Hi, somebody try this?
PI from Poland
Hi Esteban. I found the LM-709 so after 10...15 days i will be ready to try it. Today i found the PCB. I moved in new house and exists big untidiness. (the other pcb at photo is for Delta Pulse)Originally posted by EstebanGeo
You can replace the 709 by the LM318. One friend said me there are problems with the connections of the 7660 in this Poland project.
GeoAttached Files
Geo
I have some 709 in metallic and plastic enclosure. I found near 10, I'll buy all. The 3130 metallic version found 20 and I buy 10. The Diana PI uses 3130 as you can see in this part of the schematic. Diana PI was published by Hobby Electronics, September 1981 magazine. This project don't have audio, only microammeter, and runs via a VN67AF N-Channel Enhancement mosfet transistor. Think will be easy change by another power mosfet.Attached Files
Hi Esteban. Yesterday i tried the project. Because i had a problem with the audio i checked the sensitivity with the meter . It had a medium sens. So with a coil 25 cm it detect a coin 25mm (2EURO) at 23..25 cm , a can of beer (330 ml) at 60 .. 65 cm and a PCB 13x7 cm at 60 cm. Today i will try to modify it for better results.
GeoAttached Files
excuse me if i resume this old thread.
I want to try to build this PI for home experiment and study.
I can buy all original components like LM709, BDX53A, LM741 but i don't find KP103Z well i can buy 2N5460, it is present in the component list.
It's correct new connection?
excuse my bad english.Attached Files
KP103 is soviet made FET... what western displacement... I am not in course...
http://www.5v.ru/ds/trnz/kp103.htm
