Originally posted by golfnut
Tesoro Cibola
I bought a Cibola coil with a damaged cable from eBay. I then bought a 4-pin extender cable and spliced that onto the coil to repair it. That way I would have the exact same type of wire as the original. While doing this, I sketched out the
coil connector wiring diagram and thought I would add here for others.
Merc
Thanks for doing this. Is this looking into the male connector? I take it shd = shield? What is the D.C. resistance?Originally posted by Merc View PostI bought a Cibola coil with a damaged cable from eBay. I then bought a 4-pin extender cable and spliced that onto the coil to repair it. That way I would have the exact same type of wire as the original. While doing this, I sketched out the
Merc
http://www.geotech1.com/forums/showt...145#post160145
I'd like to see more inductance test results on specific coils from different quality testers so we can see how accurate different testers are.
I've been going through some life changes and hope to get back soon...too many unfinished projects.
Hope you find the info that I provided to be helpful.
last week i have finished the cibola pcb desgin from ivconic posting 45
little bit tricky but it works
minelab coil (1mH-10mH) works a little bit better than original sef cibola replacement coil (1mH-14mH)
but i think thats a frequency shift problem which could be fixed be using right cap values on rx and tx stage
no corrections done since post 45 but i will add them next weeks
kind regards
Completed the circuit board and remade Hex.
Hex Tested 2 weeks. The result is good
Hello Вernte_one ,Originally posted by bernte_one View Posthello gsl
is it possible that you can load a layout from the pcb
many thanks
I used the psb without the processor on the circuit from above page. The processor is connected to a short wire. Oт the weekend, I can remake a layout with the processor.Attached Files
I made a pcb with the MC. You can use the PIC16F873, PIC16F876. Hex same.
...i made analog model of cibola but works not as i hoped
i am sure the pic µcontrolled units performs better.....
In my opinion not much difference with or without MK MK. IMNOAttached Files
