TX Cascade for Multi-Frequency
  • #31
    Everyone is free to ask whatever questions they want to ask; everyone is free to respond or not; and everyone is free to do whatever they want with information they get here. That includes a commercial venture. No big deal.
    • #32
      Thank you. It's really not that scary. We have encountered various situations with hacking keys to activate the firmware of the microcontroller. Therefore, the developer of the reality is so secure his work. There is no question about mailings: who wants to buy a microcontroller - there will be no problems on our part.
      • #33
        • #34
          Greetings. Studying further the question of constructing (repeating, to be honest) a TX cascade for the possibility of working both on resonance and with full bridge mode, I did not find anything better than this solution: https://www.geotech1.com/forums/foru...gle-full/page2
          as they say: all the best was invented before us. There is no need to reinvent the wheel.
          But there are questions....
          1. Figure 1: I understand that this is a RC-snubber for quenching bursts. This chain is optional: can it not be installed?
          2. Figure 2: Is this capacitor provided for the possibility of operation in the sequential resonance mode? If the need arises. So?​
          3. I understand that mosfets should be chosen not only according to the permissible voltage and current, but also according to the minimum gate capacity in order to ensure the best performance of the cascade. Right?
          4. As a voltage regulator, I can consider such a circuit. This solution allows you to adjust the voltage from 3.3V to 9V, providing quite a good current. Is this voltage range enough for a multi frequency of 2-3 frequencies? I understand that with such a small voltage range, it will not be possible to implement a single field for all frequencies using a single coil. But nevertheless.
          4. Looking at the board from Minelab Vanquish 540, I saw 6 elements in the sot23 case. I understand that in this metal detector, such a cascade scheme of the TX that we are talking about is implemented. Right?Click image for larger version
          The highlighted element is probably a driver for management? Like a ТС4428 chip?
          • #35
            Just a heads up, there are PIC Micros with 3 or more NCO's. If you use TWO, driven from the same clock source, you could use one with the NCO's giving 100 times each frequency of the output of the NCO's of the OTHER PIC. These X100 frequencies can be used to drive tuneable switched capacitor bandpass filters to extract the fundamental sine wave from the NCO square wave thus giving up to 3 FULLY programmable Tx frequencies. Demodulation can be done using quadrature generators made from two 7474 flip-flops again X3. I have sample code to setup the NCO's if anyone would like it, it's written in Positron BASIC for PIC Micros.
            BEST of ALL, these PIC's also have CWG's (Complementary Waveform Generators) which can drive a full H bridge with adjustable dead band. These things are ideal for MF detectors like the MF PI I build in an afternoon using one. Poor depth, but then it was a "will this work" exercise.
            Device = 16F1507
            Declare Xtal = 20
            '**** Added by Fuse Configurator ****
            ' Use the Fuses Tab to change these settings
            Config1 FOSC_ECH, WDTE_OFF, PWRTE_OFF, MCLRE_ON, CP_OFF, BOREN_ON, CLKOUTEN_OFF
            Config2 WRT_OFF, STVREN_ON, BORV_LO, LPBOR_OFF, LVP_ON
            '**** End of Fuse Configurator Settings ****
            Dim MySFR1 As Byte
            dim CLK_src as byte
            dim increment as word
            increment = $5565
            '**** NCO clock source Mask ****
            symbol NCO_CLKsrcmask = %11111100
            '**** NCO Pulse Width Mask (Depends on NCO1_MODE) ****
            symbol NCO_PWmask = %00011111
            '**** NCO Enable bit ****
            symbol NCO1_EN = NCO1CON.7
            '**** NCO EXTERNAL OUTPUT (to physical PIN) Enable bit ****
            symbol NCO1_OE = NCO1CON.6
            '**** NCO OUTPUT Polarity ****
            symbol NCO1_POL = NCO1CON.4
            '**** NCO INTERNAL OUTPUT (to INTERNAL peripherals) bit ****
            symbol NCO1_OUT = NCO1CON.5
            '**** NCO Mode OUTPUT mode 50/50 or Pulwe Frequency Modulation ****
            symbol NCO1_PFM = NCO1CON.0
            '**** NCO INCREMENT ****
            'symbol NCO1_INCmsb = NCO1INCH
            'symbol NCO1_INCLSB = NCO1INCL
            '**** ALWAYS write NCO_INCmsb first, THEN NCO_INCLSB ****
            '**** Remember to SET NCO1_OP if using NCOx to drive interrupts ****
            '**** INTERRUPT Control setup ****
            symbol gie = intcon.7
            symbol PEIE = intcon.6
            symbol NCO1_IntEN = pie2.2
            symbol NCO1_FLAG = pir2.2
            trisc = %00000000
            symbol Led1 = porta.0
            delayms 500
            high led1
            'clk_src = %01
            NCO1CON = %11110000
            NCO1CLK = %00000001
            NCO1INCH = $00
            NCO1INCL = $34
            delayms 1000
            LOW led1
            increment = $1077
            NCO1INCH = increment.byte1
            NCO1INCL = increment.byte0
            delayms 2000
            CWG1CON0 = %11100000
            CWG1CON1 = %01010110
            CWG1CON2 = %01000000
            CWG1DBR = %00101011
            CWG1DBF = %00101011
            stop
            increment = $2222
            delayms 2000
            increment = $3333
            delayms 2000
            increment = $4444
            delayms 2000
            increment = $5555
            delayms 2000
            increment = $6666
            delayms 2000
            increment = $7777
            delayms 2000
            increment = $8888
            delayms 2000
            increment = $9999
            delayms 2000
            increment = $AAAA
            delayms 2000
            increment = $1111
            delayms 2000
            increment = $BBBB
            delayms 2000
            increment = $CCCC
            delayms 2000
            increment = $DDDD
            delayms 2000
            increment = $EEEE
            delayms 2000
            increment = $FFFF
            delayms 2000
            stop​
            • #36
              Thanks! Thank you for the advice. This is very interesting and valuable information. At the moment we have settled on a scheme with a full H-bridge.
              ____
              By the way, the use of 199 did not justify itself: if the output signal form is still acceptable at a low frequency, then at a high frequency (after 20 kHz) there are already small signal distortions "in the switching places" of mosfets.​
              • #37
                By the way. Earlier I wrote that the TX cascade was built on the DRW8833 chip. Well ... It also does not work correctly in this cascade. It has its own fixed value of dead time. 450ns So it doesn't fit either. Now, as I wrote, the full bridge works on two mosfet assemblies (IRF7105) and the IR4428S driver
                • #38
                  You could do a fft/dft. I'm no expert but have dabbled and believe its a valid approach.
                  FFT of your samples will give you the (R)eal and (I)maginary numbers. Which you can then derive the magnitude and phase for each IR pair in each frequency bin. Requires a fixed sample rate that obeys Nyquest. The more samples and twiddle factors the higher the frequency resolution.
                  In metal detectors the "Real" is the resistive and the Imaginary the reactive components. Phase = atan(I/R) and the magnitude = sqrt(IxI+RxR). Once you have these for each frequency of interest, you can do as Carl suggested, the mixing across frequencies to get your GBs, vdi's.
                  Using Microchips dsp functions. I did a audio spectrum analyser a long time ago. I also did an analog dual freq detector where I learned how to mix the various signals to disc, gb or even null salt water response.
                  Here's a app note for 16bit dsp functions, they have similar functions for pic32
                  https://ww1.microchip.com/downloads/.../90003141a.pdf
                  All the other processor brands have dsp libraries.
                  Then again maybe its as simple running your samples through a set of firmware BP filters?​
                  Add: pic32 example
                  http://hades.mech.northwestern.edu/i...f_Analog_Input
                  I proposed a detector using this methodology way back in 1989. I sent it to Garrett proposing the name "Garret Digidec GTi" a few months later the GTi series was released
