Surf pi detector-MOD
  • Surf pi detector-MOD
    After 20 years since its appearance, the Surf Pi remains one of the best pulse induction detectors. It has two minor problems that can be easily fixed. The reason for the first is the reverse-connected diode in the transistor type 32 Click image for larger version
ID:	436902 . It changes the smoothing of the reverse voltage in the search coil. This is important for small time delays of gating. The best option is to replace the Darlington transistor type 32 with a MOSFET IRF 9640. To work reliably, it must be controlled with a voltage greater than 6 volts. The most suitable is a direct connection to the 555 timer. The transistor driver has been changed to work in a simplified mode and controls only the creation of strobes. Another problem with the Surf Pi is the use of a speaker instead of headphones. The sound output is active during the closing of the second gating switch of the integrator. This leads to the creation of electromagnetic interference in the receiver. Interference in the power supply is also obtained. The key that modulates the sound output slightly disrupts the work of the integrator. It is differential, but there is a problem. The reason is the leakage currents in the integrated circuit CD 4066. There are four separate keys on the diagram, but in reality this is one crystal. A very good result is obtained when the sound modulator is implemented with a separate transistor. At the same time, the sound is created after the second strobe and the creation of interference is avoided. Surf Pi began to work much better. I hope everyone will like it. Click image for larger version
    Have a look at the Arduino Nano Pulse Induction Metal Detector Project -> Arduino Nano Pulse Induction Metal Detector Project - Published March 2021
    This fixes the problems of the Surf-PI and provides better results.
      Thanks for the advice. A friend made an Arduino Nano, a really good project. But these are two different detectors - digital and analog. I have seen that analog ones in practice give more even results. They show weak signals better and are more informative. I repeat that this is my opinion.
        It is true that digital detectors have less detail and are not difficult to make. Analog detectors have a lot of detail and are difficult to repeat.​
          Hi scs-bg,
          You are at the beginning of the design of PI detectors, but do not be discouraged - all future knowledge is ahead of you! All we started from a not very big starting point. Ask and do, ask and do!
          The TIP32C transistor is not Darlington type and haven't internal diode. This is not the problem of the first variants of Surf PI detector, but it is good that you start to analyze this schematic and to start implanting of your ideas . ​
            You correctly noticed about the transistor tip32, the mistake was mine. With the MOSET the circuit works well. As with the speaker.​
              congratulations!
                Thank you!!
                  Originally posted by Detectorist#1 View Post
                  Hi scs-bg,
                  You are at the beginning of the design of PI detectors ​
                  Hey Detectorist#1,
                  I think the boy is not starting now, but is quite deep into things.
                  I also think that you are both smart guys, and you would communicate each to other very well without using English, even more so I think that you are both MD producers (maybe I'm wrong, but I have such a feeling).​
                    Please do not create unnecessary disputes. In this case, the mistake is mine. Anyone can make a mistake. I was under the impression that the transistor type 32 has a reverse-connected diode. By analogy with type 122 or 127 for example. This does not matter for the published modification. It works very well.
                      So I was wrong again.
                      Accept my apologies.
                        I am not a producer of MD. I am professionally involved in electronics. In this case, detectors are a hobby, I do not make money from it.​
                          This is a forum for amateurs. I don't intend to pretend to be great. I think the creators of Magnum and Whites 3 Classic are great.
                            Hi scs-bg,
                            Don't be angry to boilcoil. The idea for direct contact here, in BG is not so bad. He only wants to help us in this hobby. I'm also not manufacturer - only hobbyist.
                              Thank you for your good behavior.
