Originally posted by chrisw
Surf PI - successful build
Funnily enough,
There's a crossbow for sale on eBay UK.
The seller says only 17 of them built......
Different number there to what George states.
So going by recent reading,
May not be a genuine "George" unit ........
As it sounds like more were made.
Other thing said was it discriminates iron,
Is that an advertising ploy or true ???
Actually the listing says 13 built.Originally posted by DOOLEY View PostFunnily enough,
It's one of George's.
There's enough basic info on the web about the CB, as George mentioned it's a modified Hammerhead.
View the Hammerhead article and you will see how you can experiment and customize the tuning to your needs. Basically that is what George did for his customer for the purpose the CB was built for.
HI,Originally posted by bernte_one View Posthello chris,
two years ago or so the crossbow were made in a ldt count of ten or twelve units
that what i have heared from uk dtectorists who had the luck to get one was good
they loved the peformance on uk coastline and inland
had missed my chance to buy one but was some pounds over my possibilities in this time
but later i decided to truy a rebuild but didn´t finished
I have one PCB for the Crossbow left that I can spare, if you want take another try at completing one, let me know, will send it out to you.
Originally posted by chrisw View PostHi George, thanks for the info. Its good to know I can use other coils with the crossbow. The pictures look great, I dont know if my homebuild will look quite so good.
By the way, we have had contact in the past, and I never knew your name was George I thought you might be japanese because of your logo.
ChrisMy avatar is actually Chinese (not Japanese).Originally posted by SVEN1 View PostFunny you should say that, years ago that's what I thought
Qiaozhi is a common transliteration of George. In other words, that's how George sounds to Chinese ears. Zhen de me!
It was on there recently, but the auction has finished.Originally posted by DOOLEY View PostFunnily enough,
I think one or two people have tried to cash in, due to positive user feedback and the extreme rarity of these machines.
There were definitely only 13 made, and unit #1 is here next to me.Originally posted by DOOLEY View PostThe seller says only 17 of them built......
It's a classic PI, and as such cannot discriminate iron. Some users say they hear different sounds for iron, but personally I wouldn't trust that as a guide.Originally posted by DOOLEY View PostOther thing said was it discriminates iron,
Thank you. Being a novice, this may be beyond my skills. However, will attempt one of two boards . . . VERY SLOWLY following in other footsteps.Originally posted by Qiaozhi View PostBuilding the Crossbow will not be an easy task, and I certainly wouldn't recommend anyone to even try it if their electronics knowledge is weak, or they don't have an oscilloscope and understand how to use it.
Chris can you please explain why you need constant frequency adjustments ? what does your machine do to require it ?Originally posted by chrisw View PostHi Bernte_one,
My Mirage seems ok but I cant quite make the 30 cm mark yet, but I am still experimenting with coils. Also it is very sensitive an needs regular frequency adjustment. So I will have a go at the crossbow.
Chris
He has problems with EMI in the home so he can't find a stable frequency to keep the threshold a contant tick. He is using one of the new version boards where weOriginally posted by 6666 View PostChris can you please explain why you need constant frequency adjustments ? what does your machine do to require it ?
changed from a trimpot and with an external frequency control to a fixed PCB resistor and with an external control. The external frequency control only needs to be adjusted a very tiny amount at a time.
can be an issue for some. I am going to try a multi-turn control pot for the external freq. control.
Hi, ok so its a EMI problem, is the pcb inside a metal box ?Originally posted by SVEN1 View PostHe has problems with EMI in the home so he can't find a stable frequency to keep the threshold a contant tick. He is using one of the new version boards where we
Hi 6666,
Yes Sven has got it right. Its not as bad now as it was when I first built it, but still occasionally the emi causes a need to adjust the frequency to make it quieter. But once the detector is settled it works very well. Then a little later its as if it wakes up and starts to make noise again, so another adjustment is required. Since most of my life I have used VLF machines, I am not used to having to make any adjustments. But to be fair I haven't tried my detector away from home, such as on the beach. In my area I think there must be a lot of emi noise.
