplifier is (LF157N). So if your numbers are higher than their supposed values, Instead of replacing R9, I would assume you need to connect a 500k potentiometer in series with R9 and start increasing resistance to lower the ABC values. (Do this step away from any metal objects even if it is not detected by the coil it still can affect the values)
* Now with the corrected ABC values the automatic delay should be between 18 to 22. And with this, iron discrimination should be functioning. - If your device is giving too much false signals, try to lower the sensitivity setting and see if that works out for you (this was my case). If it does not, replace R10 (100 ohms) with a higher value which I do not know by how much since it was enough for me to lower the sensitivity setting, but I would've increased the resistance staring from 150 ohms up 300 ohms or so. I mean until I gain a complete control to get rid of the false signals by using the device settings).
- Since I did not have to change R10, I'm not sure whether it has a significant effect on ABC values or not. If it does, go ahead and repeat step# 2. Also, double check pin# 23 of the microcontroller before soldering your new resistances.
- This project is worth making due to its uniqueness in features and simplicity in components. Thanks to its maker and if he ever come across here I would like to say : Thank you so much Mr. Hamid!!
- Throughout my search on the internet, I found some people suggest to replace R11 with a potentiometer to increase/decrease ABC values and sure enough it does change the values especially "A", but once the detector recalibrates itself every time you turn it on or when you exit the settings menu, the values go back to where they were.
- The pre-amp you are using is not necessarily fake just because you didn't get the right ABC values by using it for the first time. Take it from someone who bought so many amplifiers to the point where he is thinking now to open an LF357 store
- It's preferred to the you make your final coil first, so you can optimize your device to it with the steps above.
- I do not recommend the pcb version I used (see photo attached) because it lacks enough space for the mosfet and regulators to have heat sinks, and for some of the components to not be in touch with each others, which I think it affects the detector performance.
