The step by step build of the Delta Pulse Rev. 5
  • The step by step build of the Delta Pulse Rev. 5
    Having gone through everything I can find on this site about the Delta Pulse, I can say with certainty there is no clear explanation for its construction and stage testing.
    Many videos and links have over time been deleted or no longer connect to anything.
    Having never built a detector I have read extensively about them. I can fix most vintage hifi equipment given that a relevant manual exists.
    That said the Shangling SCD T200 looks and is said to sound amazing but there is probably only one person in the world who can fix them
    and he won't because they are hell to work on added to that key parts are of the unobtainable variety
    Problems in vintage hifi most often are electrolytic capacitors in the power supply, rarely do I need to use an
    oscilloscope, & I have not touch one for the last five years. I have all the test equipment but no one really shows where the leads go when testing.
    You see a video or picture of an oscope image but where are the leads going? I suspect flyback is measured off leg 6 of LF357 and + Earth
    or is the +E, but find me a picture of that. Maybe its pin 3, what is pin three? how do I count the pins?
    What happends if you slip with a lead when the power supply is on?
    If its a component connected to a heat sink its likely bad news.
    I did that once on a Philiphs CD104 and learnt alot about diodes.
    So what is the purpose and what am I going to do.
    Post images and comments which I hope fill in the gaps of building a metal detector.
    Frequency, pulse, band width, waste line all these terms I find a bit of a head banger.
    Maybe I should put together a glossary of terms, probably not a good idea although I know what an expanding waste line means.
    Maybe a proper glossary that could be incorparated into and introductory book for beginners?
    Well must get back to work
    PS
    Hi Infamy,
    do you know this Deltapulse document?
    delta pulse metal detector practical guide_5.pdf
      if you measure LOGIC levels of mosfet digital chips, LM556, you set null lead on -E. if you meassure in analog part of the sch you set null lead on GND point, DA4 pin 1.
        Hi Infamy,
        [ATTACH]n440784[/ATTACH]
        Yes, I found three copies of it on my computer yesterday.
          Hi Infamy,
          I don't really understand why some people have trouble building the Deltapulse or other detectors. Perhaps you could explain what problems you're having with the build. Are you unsure where to start? Or how to use tools like a digital meter or oscilloscope? Do you need a step-by-step guide to make sure you don't do anything wrong? Or is it something else? And yes, don't panic, you're not the only one having problems with it. I've heard this several times before from others who have similar problems.
            i can google translate a text with description of how DP works but what it will give you if your practic in electronics is zero?
            with good level in electronics you do not need in any texts, you see how the sch works by just A LOOK.
            i just suggest again - read the HAMMERHEAD PROJECT article for a magazine by Carl Moreland and it is BEST for the understanding.
            Click image for larger version  Name:	nick_txt.jpg Views:	0 Size:	593.5 KB ID:	440800
              Hi Infamy,
              Plain and simple
              There is no build document that shows the stages of construction.
              No guidance on testing during construction.
              Inconsistancey in the use of terms and abbreviations.
              Earth/Neutral but is anything but neutral eg Oscope danger, E-/E+ digital/analog take your pick.
              ITMD3 No glossary just a run through of abbreviations.
              ITMD3 Poor graphs in comparison to The Art of Electronics.
              ITMD3 The information is all over the place, your all the time trying to remember where is that information.
              The Art of Electronics chapter 1, its bare and does a bad job as an introduction to electronics.
              So I'm going to post my progress of building and ask the questions, which components to solder in first how to test, what's next.
              Photographs of a piece of a test equipment, asking the question for example, a funtion generator what can I do with that and how.
              I'm starting with building a NE555 tester. I've found what I think is a good example on a Youtube video with actual spoken words not canned music.
                Hi Infamy,
                Thanks for your reply. Based on the Deltapulse schematic drawn by KT315, I've drawn the order in which I would begin assembling the detector. In Block 2, where you need your test coil, you should already have a ready-made one. Maybe that will help.
Name:	Delta Pulse by KT315 (blocks)2.webp
                  absoliutely right, Geo, but i suggest to check sound isolated on stage 2. your is 7. i got very much requests why no sound getting and they were extremely offended.
                  sound must be ALWAYS - it is rule.
                    Since you haven't built a metal detector before, I will agree with kt: start with the Hammerhead project. It is well-documented and a simpler, straightforward design. The Delta is one of the more complex PI designs. The HH project will get you familiar with the various stages and should help the Delta make more sense.
                    If you have suggestions to improve ITMD let me know.
                      NE555 Tester. Faulty NE555 chips were identified as a problem in past Delta Pulse builds.
                      This tester should remove one problem to start with. Original design can be found here.
                      https://www.youtube.com/watch?v=vxc7sAmEeOA
                      Click image for larger version  Name:	IMG_20250913_172250.jpg Views:	0 Size:	812.2 KB ID:	440844
                      The original design had the resistor value missing next to the LED. I used a 1k resistor as that is what I used on an
                      amp when I wanted to change the light colour of the dials. Originally the design used a 1uf capacitor, but a
                      10uf capacitor is needed to make a 1 second led flash inteval, I did not change original capacitor symbol which is
                      probably wrong. A couple of things I found out, worth doing a continuity test if nothing is working, the current does
                      not go the whole way down the bread board so its possble to have the battery connected to nothing. Worth highligthing
                      the schematic as you complete a part, so easy to miss a connection even on something as simple as this.
                      Click image for larger version  Name:	IMG_20250914_111649.jpg Views:	2 Size:	544.2 KB ID:	440840
                        Hi Infamy,
                        Well that's a result, thanks.
                          Hi Carl, point taken about the Hammerhead but I don't think an easy ride will push any boundaries for me, boundaries being what I outlined at the start.
                          It also side steps answers to question being refered back to the Hammerhead article.
                          Write the chapter 1 you don't want to write and a large glossary. I think those two additions would add to the book.
                          How can you insert a colour zoomable image into a book?
                            i wrote the glossy... with people help. but it's in Russian. English is not my interior. anyway you can translate.
                            Технический глоссарий по металлодетекции
                            Содержит термины, определения, сокращения и сленг
                            Существуют три основных типа детекторов. Схемы основанные на принципе девиации частоты включают BFO, PLL и OR типы. Индуктивный баланс IB охватывает TR и VLF, также как и Two-Box типы, хотя последние иногда относят к RF. И последний тип - PI.
                            All Metal Mode ‘Все металлы’ - Режим прибора, позволяющий точно локализовать обнаруженный металлический объект. Дискриминации нет. См. также Pinpointing.
                            Audio ID - Звуковая идентификация. Способность прибора изменять тон звукового сигнала в зависимости от типа обнаруженного металла.
                            Automatic Ground Exclusion Balance - Автоматическая балансировка, устраняющая влияние грунта.
                            BFO, Beat Frequency Oscillation - Метод биений. Контролируемым параметром является разностная частота (биения) генератора поисковой головки и опорного генератора. Возможна работа в широком диапазоне частот. Чувствительность приборов BFO низкая, вследствие низкой стабильности частоты генератора поисковой головки, склонности к принудительной синхронизации (захвату или взаимному затягиванию частот двух генераторов), а также полной невозможности отстройки от влияния любого грунта. Метод может найти применение в пинпойнтерах.
                            Black Sand Черный песок - Песок с высоким содержанием магнетита (Fe3O4, магнитный железняк, колчедан, трёхвалентная окись железа). Обладает магнитными свойствами. Затрудняет точную дискриминацию.
                            Conductive Salts - Электропроводящие соли, электролиты. Будучи растворёнными в воде, обуславливают проводимость мокрого песка на берегах некоторых водоёмов. Создают помехи поиску, из-за положительного сигнала сравнимого с электропроводностью металлов.
                            Conductivity Электропроводность - Величина, обратная сопротивлению. Характеризует способность металлического объекта проводить электрический ток при воздействии на объект электромагнитного поля поисковой головки.
                            Conductivity Электропроводность - Физическая величина, характеризующая способность металлического объекта к возникновению на его поверхности вихревых токов при воздействии на объект электромагнитного поля.
                            DISC, Discrimination - Дискриминация. 1. Способность дистанционного определения типа объекта без необходимости извлечения его из грунта. Обеспечивает возможность избирательного поиска желаемых объектов и игнорирования нежелательных. 2. Настройка, которая однозначно указывает какие объекты будут проигнорированы.
                            Depth Глубина обнаружения – Эквивалент понятия “чувствительность”. Максимальное расстояние обнаружения.Параметр зависящий от глубины проникновения поля TX, свойств среды. Для условий открытого пространства и грунта см. также "Расстояние обнаружения" The Actual Depth of Detection for ANY Metal Detector is Determined by the Type of Metal, Size of the Object, How Well you made the Coil, The Size of the coil and Soil Conditions.
                            Double D Coil, DD Coil – Поисковая головка, формы обмоток которой напоминают два символа D. Обмотки имеют общую область перекрытия (наиболее чувствительную), чем достигается балансировка ПГ в ноль.
                            Drift Дрейф - Свойство, изначально присущее всем электронным схемам с высоким уровнем усиления. Выражается в самопроизвольном изменении порога чувствительности прибора в результате разряда батарей, температурной нестабильности и других факторов.
                            Eddy Currents - Вихревые токи. Круговые электрические токи, циркулирующие на поверхности электропроводных тел при воздействии на них электромагнитного поля.
                            GB, Ground Balance, GEB, Ground Exclusion Balance, Null, Zeroing Настройка на грунт или Отстройка от влияния грунта - Настройка для приборов балансного типа,, позволяющая ослабить влияние маскирующего эффекта минерализации и проводимости грунта, способствующая достижению максимально возможной глубины обнаружения.
                            Hot Rock “Горячие камни” – Минералы, которые более магнитны и/или электропроводны, чем окружающий грунт; все камни, на которые реагирует МД. К “горячим камням” относят также и метеориты, которые являются желанной, ценной находкой для поисковика.
                            IB, Induction Balance Индуктивный баланс – Метод, в котором для обнаружения объекта используется определение изменения фазы RX сигнала относительно фазы TX.
                            Mineralized Ground Минерализованный грунт - Любая почва, содержащая электропроводящие или магнитные компоненты.
                            Motion Disc, Motion – Схема с динамической дискриминацией. Требует постоянного движения поисковой головкой, дабы прибор реагировал на цель.
                            Non-Ferrous Mode – Режим “Цветной металл”. Прибор откликается только на цветной металл, к которому относят золото, серебро, медь, латунь, бронзу, алюминий, свинец, олово.
                            Non-Motion – Статическая схема, которая пришла на смену BFO в ранних 80-х. Прибор реагирует на цель и в том случае, если остановить движение поисковой головки. Требует частой подстройки на грунт – так называемого обнуления.
                            Notch Filter – Режекторный фильтр, фильтр-пробка. Схема, позволяющяя опознавать и игнорировать определенные типы нежелательных объектов.
                            OR, Off Resonance Срыв резонанса - Анализируемым параметром является амплитуда сигнала на катушке колебательного контура, настроенной близко к резонансу с подаваемым на него сигналом от генератора. Появление металла в поле катушки вызывает или достижение резонанса или уход от него, в зависимости от вида металла. Метод находит применение в пинпойнтерах.
                            *** PI, Pulse Induction Импульсная индукция - В приборах этого типа катушка не является частью колебательного контура . От генератора мощный ключ замыкая катушку на питающую цепь на короткое время. В момент его закрытия в катушке возникает импульс самоиндукции (по аналогии с телевизионной разверткой - “импульс обратного хода” или “хвост”). Анализируемым параметром является положение участка сканирования (сэмплирования) на заднем фронте пологого участка напряжения ИОХ. Отличительными чертами этого метода являются: низкая рабочая частота следования зондирующих импульсов, увеличенное потребление энергии по сравнению с IB, нечувствительность к грунту, отсутствие явной дискриминации.
                            Pinpointing Пинпойнтинг -Целеуказание. Определение центра объекта. Работа прибора в режиме ALL METAL.
                            Pinpointer Пинпойнтер - Малогабаритный ручной детектор-"указка", как правило без дискриминации, с низкой чувствительностью. Служит для быстрого обнаружения цели в вынутом из раскопа грунте. Сокращает время поиска.
                            PLL, Phase-Locked Loop ФАПЧ - Система фазовой автоматической подстройки частоты.
                            RF - Radio Frequency Радио частота - Высокочастотный вариант T/R, T/R в первоначальном смысле, где передающая и приемная катушки образуют не плоский трансформатор, а разнесены в пространстве и расположены перпендикулярно друг к другу. Приемная катушка принимает отраженный от металлической поверхности сигнал, излучаемый передающей катушкой. Диапазон рабочих частот 100-500 Кгц. Этот метод используется в глубинных приборах и характеризуется нечувствительностью к мелким объектам и отсутствием различения металлов.
                            RX – Сокращенное от Receiver, приемное устройство.
                            Sensitivity, SENS Чувствительность - Эквивалент понятия “глубина обнаружения”. Часто упоминая чувствительность имеют ввиду расстояние, на котором прибор еще способен реагировать на мишень “по воздуху”. В реальных же условиях, в силу специфики конкретного грунта и особенно наличия галло вокруг объекта, чувствительность может варьироваться в широких пределах.
                            Target ID - Идентификация цели. Cм. также Audio ID и Visual ID.
                            Threshold, THRESH Порог – Оперативная настройка прибора на порог слышимости звука и/или момент начала индикации.
                            TR/VLF, Transmitter-Receiver /Very Low Frequency - Метод позволяет создавать высокочувствительные приборы, балансного типа, с хорошим различением типа металлов (FERROUS или NON-FERROUS) за счет определения фазовых и амплитудных характеристик. По методу VLF сейчас строится большинство серийных приборов, в том числе и компьютеризованных.
                            Эти приборы имеют высокую чувствительность и разрешающую способность, которая зависит от диаметра головки - чем головка больше, тем глубже обнаружение, но тем труднее искать мелкие предметы. Может использоваться для поиска пустот и других неоднородностей в проводимости грунта.
                            Trigger – “Триггер”, “курок”. Тумлер для оперативного переключения режимов, расположен на рукоятке штанги МД.
                            Turn On & Go, Switch On & Go “Включи и ходи” – Приборы с минимальным количеством настроечных регулировок на панели, не требующие навыков и обучения пользования. часто только с одним регулятором настройки, подчас только с одной настройкой DISC. “One knob operation. Just pick it up, set your trash rejection level and start searching. No tuning, no meter, no gimmicks!”.
                            TX – Сокращенное от Transmitter, передатчик. TX Coil – передающая катушка передатчика.
                            VCO, Voltage Controlled Oscillator ГУН – Генератор, управляемый напряжением. Применяется в схемах МД для точного целеуказания - чем точнее катушка расположена над центром цели тем выше тон.
                            VCO - Voltage Controlled Oscillator ГУН – Генератор управляемый напряжением. Применяется в схемах МД для однозначного пинпойнтинга - чем точнее катушка расположена над центром цели тем выше тон. Возможно одновременно и дискриминация - когда от цветного металла частота звукового тона повышается, а от чёрного – понижается (при этом громкость сигнала может зависеть от дальности до цели и ее размеров).
                            Visual ID Визуальная идентификация - Способность прибора отображать на дисплее точную информацию об объекте в виде условной шкалы проводимости/типа объекта.
                            VLF, Very Low Frequency - Приборы с рабочей частотой 4-80 кГц.
                            Галло – Образующиеся втечение длительного времени проводимые соли в окружающем объект грунте.
                            Глубинник – Глубинный МД, построенный ли по принципу TR, , с разнесенными ортогонально расположенными катушками-антеннами (например, серийные, WHITE’S TM808, DISCOVERY TF 900), Two-Box (FISHER Gemini III,) или PI с глубинной поисковой рамкой. Сюда относят также и приборы IB типа, к которым может быть подключен т.н. “умножитель глубины” – приставка с разнесенными катушками (Garrett ADS, CXII, XIII серий и новейший Garret GTI 2500). Предназначен для поиска крупных объектов на большой глубине. Не чувствителен к мелким целям, а потому не пригоден для их поиска.
                            Динамическая схема – Схема с разделительными фильтрами, обеспечивающая развязку по постоянному току, дающая возможность повысить производительность прибора, за счёт снижения сверхнизкочастотного дрефа схемы, а также влияния неоднородности проводящих свойств грунта на территории поиска.
                            МД, МИ – Металлодетектор, металлоискатель, но ни в коем случае не миноискатель! Ни мины, ни другие опасные боеприпасы и предметы не должны являться объектами интереса поисковика.
                            Нежелательные объекты или цели – Металломусор, не представляющий ценности, – гвозди, пивные крышки, водочные пробки, фольга и пр. “You'll dig every little pice of wire, rivet off of blue jeans, bobby-pin, zipper pull, pop-top, beer top, bottle cap.”
                            ПГ - Поисковая головка, Катушка, Датчик –Единый конструктив с передающей и приемной обмотками сборе, может также содержать конденсаторы контуров RX и ТХ, цепи предварительного усиления RX, балансировочный трансформатор и т.д. Основные типы ПГ: концентрическая, эллиптическая, Дубль D.
                            Самопалы, Самостроки, Носороги, Рогачи – Кустарные самодельные приборы, разной сложности и типа действия. Несмотря на часто убогий дизайн, могут превосходить фирменные, как по надёжности, так и в отношении цена/качество.
                            ** Стандартная цель - Специальный металлический предмет, определённого размера и формы, предназначенный для внутризаводских испытаний МД на чувствительность, с целью стандартизации и контроля производственного процесса. Всемирного стандарта цели, в настоящий момент, не существует. Российский, "пользовательский стандарт" - это пятикопеечная монета 1961 г. Для глубинника - “саперка”, “каска”, “ведро”, “люк колодца” и т. д. У коллег - nickel, dime, penny
                            Фирменные приборы – Приборы изготовленные известными производителями МД, например: Minelab, Fisher, Garrett, White’s, Tesoro и др.
                            извиняюсь. это наверное я особонетерпеливый..
                            а можно ещё вот этот кусочек текста разместить?
                            -----начало-------------
                            Принцип работы BFO (Beat Frequency Oscillation) металлодетекторов основан на сравнении разности частот между образцовым и поисковым LC-генератором. Измеряемым параметров является частота LC-генератора, включающего катушку поисковой головки. В зависимости от того, объект из какого металла (чёрный/цветной) находится возле поисковой головки, частота поискового контура понижается или, соответственно повышается. Частота сравнивается с эталонной частотой опорного генератора и полученная разностная частота биений выводится на звуковую (визуальную) индикацию.
                            Принцип работы IB (Induction Balance – индукционный баланс) или VLF (Very Low Frequency – очень низкая частота) – самый совершенный тип металлоискателя в настоящее время. По этому принципу построены большинство “фирменных” приборов промышленного изготовления, в т.ч. и компьютеризированных. Принцип основан на анализе амплитуды в приёмной катушке поисковой головки и фазового сдвига между сигналом в передающей и приёмной катушке. При отсутствии вблизи поисковой головки металлических объектов амплитуда сигнала минимальна, фазовый сдвиг, в зависимости от конструкции прибора , 0 или 90 градусов. При появлении вблизи поисковой головки металлического объекта амплитуда сигнала в приёмной катушке увеличивается, а фазовый сдвиг изменяется в зависимости от проводимости металла (чёрный, цветной).
                            Метод позволяет производить выборочную дискриминацию металлов, отстройку от грунта и поиск пустот. Можно примерно определить металл мишени (даже отличить цветные металлы), а также “отстроится” от металлического мусора (пивных пробок, сигаретной фольги) с помощью встроенного компьютера. Требует прецизионного изготовления и настройки поисковой головки.
                            Металлоискатели типа FM (Frequency Meter - частотомер). Этот тип появился недавно, и создан на основе микроконтроллеров. Изменение частоты поискового контура определяется не на слух, а с помощью программы, заложенной в микропроцессор. Это более объективный метод, кроме того, такие металлоискатели обладают намного большей чувствительностью, чем BFO, и различают цветные и чёрные металлы.
                            Принцип работы PI (Pulse Induction – импульсная индукция). В приборах этого типа катушка не является частью колебательного контура. В от запускающего генератора подаётся импульсный сигнал. Анализируемым параметром является время окончания переходного процесса (положение заднего фронта импульса напряжения) в поисковой катушке. К конструкции катушки не предъявляется особых требований. Отличительными чертами этого метода являются: низкая рабочая частота следования импульсов (50…400 Гц), большое потребление энергии, нечувствительность к грунту, не очень хорошее распознавание металлов, однако такие приборы не требуют периодической подстройки. Металлы эти приборы не различают, но “бьют” далеко ( раза в два дальше, чем приборы, работающие по принципу FM). Незаменимы при работе на прибрежной полосе, под водой и на сильно минерализированном грунте, так как свободны от эффекта земли и воды.
                            PI-метод часто используется в подводных приборах для ослабления влияния воды.
                            Принцип работы T/R (Transive/Resive – передача/приём) предусматривает разнесение передающей и поисковой катушки на большое расстояние. Приборы отличаются большой глубиной поиска и нечувствительностью к мелким предметам (монеты, гвозди).
                            -----конец---------------
                            и хотелось бы увидеть толкование этих терминов:
                            BBS (Broad Band Spectrum) – многочастотное обнаружение
                            Pinpoint – òî÷íîå ìåñòîðàñïîëîæåíèå
                            DVT (Dual Voltage Technology)
                            SST (Smart Scan Technology)
                            PCO (Phase Control Oscillator).
                            FBS
                            VDI
                            GEB[/b]
                              If you have a really good understanding of both electronics and PI operation then the Delta project should not be all that difficult. If you don't, then it will be a lot of frustration.
                              What should be in chapter 1? I will expand the glossary on the next major rev.
