Custom High-Power 24V Pulse Induction PI Detector Circuit Review
  • Custom High-Power 24V Pulse Induction PI Detector Circuit Review
    Hello everyone, I am building a custom high-power 24V Pulse Induction metal detector and I need your expert advice to review this circuit architecture and find any potential flaws, mistakes, or necessary corrections.
    Key Architecture in attached PDF:
    - Power Stage: 24V 6S BMS input, 50V 4700µF bulk capacitor, driven by FGH80N60 IGBT (80A, 600V) and IRF3205.
    - Regulation: LM317T (+15V for TLP250), L7812CV (+12V logic), and ICL7660S (-12V analog rail for NE5532 dual supply).
    - Protection & Damping: MUR1100E and 1N4148 input clamping diodes, 1N4746A gate zener, and a 330 Ohm 50W parallel damping resistor with CBB81 0.1uF 630V film capacitor.
    - Timing & Sampling: NE555 timer clock, CD4011B delay window, 2N3904 analog switch, and NE5532 + LM386 audio output.
    Please analyze the attached PDF schematic, point out any mistakes, and suggest what needs to be changed or corrected for stable deep-seeking performance.
    No schematic to analyse?
      currently drawing the schematic manually and will upload it shortly."
        Hi Aashif,
        Will be good if you mention the information for desired deepness and size of the targets as aim of this project.
        Before our analyze of the design of the schematic, one precaution - the IGBT transistor FGH80N60 is in "end of life" state. Last delivery date from the manufacturer is 08 Apr. 2022. Also, for the "brutal" TX power, maybe 600V transistor will be not suitable. Maybe 1200V transistor will be need. It is very probable to need of use 1700V SiC type transistor in this project and Teflon wire with 2500V isolation voltage for the coil.
          The idea to use 6S LiPo accus for powering of power PI MD is very good. This allows to use cheap and popular BMS charging modules for 6S Lipo. Using of schematic of popular "Polones" DIY project as a base have to be tested. For big distances the size of the TX coil will be 1x1 or 2x2 meters. This coil is impossible to be moved quickly and the lack of EFE samples maybe will be not so essential. EFE signals are proportional to the speed of the moving (the law of electromagnetic voltage generation).
            Hi Detectorist#1,
            Thank you for the expert analysis and the solid advice! I completely agree with your precautions regarding the brutal TX power and the 600V limitation.
            To answer your question: My ultimate aim is to achieve a detection depth of about 30 to 35 feet. At this extreme depth, I am strictly targeting massive metallic anomalies (like deep-buried chests or large hoards), not small surface targets.
            Based on your suggestions and my own project goals, I am implementing a highly modular and upgraded architecture:
            1. Transistor & Wire Upgrade: I am replacing the FGH80N60 with a much heavier 1200V IGBT (such as FGA60N120 or IHW40N120) to safely handle the extreme inductive spikes. I will also strictly use Teflon wire with 2500V isolation for the coils.
            2. Modular Tx/Rx Coil System: Instead of a standard mono-loop, I am implementing a Dual Tx/Rx coil geometry. Furthermore, the system is designed to be modular with interchangeable coil arrays. Depending on the field requirements, I can plug in 1x1 ft, 2x2 ft, 3x3 ft, or 4x4 ft dual-coil setups.
            3. Variable Depth Control: I am integrating a dedicated potentiometer circuit to dynamically scale the TX power/pulse-width. This will act as a "Depth Control" knob, allowing me to manually adjust the penetration depth anywhere from 1 foot for shallow scanning, all the way up to the maximum 30-35 feet range.
            I am currently drawing this updated and modular schematic on my PC using EasyEDA. I will upload the visual diagram here very soon for you and others to analyze.
            Thanks again for pointing me in the right direction!
