Magnetometer MWB2.
  • Magnetometer MWB2.
    Hello. Here I will be publishing information on how to make a proton magnetometer MWB2 yourself. This information will be available as it becomes available. My English isn't very good, so there might be problems with translation.
    This is what a magnetometer looks like
      Magnetometer diagram.
        PCB in format Sprint Layout 6.0
          https://docs.google.com/document/d/1...f=true&sd=true
          User manual. In Russian
            Soft.
              An example of a magnetic card. Created in the Surfer program.
                This is a very interesting project. Most likely there will be no firmware file (hex)?
                  Can you post a block diagram ?
                    Very interesting project.What do you use it for?
                      Thank you. Do you have any information about the sensors?
                        Firmware file in post 6.
                          I will draw a block diagram and provide it
                            I use a magnetometer to search for armored vehicles. A magnetometer can be used to search for any ferromagnetic objects. Magnetometers have a much greater detection depth than a metal detector. The magnetometer detects fired ceramics, bricks, and pottery kilns. Unfortunately, the magnetometer does not detect objects made of non-ferrous metals.
                              I will provide information for making the sensor
