няма по- добро от монтаната, сашо
Metal detector with double tone and reject discriminator- new schematic
Sashe taka e prav si.Magnuma e naj-velikata shema.Ostavi gi komentirat.Az te razbiram ,za6toto samiq az sym izgubil bezbroj 4asove pred osciloskopa za da razbera nqkoi ne6ta.Kojto ne mu haresva da si napravi shema.Tvoqta izglezda mnogo interesna i razbira se ne e lesno ot edin pogled da se razbere kak raboti.I vse pak pozdravleniq!!!
I refuse off a double tone way now. because more important thing as people really only need is the discrimination. or, by another words the discrimination with zero level. it give full possibility to relic digging despite there is not all metal mode. I present new version for release by geotechers.Originally posted by sascho-bg View Postto ktT315
Wherefore send me ‘sturm’ without double tone and reject discriminator
yoursAttached Files
согласен. все так и есть. я это уже раньше увидел и устранил по типу Вайтс Классик-Тесоро (стабилитрон либо два диода на выход компаратора. добавляют еше и конденсатор чтобы сгладить скрип). просто файл со схемой на работе, а я сейчас в отпуске. а то что широтная модуляция понял еще когда выложили схему фишер-1280. на той схеме все подписано. но глубокого смысла копировать ШИМ я не вижу...
удач.
TO: Sasho Varna Bulgaria
1. What is the function of the potentiometer with label "tone"?
It is Volume control regulator for sound/tone, or Threshold, or?
2. For C35, C37, C38 with value "0.47".
It is 470nF, or?
3. What is the total power consumption?
Thanks in advance!
hi sasho hi all.
help me about this projrct with sasho please.
i want know what is the value of c29,30,31-c35,37,38-c66,65.wich range are they?
pf?nf?uf? the oscillator doesnt work with any simulators.where connect the emitter of q5, c1, c65? also head of r4?
why those power pin are differ from others? are the op10 and op11 393 or 339? if are 339 the pins are inaccurate.
and at the end c4 must be in search head or not?
please answer me in english.
best regards.
pozdrav Saso
Bravo , u pravu si za MAGNUM , ja 8 godini radim sa 2 kanalnim magnumom, dva tona ID. Modifikacija koju sam dobio iz BG i svaka cast onom ko je tu modifikaciju napravio. Ja sam jos malo doradio neke sitnice i sad je to jako dobar aparat koji nikad necu da promenim.Originally posted by sascho-bg View PostNiamam namerenie da si meria neschtoto s kogoto i da e.Znaia,4e wsi4ki
ste weliki.No nai welik e Flint,koito izmisli Magnum.
Nadam se da razumes sta pisem
