I used .33 mfd box film capacitor. I dont know how stable it is. I couldnt find a .33 mfd COG or NPO .I just tried to make it resonant to 8.5K hz by removing and adding TX coil turns.then rebooting MD to see what the new frequency is on the display. I think the new krot2 version is 3.4 Z80? or something. try looking on the forum, I think there is a new Sprint lay file.
For 10uF film capacitor C11 is of too small figure on a board. I think this is one of mistakes and it should be polarized. There are missing + on schematic and PCB designer program use it then as film capacitor with its shape. I used 10uF electrolyte capacitor on its place. It is 10uF as per schematic and part list too.Originally posted by Wiltran View PostDoes anyone know if C11 is a electrolytic? its supposed to be 10 pf? mfd? what? It is shaped like a box film capacitor on the board layout sheet.
Z80? We are on Sinclair ZX80 and Spectrum again? Not interested - in first line due high power consumption of Z80 platform. And why, there are still 10k free in xmega32 flash for improvement?Originally posted by Wiltran View PostI think the new krot2 version is 3.4 Z80? or something. try looking on the forum, I think there is a new Sprint lay file.
Hello!
I am the author of "The Mole " . My name is Andrew. I am very pleased to know that my device interested foreign friends ! The truth was surprised that more than one radio-enthusiast boasted full willingness device and that there is distrust of SMD parts ..)
And now to the point:
1. Nearly all displays with the controller HD44780 or similar work from 3.3V but this 3- need to apply a negative voltage C26,D1,D2,C27. Adjusting implemented R19 ( can be fixed resistor ) or instrument menu - The " Contrast " .
2 . Capacitor C11=10 uF can be both electrolyte and non electrolyte . I use ceramics 1206.
3 . R1 R2 = 1 ohm resistors ( I put two in parallel for 2 ohms )
R2 affects the accuracy of current measurement in TX!
4. Z80 - housing
Hello Andrew.Originally posted by ANDREW K2 View PostHello!
4. Z80 - housing
Welcome here
Can you tell us where is better to connect the Tx coil??? At Tx1 and Gnd, At tx1 and Tx1.1 or gnd and Tx1.1???
Hi Andrew, thanks for reply.
I mean Tx1 and Tx1.1 as shown at below pcb...
I saw what you mean....
RegardsAttached Files
TX coil connections
Hi Smitty, Ok so you connect one side of coil to TX1.1, providing you have a resonant cap in the coil, and the other TX connection to ground. Tx1 is unconnected, and you are now in bridge TX coil mode and you should have 2x TX coil power?Originally posted by smity View PostContact Tx1.1, is where you connect the transmitter coil, if the resonant capacitor is in the sensor. On the scheme, all right. And how to connect, you decide ...
