Originally posted by useus
Pinpointer with discrimination "Cat-FM" on ATMega328P
Hello friends I just finished my PCB Lay.
Can you check if everything is okay?Attached Files
Hi, place generator parts as near as possible each other, coil capacitor(33nF) must be as near as possible to coil connector.Originally posted by Ruben2000 View PostCould you give me some points that I should take into account when designing my PCB?
Buzzer, LED and Vibro place as far as possible from generator. In general, that Is all my friend. And take a look on Useus design, there Is generaly correct layout.
I am also working on perfecting it because I tried it outdoors and there is a lot of instability, it sounds progressive from slow to fast with no target. sometimes it also goes haywire, I have to turn it off, wait 1 minute and turn it back on. I think it is a question of pcb,Originally posted by void118 View PostHi, place generator parts as near as possible each other, coil capacitor(33nF) must be as near as possible to coil connector.
of capacitors or the bc547 and bc557 transistors are not good at worst
Hi, first try to use 1.5.1 firmware with "1" sensitive and tell me about your coil please.Originally posted by useus View PostI am also working on perfecting it because I tried it outdoors and there is a lot of instability, it sounds progressive from slow to fast with no target. sometimes it also goes haywire, I have to turn it off, wait 1 minute and turn it back on. I think it is a question of pcb,
Second , you can try to wrap the sensor into aluminum foil and ground It, It's looks like earth magnetic field Impact. Where are you from friend?
Thank you very much my friend void118 !!!
Originally posted by void118 View PostHi, first try to use 1.5.1 firmware with "1" sensitive and tell me about your coil please.
firmware 1.51 all levels of sensitivity does not change anything.
now i temporarily shielded the coil as you told me and it's almost perfect thanks, i didn't understand what it could be. strange because during the tests he didn't do it to me.
I have two coils that give me the same effect, a 2.2mh 0.26mm wire 4 layers 25mm coil and a 2.4mh 0.45mm wire 2 layers 45mm coil. both on 2x 100x10 ferrite
The problem was In shake of earth's magnetic field, It can cause generator frequency shift I suppose.Originally posted by useus View Postyes that I know, thanks. I meant that I did not understand what the problem may have been, thanks again for helping me !!
Ouh, I understand, actually when you tested It on the table the coil was fixed relative to the magnetic field, but when you moving coil you can see sthe same situation like In compass, you moving compass and arrow moves too. This Is very similar situation I think. Nearest feature I will try do reduce generator frequency to 10kHz to reduce this effect.
great, then before shielding the coil definitely I await your upgrade!Originally posted by void118 View PostThe problem was In shake of earth's magnetic field, It can cause generator frequency shift I suppose.
