  • Need some technical data on the sensors (inductance, resistance ...). You also need to see the wiring and shielding of the cable. This is important. Then you can think they will work with the Mole-2 or not. But the right option is to manufacture the sensor itself, according to the author. Then the unit will meet its specifications.
    • Originally posted by smity View Post
      I constructed many coils. Shielding is something that i hate. With little graphite.... coil has erratic signals, with many graphite coil has not enough deep, i never be sure that the amount of graphite is ok. So when i construct a detector i try to use a coil from known manufacture. At most times the results are better that a hand made coil.
      • Hey guys what about differents between those two versions of PCB: KPOT-2M v01 & KPOT2-V_02
Name:	KROT PCB BW.jpg
ID:	338412Click image for larger version
        Someone has this "V_02" version ?
ID:	338418 My first pcb ever. Needs some cleanup but I hope it will be ok.
          I guess I should expose it a little longer. Have anyone made one on this version of board yet?
          • Be carefull... some pads (lines) maybe are broken.
            • hello, are that it is possible to modify the program so that it operates in three tons ?
              low > ferrous ,
              medium > gold
              aigu > copper
              • Thanks Geo. I will check it all before putting solder mask on.
                Solder mask will be my first time too. Will be doing dip version at the same time.
                Will post updates
                Can I program chip with
                Olimex AVR-ISP-MK2 MKII MK2 atmel AVR ISP programmer?
                Thanks in advance!
                • I did not look how to program it.
                  WM6 will do this work for me ...
                    Did you build smd version 1 or v2 the big one? Any pics? Depth?
                    • No, only the DIP version but i did not finish it because i wait for some components..
                      • That, so no one has collected the device? I produced, but I will not work properly. Not correctly identifies metals in the ground ...
                        • Originally posted by Black Digger View Post
                          Did you successful set the ferrite sample?
                            We collected the components but did not finish the project. I believe until the end of this month to finish it....
                            WM6.... what do you say????
                            • hey Guys what about latest clip of author`s KPOT2xm: http://www.youtube.com/watch?v=hAEC2NqG9Fw
                              Besadies of ****ty music, don`t You thing is something wrong of this md ? Ground could be full of iron?, or ground balance works bad, and why he miss few "high signals" - it`s not promising
                                Geo your board is almost finished. Only two resistors missing 1E and 2E, I have none of those value in 1/4W body only bigger stuff that not suit to PCB. On Monday I will visit electronic store to ask for those resistors.
