super pulse
  • super pulse
    Hi everyone, I've built many metal detectors but haven't been satisfied with any of them. I've tried digital and analog, all kinds. I'm looking for a stable and truly useful device. I'm waiting for your suggestions. Which device should I build?
    Does this imply that you've been making truly unstable and useless ones so far?
    Before any question to others and before any decision; you need to define your goals.
    Which detector, what kind, for what purpose, what specifications?
      I realized around 2011 that I was not capable of making a VLF I/B detector that would meet my expectations 100%.
      And then I solved that problem very simply. I bought XP Deus 1.
      In the meantime, a lot has changed on real soils, and now Deus 1 no longer meets my expectations 100%.
      Now I'm in trouble again.
      Am I going to try to build myself a metal detector now?
      No, I'm still not capable of making anything better than what I have.
      Bottom line: my goals are high and ambitious.
      In a similar way, you need to define your goals for yourself first.​
      You asked this question in the PI thread, which implies that you want a PI detector first.
      The best you can DIY at the moment is the Pulse Star 2 or the Gold Scan by Eric Foster, depends on what exact type of PI is your primary goal.
      You have that threads on the forum, you have the schematics, you have the pcbs. Just search for it.
      If that doesn't meet your criteria either... then do as I did; buy yourself a better detector.
        Yes, you're right, I want to build a pulse detector, and it's especially important that it's discriminatory. I want to build an ivconic PD3200, but the PCB needs to be double-layered, and I haven't been able to figure it out yet. I need help.
          This is probably awkwardly written, I'm "ivconic" and the PD3200 has nothing to do with me.
          It is a detector that originated in Bulgaria. I'm not sure I remember who the author was.
          I had the opportunity to see a DIY PD3200 at a colleague's place.
          It is a solid PI detector.
          Neither better nor worse than the others in that category.
            Dear ivconic, yes, it has nothing to do with you. I want to try this, but unfortunately I can't make a double-sided PCB. So, what is your suggestion for me?
              The author of PD3200 is given only demo HEX which is not fully functional.
              Until you provide a full functional HEX file for the processor; there's no point in thinking about crafting.
                So what do you advise me to do? What are your thoughts on this?
                  So far, as I understood; you would like something like this:
                    Hi haylaz0036,
                    Don't be lazy (in our country the word "haylaz" is used for lazy person)! The variant of "Delta pulse", very old PI detector, now with using of microprocessor's control, not solve the lack of ground balance and discrimination possibilities of this detector. Pay attention to new hybrid solutions with ground balancing and sure Fe/non-Fe discrimination.
                      Originally posted by Detectorist#1 View Post
                      Hi haylaz0036,
                      oh oh oh. just remind you chineses are selling SANDBANKS based oldest detector and get good money, this schematic with just one sample while DP uses
                      two - second is ground balance.
                      MAIN AXIOME. you can not build something if do not have full documentation. you can not build ML GPX5000 because you have not even pics of the pcb.
                      pleasure
                        ivconic, I can't do that. I've been through so much. Wouldn't it be better if it was something a little simpler?
                          Hi KT315,
                          Do you have possibility, as long time member of this forum, to announce here SIMPLE PI MD with ground balance and discrimination possibilities (not VDI) with full documentation (scheme, PCB project, BOM) for easy repeating from not very experienced person?
                            First determine what function you want to achieve, and then develop it according to the actual situation. This is a very simple thing.
                              Hi KT315,
                              Congratulations Detectorist#1, you would be doing a great service if you did something like this.
