Originally posted by kt315
Terminator 3, Terminator Trio
This is excellent idea. The task of constructing coil to verify a good working circuit is often a painful and time consuming exercise. Also coil can be poorly constructed whereas coil emulator is more precise. Once the detector circuit has been verified and is working well, then focus on building the optimum coil using emulator information.
Look here:Originally posted by Floki View Postdon't share the link?
http://elwo.ru/forum/6-217-1
http://elwo.ru/forum/6-1109-3
http://forum.cxem.net/index.php?/top...0%D0%BC%D0%B8/
http://forum.cxem.net/index.php?/topic/119295-terminator-pro/
http://forum.cxem.net/index.php?/top...0%D0%B8%D0%BE/
http://radioskot.ru/forum/14-6596-1Originally posted by Floki View Postdon't share the link?
http://radioskot.ru/forum/14-13507-1
http://radioskot.ru/forum/14-11877-1
http://www.md4u.ru/viewforum.php?f=80
The PCB is here: http://forum.cxem.net/index.php?/top...0%D0%B8%D0%BE/Originally posted by dbanner View PostThis is interesting, it's the terminator Trio "M" variation. Notice variable tone discrimination towards end of video. Nice feature.
https://youtu.be/zmABqFa_qIQ
Problem is that there are so many variations with so many different layouts, still can't find the layout KT posted for "double tone" on the russian forum. Google translator is not so good.
Looks to be a very good detector though.
Post № 1
You're probably joking! These are hundreds of pages in Russian, and you say that you've reviewed them all? Below I give you specific links to a page and a download. You will be able to download a PCB completely in a SMD.
But do not expect someone else to do the job for you.
http://md4u.ru/viewtopic.php?f=80&t=...2aa&start=1175
http://md4u.ru/download/file.php?id=24016Attached Files
This is significant, what do you mean? What is k561,k176? Are you referring to the TX oscillator, with TX coil disconnected, transistors in TX thermal runaway? Is there a solution for this? What is your redesign solution for TX?Originally posted by scs View PostI have made circuits with a resistor k561,k176 and a sd4000 in amplifier mode. They work unstable. When is no signal increased consumption and they are heating up.
Thank you SCS for reply. Yes I know SBG-PI is very good. Just looking at the schematic, It has all the elements of a very good design.Originally posted by scs View PostC16 is 8.2 pf.SBG-PI works much better. When installed correctly starts working right away.
Toros, he was just replying to a question I asked him.
