Surf Pi Professional Pcb's back in stock - NEW Prices
Quote"
"As well as the following file for adding a pin pointer mode (note the resistor R numbers don't match the Surf PI Schematic, but its easy to locate the place to add it): Attached Images End Quote"
Has anyone done either of these mod and had them work? I was unable to get either one to make any difference in the operation of the detector. I believe I put it in the right spot????
mine is working good now, i had to remove al the sockets to find an error under the last one on the pcb. but now everything works fine .
i need to find the right materials to make everything waterproof and if possible with neutral buoyancy.
greetings
Oh no my setup is not waterproof. The housing is a good base to make it waterproof. put i have the trimpots outside and they are a problem but i dont need a waterproof version.
Today i have tried to change some ic`s.
The parts that i have
build in at first: changed part result
TC7660
NE555 ILC555N other metallic sounding but no change in range
NE5534AP
HEF4066BP HCF4066BE no change at first look but 2-3cm more range
HEF4093BP HCF4093BE the range falls from 15-18cm 2Euro to 5-10cm
LM 358
at last i only left the HCF4066BE i have a range up to 18 cm with a coil of 24cm diameter from LIY0,25/1,3 with 1,3 OHM and 470microH (measured with a LCR meter) wdg? maybe 30.
here are some pictures of my finished project.
Some improvements follow this weekend i think my problems were caused by some ic´s.
I ordered the right one strictly like the partlist. If it works than better i post it that nobody take the wrong ones like me.
I see on the photo's that the via's beside the IRF9640 are "open" think it is better to fill the via's with soldertin , or even beter put a wire link over it, now... it looks strange, but I do not now how many current the via's can take, the ground from the 1000 uF Cap and coil is made with those via's. If anybody has comments.... ?
