I've seen enough magnetometer projects, but I haven't seen a detailed description of the manufacture of a search sensor. Could you describe the manufacturing technology of the search sensor?
Magnetometer MWB2.
- Likes 2
Gerber files. The list of parts will be published later.Originally posted by j570 View PostHello. Very interesting project. Could you please publish the Gerber files and the parts list?Attached Files
- Likes 1
You can use both the first and second. Both work. $GNRMC and $GNGGA, UART baud rate = 9600 - required parameters.Originally posted by j570 View PostThe photo from inside the magnetometer shows a NEO-M8N GPS module, and the parts list shows a Beitian BE-800. Which module should I use?
The sensor's inductance, together with capacitors C22, C28, C34, C35, C36, and C37, forms an oscillatory circuit. This circuit is tuned to the following frequency ranges:
Range 6 - C37 - 3320Hz
Range 5 - C34 - 2869Hz
Range 4 - C36 - 2463Hz
Range 3 - C35 - 2111Hz
Range 2 - C28 - 1800Hz
Range 1 - C22 - 1511Hz
The magnetometer detects a magnetic anomaly from a passenger car at a distance of 8-12 meters. This range depends on the vehicle's position relative to the Earth's magnetic field and the magnetometer's relative position. A T-34 tank is detected at a distance of approximately 20 meters. A DP-27 machine gun is detected at a distance of approximately 6 meters.Originally posted by j570 View PostThank you very much. Could you describe your experience with this magnetometer? What are the typical detection ranges? For example, a shovel, a car?
What type of capacitors did you use? What type of dielectric? Relay R2-Nil-1C-12. Could you suggest an analogous type? I can't find one. Could you attach a picture of the board so we can see the component layout or do you have a file with the component layout on the board? I'm planning to build this magnetometer, so I have some questions.Originally posted by Fisher View PostThe sensor's inductance, together with capacitors C22, C28, C34, C35, C36, and C37, forms an oscillatory circuit. This circuit is tuned to the following frequency ranges:
